Question about Cuisinart Brew Central 12-cup Coffee Maker
We have a Cuisinart DGB-600. Lately, when brewing
We have a Cuisinart DGB-600. Lately, when brewing coffee, it stops up to six times during the process and has to be restarted. We have de-limed it, but it is still stopping many times.
  • 2 more comments
  • Anonymous May 20, 2009
    I have exactly the same problem.
  • Anonymous May 25, 2009
    Same deal. It will only work if I use the 1-4 cup setting, but that's annoying.
  • bev091754 May 26, 2009
    Same problem...any solutions yet?
  • Anonymous Mar 16, 2014
    The on-off switch turns off intermittently (before the time limit and sometimes during the brewing process)
  • 85 Answers
Hello g_daniel,
Your units problem may be due to a filter problem. I am most familiar with the cuisinart dcc1200, but I may be able to help you.
Your described problem may be one of two problems. Let's start with the easier solution first. In the DCC 1200 there is a filter "stick or column" in the left rear. Pull it out and remove the clogged carbon filter(s) that are in there. Shine a light into the receptacle and remove the debris in the bottom. It is likely that this is causing the problem with you machine needing to be started on multiple times. See if this solution works. If it does, you might run 8 cups of water and 4 cups of vinegar through to help decalcify the units plumbing. Do this once or twice and then rinse with at least one pot run-through of clean water. If this works then you are good to go.
Next, if this does not solve your problem we can do the following: unplug the unit and lay it on its back. You will need a #10 torx driver (hardware store if you don't have one) to remove the bottom cover plate. There are 4 torx screws holding it on. When removed, you will find 2 orange hoses. Carefully attempt to remove the left hose without splitting. I used a eyeglas screwdriver to loosen it up. If it splits, just cut off the split and stretch it to reconnect when time comes. As you look into the hose you will find a little black valve inside as well a some gunk. Clean it all out with a fine wire as best you can. Rinse well. Attempt to reconnect the hose back onto the pipe. Slip the pipe clamp back into place. Replace the cover and screws and you should be good to go again. This is not as daunting as it may seem. You can do it. :o) Good luck! If this answer helps, please leave positive feedback for me. Much appreciated. Regards, NormanZ
Posted on Jul 10, 2009
We have a Cuisinart DGB-900 BC Grind and Brew Thermal Coffeemaker. Our Problem is that the bean grinder has stopped working. We purchased the coffee maker on 2/25/10. Prior to this happening, we were...
try cleaning the grind chute again. if problem persists:
this is a cronic problem with the DGB900BC even after cleaning. the problem is the gate or trap to the grounds needs to open/remain open during grinding or all backs up and jams. my unit opens the door (correctly) during the rotation but closes just before grinding (over-rotation?). Cuisinart is not aware of this problem (800-726-0190). please call them; i just have.
Aug 30, 2010 | Cuisinart Grind & Brew DGB-500R, 12-Cup...
Need instructions to operate DGB-600BC
Thanks for the reply. Got rid of the coffee maker. Its a dud. No more information required.
Jun 18, 2009 | Cuisinart Thermal DGB-600 Grinder
Cuisinart DGB-300 coffee maker brew pause valve
No one has just the individual part, but you can get the whole brew basket with the part included on Cuinart's website, or by calling them.
Feb 03, 2009 | Cuisinart DCC-100 Coffee Maker
Cuisinart dgb-600 brew pause feature doesn't work
Replace the filter basket - they can be had for around $6.00 plus shipping - you can even get them directly from Cuisinart.
Jan 23, 2009 | Cuisinart DGB-600 Coffee Maker
I have a cuisinart automatic grind and brew thermal coffee machine. Soemtimes, during brewing, the container holding the grinds pops open and the still brewing coffee pours everywhere.
On mine the door that holds the ground coffee in place at times doesn't latch properly either and then the it will pop loose. I have to close it fairly hard in order to get it to latch and I test the latch by pushing on the door to see if comes open. When properly latched it will only open via the little button on the side, not by jiggling the door.
Jul 07, 2008 | Cuisinart DGB-600 Coffee Maker
DGB-600 will not brew
The unit has either wiring connection problem internally or the internal motor is blown, it can only be found once the appliance is opened.
Dec 12, 2007 | Cuisinart DGB-600 Coffee Maker
DGB-600 Will no longer grind coffee
I am having the same problem, can someone please help?
Oct 09, 2007 | Cuisinart DGB-600 Coffee Maker
I just called Cuisinart and they will send me another brew basket for my DCC-100 (it has a Brew Pause valve also) for $9.14 (part + S&H). Did you try to contact Cuisinart?
Aug 30, 2007 | Cuisinart DGB-300 Coffee Maker
Open Questions:
See all Cuisinart Brew Central 12-cup Coffee Maker Questions
Cuisinart Brew Central 12-cup Coffee Maker Logo
192 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
