Question about Lenovo 3000 N100 Notebook PC
Lenova laptop will not boot up even though the battery has now been charged. Have tried removing battery and using the power supply only, but it still will not boot.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 70 Answers
May be here can help you
Posted on Feb 10, 2010
IBM THINK PAD LENOVA embedded security chip
Sometimes (rarely) laptops need a bit of a kick to get them going! When confronted with this particular issue, I power off the laptop, disconnect the power supply, remove the battery and discharge any residual charge by pressing the power on switch for a couple of seconds.
Replace the battery, re-attach the power and reattempt the normal power on cycle. See it that kicks it into action!
Dec 28, 2013 | IBM ThinkPad Computers & Internet
Compaq nx6125 is not charging even though the adapter is working fine and the battery is fine too
Firstly, try the following steps to check the problem:
Turn off laptop.
Unplug AC power adapter.
Remove battery.
Replace AC power adapter.
Turn on laptop, allow OS to boot.
Once logged in to the machine, perform a normal shut down.
Replace battery.
Turn on laptop, allow OS to boot. The battery should once again be charging as normal.
Oct 25, 2012 | Computers & Internet
Sudden death Acer Laptop model 4702z when it was powered from AC
our laptop will always use the ac and charge the battery no need to remove this. If your laptop (boots up) displays the black screen with tex at the start you are able to save the laptop maby not the stored info boot up beeps let you no of any problems
May 26, 2010 | Computers & Internet
My Acer Aspire 9805 battery was replaced. For
It could be an AC adaptor issue.
It should boot when connected directly to the power outlet through the laptop adaptor. If it is not boot, then the adaptor might not be supplying the needed power to boot it up.
If it is possible, try to isolate the issue. Charge your new battery using another laptop. Then plug it in your laptop to see if it works. If it will work, then it is the AC adaptor of your laptop that is defective. If the charged battery still won't make the laptop boot, then there is something wrong with your laptop hardware. If could be a motherboard issue of your laptop.
Feb 23, 2010 | Acer Aspire 9805WKHi Notebook
D600 laptop boot problem
The D600 is plagued with power up problems for 2 reasons. First the connector on the motherboard to the power button is very sloppy and after awile it breaks contact. If you put pressure under the docking port area and press the power button it may start. The second is the memory slots. I know you said you replaced the memory, but it is the slot that is a problem. Remove the memory and put 1 chip in "A", then press down on the chip while trying to boot the laptop. If this works then get a peice of foam or pad and place it on the chip. When you put the cover back on it will push down on the chip and should boot. Repeat this process for "B".
The green light does signify a charged battery! This is also a possible reason for not booting. Remove the battery and try to boot with only the power supply. A shorted battery will stop the laptop from starting up.
If all of this does not help then remove the battery and the CD Rom, then try to boot. Finaly if nothing helps you should buy a new Laptop or a used one on E Bay. You could get a used D600 on E Bay that has a good motherboard for cheap money and use your drives and LCD. I work on D600 and D800 all the time. Let me know how you make out!
Dec 09, 2009 | Dell Computers & Internet
Dell Laptop Won't Boot Up
Don't take this as a definate answer, as I am only going on from what I've seen close friends do though I don't remove my Battery from my Laptop even though.
I do have some Electronic sexperience though very limited so my answer is You don't need a battery for a Laptop to boot and it doesn't matter if it doesn't hold a charge anymore,
Your problem I suspect is something else, meaning without proper (enough) input regarding what the Laptop does and or doesn't do, eg. starts the P.O.S.T then stops, 3 beeps or 1 , possibly none. Can you get into the BIOS setup? Maybe Windows starts loading and stops somewhere in the boot process.
If you need anymore assisatnce then feel free to ask.
Apr 09, 2009 | Computers & Internet
The laptop doesn't boot up always.
I would try the following:
1. Remove the battery completely. If the computer boots properly several times in a row, then the battery may be causing the power supply to do strange things.
2. If you have experience removing laptop components, try removing the hard drive. Because you say the screen goes black (I assume the system powers off) sometimes after the HP logo, I doubt its Windows or a software issue.
3. If HP has a diagnostic CD you can boot to, try that.
4. It may be the power supply acting up. If it charges the battery, and if you can boot to Windows with the battery, try getting a new power supply.
5. Otherwise, it may be the motherboard of the laptop.
Nov 28, 2008 | Computers & Internet
Will not boot up or turn on though it is getting power
The Charger could be bad, Try replacing that, or let charge, then try to turn on. The laptop might not boot with AC power. kinda stupid but maybe. If that doesn't work, the AC adapter is bad.
Jun 12, 2008 | Lenovo 3000 N100 0689 Notebook
Regarding battery problem/battery not charging
Hi Jasbir, Laptop batteries only have a set life span and if your battery does not hold charge the only solution is topurchase another battery. You will find the cheapest way to do this is to search the computer section of ebay [laptop assessories ]
and find the battery for your laptop model.
Regards mistyman
Nov 16, 2007 | Computers & Internet
Computers & Internet Logo
227 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
