I have a hatachi 60 rear projection tv, the cable port on the back of the tv is broken, i pulled the back off the tv and pulled off the silver box, the f-connector that goes to the incoming cable line, is bracket is broken. I need to find out where to get a new one, or how to replace it.
  • 147 Answers
This can be soldered back into the tuner if the board in the tuner is not broken. If you need a new connector any electronics supply store will carry it.
Posted on Apr 14, 2009
60" RCA TV
The tuner in RCA is a known issue. I recommend connecting the satellite with RGB (Red-Green-Blue) component cables and red/white sound cables and use video. The picture will be better. The tuner repair can be pricey $$$
Apr 02, 2010 | RCA P52921 52" Rear Projection Television
60'' phillips projection tv suddenly won't turn on
it is best to have it serviced at a reputable repair shop...
Nov 13, 2009 | Philips Magnavox 9P6034C 60" Rear...
Can not get pip to work
Pip has its own tuner, try getting a cable splitter to split the signal into the tv. If you have digital cable you may need a second cable box to do this. If your cable provider still sends an analog signal the splitter will work.
Jul 10, 2009 | Toshiba 53H71 53 in. Rear Projection...
Digital tv
Unless it says HDTV it is not digital.
Feb 16, 2009 | Hitachi 60SBX78B 60" Rear Projection...
Broken Antenna Port
If you have already identified where the connection was on the board you will have to access the board to be able to solder back to the points where the old connector was. Once you have identified the two solder points (One should go to ground and the other if you can with the tv on touch it and see if a picture tries to come in or get rid of the snow). Then buy a matching transformer from radio shack or Home Depot, Lowes. Normally this would go on the outside antenna. But you want to take it and clip and strip the ends that have the forks. Solder this to the board, one to ground and the other to the point that would have been center on the old broken piece. This will have a 72 ohm or a connection that your antenna will connect to.
Jan 11, 2009 | Toshiba TP50G60 50" Rear Projection...
Replacing bulb and housing
the front comes off, you can see the parts.
Aug 07, 2008 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Hatachi 60 inch big screen test port e994 open high voltage shutedown
You can get the parts from www.TvRepairKits.com. They have put together a kit that includes the parts and instructions to fix the following models (50UX58B, 60UX58B, 50UX58K, 60UX58K, 50SBX78B or 60SBX78B). The kit includes the E994 pico fuse and the C707 capacitor.
Jun 24, 2008 | Hitachi 60SBX78B 60" Rear Projection...
RCA Silver Box
Silver Box? please explain your problem...for d52w20
Mar 16, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Scrambled picture when cable box is hooked to hdtv plugs on philips 60 inch rear projection tv
My hdtv component jacks will give a clear pic then pop back and forth into double images. Can anyone help?
Oct 03, 2007 | Philips 60PP9202 60" Rear Projection...
RCA 52" tv. model # D52W20
The silver box is called the TUNER. Call an RCA distributor, such as Union Electronics or Herman-Panson and order it by description by asking for the tuner for your model number. Have the location number on the board, just in case.
Sep 01, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Televison & Video Logo
50 people viewed this question
Top Televison & Video Experts
