Question about 2wire (1000-400108-001) Router
Dilnk 655 router conected i can connect through wireless on laptop but the desk top which is wired in from router is saying not conected to internet the network magic program says router is not conected and repair connection fails all the time i am on line with laptop should i hjust push the reset button and try reinsatlling/ setting up network
  • router help Apr 14, 2009
    the desktop is vista home basic and the laptop is vista home premium
  • Simon Arrow May 11, 2010
    What operating system is your desktop
  • 30 Answers
Try reconneccting the lan cable from your router to your main desktop, take it out for about 5 seconds then put it back in, a light should turn on around the port but check with the on screen details. this should fix it, if not you may need to set up a lan connection through thte network thing
Posted on Apr 15, 2009
I have a D-link DIR-655 wireless router . I have two computers wired to the router and I run a wireless laptop. A couple time a day I lose connection and get a message thay says "local connection...
Make sure the power setting does not allow the ethernet card to be shut off. Also look through the other settings on the ethernet card properties menu. Some of those affect the stability of the connection. You access the setting through device manager.
Aug 04, 2017 | D-Link Xtreme N DIR-655 Wireless Router
My wireless connection , says "Limited or no conectivity" I have excellent signal strength. This occured when i plugged in a second lap top with cable. Now only port 2 works and wireless is restricted. I...
Usually this is caused because the security settings on the laptop or PC do not match what is setup on the wireless router. Login to the wireless router and look at what is setup for security, WPA, WPA_PSK, etc, also the passphrase, it is case sensitive. The setup on your laptop must match.
Jun 22, 2010 | D-Link DIR-655 Wireless Router
Trying a add another desk top to an existing Belkin wireless G router at home. Right now there's a desk top and laptop working off this router.Try several times and still can't connect to internet.
Make sure the Belkin wireless is the only device directly connecting to your internet service provider's router/modem. Usually that port is labelled "WAN" or even "Internet". The Belkin should have extra ports/jacks for WIRED connections, right? You then connect the PC into the other remaining ports/jacks on the Belkin (if they're wired) or just use the wireless for the laptop if the laptop has wireless. After getting the wireless going, though, you should lock it down by using WPA encryption key if possible.
Feb 24, 2010 | Belkin (F5D7230-4) Router (587009)
Loses internet connection constantly eliminated modem,pinpointed dir 655 wireless router
does it loose the conection constant over wireless, if so make sure u dont have two software wireless management programmes running try remove one of them and let windwows manage the conections for wireless
Nov 28, 2009 | D-Link Xtreme N DIR-655 Wireless Router
Have a windows xp desktop,and a apple macbook pro.what ROUTER
Buy a Wireless Router.
Select any of this following:
LinkSys
NETGEAR
Belkin
D-Link
Sep 23, 2009 | Apple AirPort Extreme Router
Although cable to desktop connects to internet, my router from desktop to laptop via router won't connect.
Desk top to internet is OK.
How about Destop through Router connection to Internet OK?
Assuming you want to connect wireless from Lap top to Network, need to configure correctly for wireless in Router.
If you connect Lap top to router by wire and it didn't work that mean your router is bad.
Jul 03, 2009 | Linksys WRT160N Wireless Router
My DIR 655 is able to conect to my laptop through wireless
Do you see wireless signal of your router from your Laptop? If not! make sure the Wi-Fi of your Laptop is activated for you to get online wirelessly.
Mar 07, 2009 | D-Link Xtreme N DIR-655 Wireless Router
Lan internet
the easiest way to setup internet on the laptop, is to go to control panel, and launch the network setup wizard. this will enable you to setup a new network, and scan for a local area network connection. this will also give you access to the troubleshooter. to solve any connection problems or issues, should there be any. If your using a wireless method. Your PC must also be able to transmit/receive wireless Signals. If hardwired you,ll have to use the network setup wizard, as this will auto determine I.P And any other DNS settings et,c.
Hope this Helps Mike @ compurepair.
Jan 14, 2009 | Toshiba Satellite Pro L300 Notebook
Can't get internet connection to my lap top.ps i have a desk top.
Is your laptop wireless adapter correctly configured? It may be set to only recieve certain types of signals (802.11b, when you may beed 802.11g etc), so check if the configuration of the laptop matches the configuration of the router.
To test if the laptop can get internet at all, try to get to a wired internet line (your wireless router may have some Ethernet ports on the back; laptops usually have Ethernet connectivity), just incase your laptop is set to block all internet signals coming in.
Hope this helps!
Dec 27, 2008 | Computers & Internet
LINKSYSBYCISCO WIRELESS ROUTER
this is what is happening, please get me solution email is nickesdad51@yahoo.com
Dec 08, 2008 | Linksys WRT160N Wireless Router
2wire (1000-400108-001) Router Logo
150 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
