Question about Echo 30.1CC Chainsaw With a 14 In.bar and Chain
Chain brake problem
The chain clutch won't release. Even when I am trying to start the saw the chain moves.
I have a cs3000 14 inch saw about 10 years old.
It just started doing this for no reason.
I did try to adjust the idle screw but when I turn it down enough to make the chain stop the engine stops. Thanks Comment posted on Apr 09, 2009 I have tried all the things you suggested but they didn't work. Where is the chain break and how should it look when in good shape? Thanks Two Comment posted on Apr 12, 2009 The adjustment of the idle screw has nothing to do with the chain moving even when the motor isn't running. When I pull the started rope the chain moves several inches even though the engine never fires. I can take the plug out to make it easier to crank and the chain moves with each pull. I think it has something to do with the chain brake. Is it adjustable on this model? If not how do I replace it and where do I get the parts to do so? I have a cs3000 14 inch saw sn.023513. Thanks Bigal
  • Anonymous Mar 28, 2014
    is this saw big enough for a 42"?
    President:
  • 949 Answers
Http://www.echo-usa.com/pdf/documentation/CS3000T1T1E_081303.pdf
This is the breakdown of parts for your model,you can see how the brake is, but your problem sounds like the dogs inside the clutch are stuck and causing the chain to constantly engage the chain.
Open the clutch to look at it and see what is causing this.
The idle usually will not cause the clutch to engage, this is usually
a higher rev that engages the clutch.
Posted on Apr 14, 2009
Have a stihl chainsaw that's probably 10 yrs old. Will start ok but the chain won't move when given gas. It revs but won't move.
I guess the first thing to look at is chain free to move ?, do this with saw off ! and not running , if its not free to move give a good look at the chain brake , if chain moves free with a gentle push , then your clutch is in need of replacement good thing as stihl makes parts for there old saws still too , now if your saw was 20 yrs old your clutch is rebuildable
Apr 26, 2015 | Stihl Garden
My chain won't run on my 240 eseries when I try to release it ti cut
The hand guard on the machine should control the chain brake, you should be able to firmly pull the guard fully back to the top hadle to load the brake, if the saw has been run for any time with the brake on there may well now be some melting of the plastic cover, this will mean a new brake complete required, you will have to lever the brake off the saw as best you can, it will be tight because the band will be clamped around the drum, this should only be done as a last resort if pulling the hand guard back does not work
Oct 03, 2012 | Garden
HUSQVARNA MODEL 435 CHAIN SAW.....BRAND NEW IN JUNE...NEVER USED....WITH BLADE, CHAIN, AND SIDE COVER (TENSIONER ASSY) REMOVED, IT RUNS FINE......WHEN CHAIN BAR , CHAIN, AND COVER ARE REINSTALLED AND...
There is a number of ways to re load the brake, you can either remove the clutch and sprocket, the brake will then go back onto the saw enabling you to use the hand guard on the saw to load the brake ( to remove the clutch, there are two cut a ways in the clutch centre designed to enter a flat screw driver into, then strike with a suitable hammer to remove, it is a left hand thread ) or you can remove the hand guard from the saw and use this as a tool to re load the brake, or you can clamp the cover in a vice ( be carefull not to damage the cover ) then use a strudy pair of pliers or grips in the three legged loading mechanism and turn it to load the brake.
Dec 22, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
I am trying to replace the chain on my saw. When I try to fit the clutch cover back on the there is a metal band that does not seem to want to fit properly over the wheel, causing the chain to not move...
Your chain brake mechanism is in the "locked" position...you will need to release it. Some husky's have the handle on the cover. If this is the case simply pull the handle towards what would be the rear of the saw and install the cover.
Other saws have the handle on the saw and some little cogs mesh with cogs in the side cover. In order to unlock this one I use two 1/4" x 2 1/2 inch or so bolts in a vise. They get clamped with the bolts protruding vertically above the vise jaws and are spaced so the the tips of the bolt will fit in between the cogs. Study the assembly and determine the direction of rotation required to release the brake. Place the side cover face down over the bolts with the bolt tips in between the cogs and rotate until the brake cams over and releases. be sure you know which direction to rotate the cover as a bit of force is required to get things moving.
Once the brake is released you should be good to go.
Take care.
Dec 09, 2010 | Husqvarna Chain Saw 20" Bar
Can't get chain to move. Engine starts ok but seems to be burning clutch. Has not been used for 18 months.
Hi there, I suspect that the chain brake has been activated. To release it, pull back the front guard (in front of the front handle) until it clicks. The chain should now be free to move. Happy sawing !
Nov 06, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
On my saw when I changed the chain out, the cover will not go back on over the clutch correctly.. The cover has a ring in it that is supposed to go over the clutch but does not fit correctly, What am I...
You should have released the chain brake before taking things apart--it will be necessary to move the brake coupling in the cover with a wide blade, square shanked screwdriver and a wrench that fits the square shank of the screwdriver. It should make a 'snap' noise when fully released and the brake ring will have expanded to fit over the clutch hub. Hope this helps!
Oct 18, 2010 | Husqvarna Chain Saw 20" Bar
Chain brake jammed on Echo CS400 chainsaw
You will need to release the brake by applying a very heavy screwdriver to the + shaped part of the brake coupling. Check the action of the brake handle and duplicate it at the the +. Hope this helps!
Jun 25, 2010 | Echo CS400 18" Chain Saw
Chain brake is jammed, chain will not move when cranked
Take the side cover off of the clutch area and watch while you try to move the brake. Something may be broken or out of place. If the brake band which is fitted around the clutch drum is damaged, it may be causing non-release.
May 13, 2010 | Homelite ZR10926 16 Chain Saw
Starts but chain wont turn. and white smoke comes out the side where chain is. is it the clutch thats burn out?
Grasp the forward most upper handle (hand guard), move it forward, did it click? If no the brake is released. Pull it aft until the brake latches open (clicks), may require some grunt at rear extreme.
Remove the clutch cover, bar and chain. Start the saw, does it still smoke? Yes post back below, no reassemble your saw, ensure the brake is open. Start teh saw. Smoke? If yes post back below.
http://www.fixya.com/support/r4146814-chainsaw_chain_installation
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank You for using FixYa.
Apr 25, 2010 | Garden
I have an Echo CS-440 18" chain saw and the chain came off. Now that I have put it back on, it won't move either by hand or when the engine is running. Help
OK.  This is simple. Either the chain brake is engaged or the chain is too tight. Start by pulling back on the chain brake toward you.  There should be a "click" if the brake was released.  If the chain is still immovable, try resetting the chain tension. 1. remove the spark plug wire 2. loosen the two clutch cover nuts 3.hold the bar nose up and loosen the tension adjustment screw until the chain moves freely without becoming loose. 4. tighten both clutch cover nuts with the bar held up. 5. Pull the chain around the bar by hand.  Loosen the adjustment if you feel tight spots. 6. When the chain is properly tensioned,tighten clutch cover nuts securely.  Do not overtighten! 7.  Check chain brake operation and release. 8. Replace spark plug wire and operate  saw.
Hope this solution will Fixya.
Jan 10, 2009 | Husqvarna Chain Saw 20" Bar
Echo 30.1CC Chainsaw With a 14 In.bar and Chain Logo
508 people viewed this question
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you an Echo Garden Expert? Answer questions, earn points and help others
