Question about Toshiba Office Equipment & Supplies
Toshiba E-Studio 810 says call for service when check the cue references C26
Check to see if lamp lights. if not, replace lamp.
if lamp lights, pull the platen glass and replace the scanner board under cover by lens.
Posted on Apr 28, 2009
Please my heater lamp is not lighting.
U need to check whether the exposure lamp is light ON or not when u turn ON the machine
If not light ON, then exposure lamp unit or connectors might be faulty
Dec 21, 2015 | Toshiba E-Studio 160 All-In-One Laser...
When i switch on ma toshiba e studio 212 its showing me error c26. how can i fix it
it is cis unit error check connection between cis unit and main board otherwise replace cis unit ribbon OR cis unit OR main board
Feb 06, 2014 | Compatible Toshiba T1810 For E Studio 181,...
Toshiba E-studio 166 error code c26
hi. i have problem in my Toshiba e studio 166. that machine toner light is blinking always. i try so many time nd i fixed new toner also. but i cant get any result of this. pls help me to solve this problem....
Mar 07, 2012 | Toshiba e-Studio163 Copier
Good day, i lost my manual. how do i make a double sided copy. thanks chantel
E-STUDIO 810 Operator's Manual
Please visit the above link and download/ save the Manual for reference. (Chapter 2-11)
Hope it helps! Good Luck!
CreativeTECH
Feb 18, 2011 | Toshiba E-STUDIO 810 Copier
Tips on C26 code , more info how to fix
[C26] = Peak detection error
Does the exposure lamp light? (Perform the output check in the test mode: 03-267)
If no, Replace the SLG board-->inverter-->exposure lamp.
Oct 07, 2010 | Toshiba E-STUDIO 550 Copier
What is the solution for error code c26 on my toshiba e-studio 550 copier?
Hi how are you i hope you are well this is jack ..my personal ID.. (jack_pak@hotmail.com)
C26 Error is scanner error
please check the scanner unite
1 scanner lamps.
2 scanner strip.
3 scanner bord
4 LGC bord.
please check these all goods are working properly.
Thanks
Best Regards,
Jul 02, 2010 | Toshiba E-STUDIO 550 Copier
Call for service c26 in toshiba copier e 810
C26 indicates Peak detection error.
U need to make sure the exposure lamp is light when u switch ON machine.
If no light, then u need to check the inverter and the exposure lamp.
Oct 06, 2009 | Toshiba E-STUDIO 650 Copier
Help
C26 is a peak detection error (when the copier scans the white reference plate there is an error in the detection)
The most common cause of C26 error is the failure the lens unit which is Toshiba's part number 6LA02100000.
The components that fail on the board are IC1 and IC10.
The board can be repaired, but most commonly it is replaced.
May 05, 2008 | Toshiba E-STUDIO 650 Copier
Erro code c26
C26 indicates Peak Detection Error.
U need to check whether the lamp light on when u ON the machine.
If no, u need to check the inverter cable, inverter board, or exposure lamp.
If light is ON, then u need to perform following:
1. Check if the connectors on the CCD and SLG boards are disconnected.
2. Check if the shading correction plate is dirty.
3. Check if the conductor pattern on the CCD board is short- or open-circuited.
4. Check if the conductor pattern on the SLG board is short- or open-circuited.
5. Replace the lens unit.
6. Replace the SLG board.
Apr 08, 2008 | Toshiba E-STUDIO 650 Copier
397 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
