Question about Dryers
Error codes on electrolux ede 51760w tumble dryer
Item is brand new, and when set to run on a programe it works for about 2-4 min, and then stops and displays e50 with a audiable blep. the hand book gives no incling to what this could be , is it a over load as some settings need 3kg. or is it faulty?? is there a site that lists the error codes that can tell me if i need a engineer or if it is opreator error ??
  • tommy1664 Feb 16, 2008
    we have a zanussi zdc5370w, which recently started playing up with the same fault. have had an engineer out who has never heard of the fault. hope to have better news soon.have contacted zanussi on line & they redirect to local service centre but still no explanation of problem
  • Anonymous May 15, 2008
    got same problem tonight.
    zanussi zdc5370w
    Seems to be trying to pump up to the water resevoir - pump runs for a few seconds then stops then again a few times them e50 comes up
    anybody got a fix yet?
    Problem Solver:
  • 7 Answers
Make sure the water lines aren't reversed
Posted on Oct 16, 2008
  • 66 Answers
Is it a sensor dry is there damp washing in there when you are testing it or is it emty as this will tell the pcb to stop as it feels no mosture in the machine regards jason
Posted on Sep 14, 2007
SOURCE:
Brand new Electrolux EIED200QSW compact 220v dryer has error message "unstable mains supply". Also displays error message E04.
Hello Scott, thank you for your inquiry!
From the information you have provided your Electrolux dryer is displaying an error code of "E04". I see that this dryer is a new appliance from the manufacturer and I would recommend contacting them directly for further assistance. I hope that this information is helpful to you. -Matt
Feb 20, 2016 | Electrolux Dryers
Error code on a Frigidaire affinity dryer EDE, E4A
try going to google and put in the model # and the brand along with the error code.
Feb 24, 2015 | Kenmore Dryers
What e54 error code mean on an electrolux dryer
You have not specified Tumble dryer model so I can not say for certain that my answer is correct. Fault codes can sometimes vary depending on the platforms appliances because today some manufacturers release new models twice a year and thay have the absolutlly right to make changes and improve the efficiency of new appliances (also change fault codes).
E54 - means the motor is inoperational.
Could be:
  • Excessive wash load.
  • Voltage too low.
  • Motor/transmission system inoperative.
Dado
Aug 09, 2014 | Electrolux Dryers
E64 error code electrolux dryer
E64 - Heater thermostat
  • Thermostat faulty (replace heater unit)
  • Heater unit faulty
  • Wiring faulty
  • Electronic board faulty.
Dado
Electrolux EDC77550 drum dryer starts normally but stop after running couple of minutes.
If motor runs continuously with power applied, check for short circuit across motor relay (RL2), or L1 applied to motor relay output (J3-1) with cycle stopped. If motor does not start when Start key is pressed, check for open circuit between L1 and motor relay connection (J3-2). If no wiring problems found, replace Main Control Board.
Aug 14, 2012 | Electrolux Dryers
Dryers Logo
1,928 people viewed this question
Top Dryers Experts
Marvin
Marvin
Craig Butler
Craig Butler
