Question about Thomson RP5600 Clock Radio
I can't set the clock
Mine is an early version i think (RR520U). I unplugged it & it won't set clock. Lost the manual!
  • Anonymous Nov 30, 2008
    My father inlaw has this clock and he has moved so much that he can not find the manual for this clock and does not know how to set it. Could someone help please.
  • janebug Nov 30, 2008
    My father inlaw has this clock and he has moved so much that he can not find the manual and does not know how to set the clock part.Could someone help please.
I had the same problem. Looked here for help and found no solution, so dug through the attic till I found the manual. Thankfully I had kept the box. Here's the instructions from the manual:
Setting the Time
  1. Press the SET button, the ":" will flash on the display.
  2. Press REV or FWD to set the time.
  3. AM or PM icon will show beside the time.
TIP: No icon will be flashing if all selectors are set, if you see any icon flashing on display, press the SET button repeatedly to confirm everything is set correctly.
Posted on Dec 17, 2008
  • Anonymous Dec 17, 2008
    Actually, the solution I posted was for a slightly different model. For the RP5600, the procedure is a little bit different:
    Setting Clock
    1. Press SET repeatedly until a clock icon
    shows on the display.
    2. Press REV or FWD to set the clock
    time. The time decrements or
    increments will follow by a faster rate
    when you press and hold the buttons.
    AM or PM icon will also show beside
    the time.
    3. Press SET when finished.
RCA RP5600A
Posted on Jul 10, 2008
SOURCE:
How do I set the clock on my DMR-E75V. Also, where can I buy a manual. Lost mine when shifting.
Press functions,select to others,press enter,select set up,press enter,select others,press right arrow,select clock,press enter,change automatic to on,this will then hold the time.
Oct 18, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
Strausbourg Manor Wall Clock chime adjustment
It is normal for the average wall clock. Of course, this can be adjusted, but without watch/clockmaking knowledge it is impossible, because first you need to find out which part of the movement is causing early chiming - and there are plenty of them.
Super fine adjustment can be found only in top of the range clocks. Hundreds of hours of craftsmenship are spent to adjust and fine tune them. That's why they cost a fortune.
If you can not live with that early chiming, you have to bring your clock down to the watch/clock repair shop and ask for help. Be ready to pay quite a money, as this job takes the skill and a lot of time.
Rate me, please.
Jul 29, 2009 | Seiko Mantel Clock
I NEED THE INSTRUCTIONS ON HOW TO SET THE CLOCK ON MY MICROWAVE
To set the time just press CLOCK, then press CANCEL, then enter new time setting and press CLOCK again.
Apr 07, 2009 | Microwave Ovens
Daylight savings problem
I just figured out how to change mine. remove the battery from the bottom of the clock, keep plugged in, hold down the time zone button and press the set button either up or down which ever time zone you need, it is very simple hope this helps
Mar 08, 2009 | Emerson Smartset Clock Radio
Brookstone smart set alarm clock. It is about 20minutes ahead
I've noticed that manually setting the clock forward or back by any number of minutes, results in the same time offset being displayed after unplugging - plugging back in. So, if it's 9pm and you set if 5 minutes fast (9:05pm). Then unplug it and plug it back in 30 minutes later (9:30pm), the clock will maintain your setting of 5 minutes ahead of the actual time (9:35).
I like to set my clocks 5 minutes fast, just to make me always think I'm running a bit late (sure, maybe I'm a bit crazy). But this "sticky" manual setting is kind of a nice feature in my opinion. I'm wondering if it's not intentional?
Anyway, just manually set it back to the real time, and it sho
Feb 18, 2009 | Brookstone SmartSet Alarm Clock
Thomson RR520U Alarm Clock
Hi, Same here but I DO have the manual. Still took a lot of working out tho. Make sure you have decent batteries installed (Should be changed every year) so that the time will remain next power out.
If you send me your Email address I'll copy the relevent page for you. To rizla01 - at - yahoo.com
Sep 03, 2008 | Thomson RP5600 Clock Radio
Timex Clock Radio 308
www.timexaudio.com Select Support/Product Manuals from the menu and select your model from the list to get a .pdf version of the manual.
Jul 14, 2008 | Audio Players & Recorders
Lost instructions for Emerson
to change the alarm mode setting for alarm 1, hold alm1 setting button and press the alarm mode button until the day indicators show thedesired mode setting. weekday only,weekends only,or everday operation. release the alarm mode and alm 1 setting buttons and the display will return to correct time.
Dec 05, 2007 | Emerson CKS2237 Clock Radio
Needles flying around the clock
I have a mantle clock version and to set the clock to recognize the radio signal, I need to hold down both the ET and PT time zone buttons for a few seconds. The clock hands will then continue to move until they reset themselves to the correct time.
Nov 03, 2007 | La Crosse Radio Controlled Atomic Clock
Thomson RP5600 Clock Radio Logo
461 people viewed this question
Top Thomson Audio Players & Recorders Experts
Damen Wong
Damen Wong
Jerry Greenberg
Jerry Greenberg
Marvin
Marvin
Are you a Thomson Audio Player and Recorder Expert? Answer questions, earn points and help others
