Question about Bose Acoustimass 15 6.1 Rear Speaker
Connect a laptop to a bose acoustimass sistem
    Brigadier General:
  • 8,546 Answers
If your laptop has speaker outputs that you can attach the provided bare wire cables to, maybe. Otherwise, NO. It requires speaker level inputs.
Posted on Apr 28, 2009
Can i connect my bose acoustimass 800 with any other receiver?
hi,
Surly you can connect these speakers to any receiver. It has an active subwoofer and 5 passive cube speakers. It can handle power up to 150W.
ok
Apr 28, 2011 | Bose Acoustimass 6 III System
Have this Bose system connected to my Yamaha a/v receiver
If you have it literally conencted the way you say not much good will happen.
The speaker OUTPUTs for the Yamaha feed the INPUTS on the Acoustimass Module then the satellites branch out of the Acoustimass Module's OUTPUTs.
Acoustimass module
Bose® recommends putting your Acoustimass module at the same end of the room as the
television monitor. To prevent interference, keep the module at least 2 feet (.6 m) from the
television.
• You may hide the Acoustimass module behind or under furniture, but do not block the
opening. Be sure there is at least 2 inches (5 cm) between the opening and any surface.
• If the opening faces the wall it increases the bass; if it faces away it decreases the bass.
For the most bass response, place the opening 2 to 3 inches (5 to 8 cm) from a wall or
corner.
• Stand the Acoustimass module vertically or horizontally (Figure 6). To stand it on the
cable connection end, remove the cover by gently pulling it away
Move the sub closer to a wall or corner to increase the bass.
This is a SYSTEM and as such is not designed to be pieced out or separated. I don't recommend that you try it that way. I doubt it will improve the sound.
Apr 30, 2010 | Bose Acoustimass 10 III System
How do i hook it up to a tashiba 42 lcd
usng rca cable connect from tv side audio output and audio in from bose acoustimass sterio.
Apr 13, 2010 | Bose Acoustimass 5 III System
I have a Lifestyle 35 and want to replace head unit with a 5.1 receiver. The Bose subwoofer model LSPS uses a network type cable connector on the sub side and a male din plug on the head unit side of...
The entire 5.1 amplification system, in the Bose Lifestyle 35, is actually part of the Bose Acoustimass (subwoofer) module. The RJ-45 (network type) connector passes a low-voltage signal from the console to the Acoustimass module. If you were to hack the connection, and plug the speaker outputs of a 5.1 receiver to the RJ-45 socket on the Acoustimass module, you would blow the amplifier.
If you are really itching to replace the Bose Lifestyle 35 console with a regular 5.1 receiver, I strongly suggest you sell your Bose system, and purchase a Bose speaker system, such as the Acoustimass 10 Home Theater Speaker System, which is made for use with a standard 5.1 surround sound receiver.
Dec 26, 2009 | Bose Lifestyle 28 System
Please help i have matsui dav50 home cinema dvd player and cannt change it from 2.1 to 5.1
i have Bose - Acoustimass® 20 Powered Speaker System without the lifestyle, can i connect a pre amplify to it
Oct 31, 2009 | Bose Acoustimass 20 System
Bose audio input receiver cable 15 pin
You can buy it on ebay but it's cheaper just to make one. If you can solder, all you need is a female 15-pin d-type connector and a bunch of speaker wire. Here is a diagram of the connections.
Jun 24, 2009 | Bose Acoustimass 10 III System
Can I connect my Bose Acoustimass 5 - Series II to Bravia unit?
Yes, there should be no issues using your Bose speakers with your Sony receiver. Sony has a "hookup guide" to help here -
http://esupport.sony.com/US/perl/model-home.pl?XID=M:products:crmportal&LOC=3&mdl=DAVHDX265
Please rate my answer, thanks.
Apr 30, 2009 | Audio Players & Recorders
Bose Acoustimass 8 pin Cable
Bose Lifestyle 3 or 5 not sure which. DIN 8 pin to 2 RCA's
Sep 11, 2007 | Bose Acoustimass 10 III System
356 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Ben Armstrong
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
