I have a canon CFX B3801F multi function system I changed the cartridge and now when copy comes thru no ink cannot read, thought bad cartridge changed second time still nothing
    Brigadier General:
  • 3,614 Answers
did you change original ink.. in some cases the cartridge must be reset.
also try to re install again the driver of the printer
Posted on Apr 14, 2009
U162 error on black ink cannon printer
This error occurs when printer fails detecting ink level or printer assume that no ink in the cartridge. We cannot use print, copy,scan, and fax function before the problem fixed. It's recommended for you to replace ink cartridge. To continue using the printer without replacing the cartridge we must deactivate ink level detection function. Be aware that printing in this condition can damage the printer while sending fax or scan is not problem.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Original source: http://ij-forum.blogspot.com/2008/12/error-message-check-ink-u162u163.html#ixzz2Cpr4Be1K
Nov 20, 2012 | Canon PIXMA MX340 Wireless Office...
Cant get my canon mx330 printer to work
Multifunction devices usually require two separate inks to acquire functionalities. For example, an empty ink cartridge especially the color ink may still produce copies without multi ink features. However, any attempts to dismaunt the ink cartridges would require restorations from the computer settings. First, inspect the printer for empty accessories that require replacements. After acquiring and replacing ink cartridges makes way for the next processes. Second, connecting the printer that has been restablished would produce display results requesting printer copy allignments. Attempt to print a document to produce the results for alligments. Goodluck
Jan 12, 2011 | Canon PIXMA MX330 Multifunction InkJet...
Copier appears to be functioning well, but page comes out blank
You actually answered your own question, you said it started fading and came out with lines missing. Looks like and could possibly be that the ink cartridge you are using wasn't as full as you thought it was, and the computer really has no idea, it's just software and i do not recall seeing sensors on the inside of the ink tank to tell the computer how much ink is in the cartridge. Try refilling the ink again or maybe a better idea is to buy a new cartridge since over time the cartridges can get contaminants in them which will block the ink from the inside of the cartridge.
Hope this helps
May 31, 2010 | Canon PIXMA MX310 All-In-One Printer
Cannon MP520 when printing documents there are lines through some of the text. I have changed the ink cartridge 2 times! What should I do?
The issue is not with the ink cartridge but with the actual print heads. In most (almost all) Canon ink jet prints/multi functions the prints heads are separate from the ink cartridge.
The print head is what guides he ink onto the page, if they become dirty or clogged then you will get lines through images and text or very poor print outs.
You can clean the print heads by using the software that came with the printer and there are some other ways as well.
I tried to paste the instructions from Canons site but they were too long. Use the link below to go to Canon's knowledge base for the MP520 and search for "clean print heads" and follow the instructions that come up.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=15483
Apr 14, 2010 | Canon PIXMA MP520 InkJet Printer
The printer says so ink cartridge installed on black.
my hp officejet pro 8500 wont make copies, it says replace yellow ink cartridge. can i not take the yellow cartridge out an still make copies?
Oct 01, 2009 | Brother Multi-Function Center MFC-240C...
Canon MX850 will not print from small Black Ink Cartridge - 8BK. It only uses the large black ink cartridge and I have a drawer full of small 8BK cartridges. How can I get it to use the small black...
Canon PIXMA MX850 Multi Function Printer Printer Canon MX850 will not print from... Answer Canon MX850 will not print from small Black Ink Cartridge - 8BK. It only uses the large black ink... (More) Canon MX850 will not print from small Black Ink Cartridge - 8BK. It only uses the large black ink cartridge and I have a drawer full of small 8BK cartridges. How can I get it to use the small black cartridge and not the large black cartridge? Thanks
Sep 30, 2009 | Canon PIXMA MX850 Multifunction Printer
Do not work
Thats odd, the Brother ink cartridges do not have heads attached to them, they are just ink tanks. Check to make sure that it is fully seated. also make sure that the cap was punctured when it seated. Clean any visible contacts with a q-tip & rubbing alcohol.
If this does not work, try another cartridge, you may have a bad one
Jun 18, 2009 | Brother Multi-Function Center MFC-240C...
Have a Canon PIXMA MP150, just recently replaced the Black ink cartridge. When I make copies I will press the black ink button for my black copies but the only light that come on is the color ink button. ...
the problem occurs mainly due to following reasons
clogged catridge head
*clean it using ammonia solvent
bad contact of catridge terminals
*clean the contacts of both catridge and catridge holder
Apr 13, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Changed blk ink cartridge and it says NO CARTRIDGE
see/search brother faQ:
http://www.brother-usa.com/FAQs/faq.aspx?Model=990&ProductGroup=5
Nov 09, 2007 | Brother Multi-Function Center MFC-3360c...
20 people viewed this question
jasbo
jasbo
