Question about Dryers
No heat I have a relatively new (2 yrs) old whirlpool dryer, it is model number LEB6300PW8. The heating element seems to be out. No heat for cycles.
    Genius:
  • 1,122 Answers
I'll guess the lint filer is on the top?remove the back panel,check the fuse on the heater box,it is on the left side top,also check the heating element to see if any of the wire is broke,let me know what you find-mike
Posted on Apr 15, 2009
Is there something that would cause my heating element to go bad besides age? I have replaced my heating element 4 times in the last 2 yrs.
possible short in the wireing or a lint build up in vent and housing, blower unit etc CHECK UR THERMOSTATS WITH A METER ESPECIALLY THE THERMAL CUT OFF AND THE HI LIMIT AS WELL AS CYCLING
Jul 25, 2014 | Whirlpool Dryers
Roper electric dryer will not heat after replacing heating element and thermal fuse. what's wrong.
It doesn't necessarily mean the heating element is busted when the dryer stops heating and the thermal fuse is not part of the heating circuit, it is part of the motor circuit. The heating circuit is basically composed of the heating element, thermal cut-off, high-limit thermostat, cycling thermostat, and the motor centrifugal switch. The most common part that causes the dryer not to heat is the thermal cut-off and/or the high-limit thermostat. Verify this condition by bypassing the said components. Click on the link below for the detailed instructions. Indicate the exact model number of the dryer should you need further assistance.
Troubleshooting Whirlpool and Whirlpool-Made Electric Dryers Running But Not Heating
Feb 12, 2011 | Dryers
Does this model have two heating elements it get hot but not as hot as it should takes too long to dry cloths
An electric Estate dryer, manufactured by Whirlpool only has one heating element. If your dryer is STILL heating, but you are experiencing longer dry times and poor drying efficiency, the following link can give you some items to check before you assume there is a malfunction with your dryer:
http://www.fixya.com/support/r3578821-dryer_takes_too_long_to_dry
The element should cycle on and off as the dryer cycle runs. If it is glowing steady and really bright, its a good sign that you may have a clog somewhere. The number one cause of dryer heat related problems is poor exhaust ventilation. If not vented properly, a dryer will not dry efficiently, will take longer than required to dry, and will cause the heating circuits to overheat to the point of failure. The dryer will actually seem hotter as the heating circuits begin to overheat. This is also the source of many fire hazards if not resolved. Read through the link provided and review some of the potential causes.
If you have any questions, please post back and let me know. Please include your MODEL NUMBER (if it is different from the one you listed this question under), so I can determine how your dryer is configured. I hope you find this information is helpful.
NOTE: If you thoroughly check everything and still have problems let me know. The problem could be related to a thermostat beginning to fail.
Feb 15, 2010 | Estate TEDS740JQ Electric Dryer
The dryer is heating on air fluff.
Good Afternoon,
Is this dryer Electric or Gas?
Mar 27, 2009 | Whirlpool LER4634J Electric Dryer
Whirlpool dryer model LEB6000PQ0 its not heating up anymore''it starts it turns but the clothes dont dry its only 2 yrs old.
check your breaker first.A dryer will run on 110 but wont heat.if not breaker it could be your thermal fuse or element.the thermal fuse is located on element cage,unplug machine and test for continuity to your thermal cut off fuse which will be the top one on cage and check continuity to element.
Mar 08, 2009 | Whirlpool Dryers
Whirlpool dryer won't heat
Ended up replacing the solenoids and the burner ignited, flame stayed on. Problem appears to be solved. Thanks for your help and posting.
Jan 03, 2009 | Whirlpool LGR7646E Dryer
My dryer will run but won't heat
you either need a new heating element or limit switches
Nov 02, 2008 | Whirlpool LER8648P Electric Dryer
No heats from the dryer. the mechine is 4 yrs old.
First thing is to check the fuses. Often there is a separate line for the heating elements. If that fuse or circuit breaker is tripped there is no heat but the dryer will still turn.
There are heating elements behind the drum that may need to be replaced if broken. Also check thermostat control.
Sep 16, 2008 | Whirlpool Dryers
Newer Whirlpool Dryer Heat Element keeps breaking
  • clean out the dryer vent make sure hose behind dryer not pinched close ck the temp comeing out bac k dryer should be around 160
Mar 06, 2008 | Dryers
Dryers Logo
69 people viewed this question
Top Dryers Experts
