Question about AEG D5701-4 Electric Double Oven
Can I fill a gap between the oven and Housing Unit with wood
We have just purchased a double oven AEG D5704-4 and there is a gap of about 15 mm between the top of the oven and the Housing Unit. Am I able to put a piece of wood in the gap to improve the appearance without impairing the functions of the oven.
  • AEG Master
  • 3,463 Answers
No problem at all to doing this.
Posted on Feb 24, 2010
I have a built in single oven do i need to change the wire when i put in a double oven
In order to answer this question we need to see the power consumption that you will have.
So in general if you use just one of the 2 ovens at any given time (not parallel usage), no need to change it.
But if you plan to use them both in parallel, you have to check the power consumption.
See the table attached: http://www.powerstream.com/Wire_Size.htm.
If you cave a cable of 0.2294 inc / 5.82676 mm (most usual case), this cable can carry up to 75Amp. So if you have a 110v power line, this is 75x110=8.2kw.
Check if the sum of your ovens are less than 8.2kw. If so, you are fine. If not, install a 2nd wire.
Feel free to ask more if you know exactly the power consumption of your ovens and the dimensions of your cable.
Jul 29, 2011 | AEG D5701-4 Electric Double Oven
How can I clean the inside of my oven door? D57014 AEG double oven.
Not knowing what kind of dirt or grime is on the inside of the oven, I would recommend using one of these Whirlpool products. They all work great and they have different ones for different cleaning needs. Cleaners
http://www.pricedrightparts.com/categories/Accessories/Cleaners/?sort=featured&page=1
Joey
Jun 11, 2011 | AEG D5701-4 Electric Double Oven
My AEG competence oven is making a loud buzzing noise coming from the top fan? The food tonight was either burnt or under cooked? The buzzing is also loud when switched off/cooling down? Any ideas please.
I would suspect that the problem is caused by the external cooling fan located under the outside cooker cabinet housing, which continues to operate as the oven is cooling down if it is built in, you will have to remove it from the oven housing to access the fan
Dec 12, 2010 | AEG D4101-4 Electric Double Oven
Broken glass AEG hob
If it is just the edge of the corner glass not a lot you can do if it is broken nearer the inside be very careful as the weight of pans can cause the break to spread.Check serial no. on base of hob body the first 2 digits are the year and 3rd digit is weeks in year.For example 92800055 that would be 2009 and 28th week equals july 2009.Any AEG unit has 2years full warranty.Check and you might be able to claim new glass.Hope this helped.
May 05, 2010 | AEG D2100-4 Electric Double Oven
Can i install a biult in oven staight into the housing or does it need some sort of heat resistant layer around the oven
Is the housing metal or wood? Metal would be better, but either is ok. The oven most likely has double insulated walls. Connect the power source and see if the outside gets hot. If it does, you can purchase a thin layer of heat and fire proof insulation.
Nov 03, 2009 | GE Profile JTP56 Electric Double Oven
AEG Competence D2160-1m2 (double oven)
You neede to replace the oven element.
This is located at the rear of the oven compartment behind a removeable cover.
Nov 29, 2008 | AEG D5701-4 Electric Double Oven
AEG COMPETENCE DOUBLE OVEN - 13 year old model
You can look on eBay to buy a used cooker and use it or spare parts
or if its better replace your own.
Jan 04, 2008 | Ovens
AEG D5701-4 Electric Double Oven Logo
134 people viewed this question
Top AEG Ovens Experts
ashburton
Sal DeAngelo
Samyfam
Samyfam
Are you an AEG Oven Expert? Answer questions, earn points and help others
