Question about Briggs & Stratton 6200 Watt Electric Start Generator 30242
Boat starter motor
When I turn on the starter the pinon moves up but does not turn the fly wheel. Is it the starter or the soliod?
How can I test them?
Thanks.
    Scholar:
  • 79 Answers
If the pinion moves up then the solenoid is fine, but if the starter does not spin then the starter motor is bad. Will need new starter.
Posted on May 07, 2009
How to test syarter motor using battery only outside of vehicle
our school in 1964 this was covered. Old school.
we now just hot wire it on car, and bam the answer ,ask.?
first is torque reaction, get the starter held down or it will want to walk away, and ? danger can happen. (picture shorting battery and acid flying to eyes)
1: starter held FAST.
2 then connect jumper cable Plus RED to out side large, solenoid lug. and battery , +
3 connect jumper cable black to battery neg lug.then other end to starter casing (mount)
4: jumper the outside lug to the dinky lug, the solenod engages
the pinon flies out and the starter pinion spins fast.
when done remove battery minus lug first.
end.
in the olden days, we fixed bad starters.
and this test , finished that job.
new brushes, and or solenoid and bam.
i just did this on a 68 bug last week.
Jun 27, 2014 | 1994 Geo Metro
1992 subaru legacy starter wont engage fully and makes a loud grinding noise
Sounds like it is not toughing 100% and making full gear contact with the fly-wheel. Replace starter or the misalignment can burr the flywheel causing rounding and subsequent damage to the device.
May 09, 2014 | 1992 Subaru Legacy
2002 Kia Rio, sometimes it starts up fine. More and more often it sounds like the starter motor is spinning, but its not engaging. So it's not even attempting to turn over the engine. It's not a clicking,...
very good post, few like it.
this is the starter free spinning
the solenoids job is the engage the teeth the fly wheel (ring gear)
the pinon shaft in starter is dirty, clean it (easy fix)
bad starter solenoid. get a new starter , most solenoids cost more.
your suspisons are dead on.
Oct 12, 2013 | 2002 Kia Rio
Sears Garden tractor does not start, how to i test to see if it is the starter or solenoid or what?
Try turning it over with the spark plug removed. If it now turns over the starter is weak and needs to be replaced. Also check the oil level. Too much oil will will lock it up.
Apr 14, 2013 | Craftsman Lawn Tractor Operators Manual...
Sierra 1500 wont turn over 350. locked up???
Have the battery tested for a dead cell. It may test at 12 volts but that doesn't mean there isn't a dead cell. Also, if the motor has good compression you probably shouldn't be able to turn it over by hand at the fly wheel. Maybe an old school motor with V belt, but not a newer motor with all those accessories attached to the front.
Mar 14, 2010 | GMC Sierra 1500 Cars & Trucks
I have a 2009 CRV, and a bout once every 10 start ups when I turn the key to start the car I will hear a squirting sound, and it sounds like it is coming from the ignition. When this happens I generally...
Without hearing it I would only be guessing, however I believe starter solenoid is a good guess.
When you turn the key the first position it applies power to the vehicles ignition coil and other operational components. The second position applies power to the starter solenoid which moves the starter gear against the fly wheel so the starter motor can crank the engine to start the combustion process. If the solenoid does not move the small gear against the big gear you will hear the starter motor running with no resistance producing a high pitch whine. Some of the gears could be missing on the fly wheel but it would not start unless you physically moved the vehicle forward to manually move the fly wheel.
Therefore, I would have the starter (starter and solenoid are usually together) checked or replaced. If you have some mechanical knowledge you could do it yourself with minimal tools. I believe turning the key back is not helping you. You just need to turn off the ignition and try to start it again. Sooner or later the solenoid will fail completely and not work at all. I would not want to be stranded so I would fix it soon but it could work intermittently for a while.
Jan 13, 2010 | 2003 Chevrolet Impala
THE FLY WHEEL WONT TURN WHEN I TRY TO START THE BIKE IS THE STRARTER CLUTCH BEHIND THE FLY WHEEL WORN. IS IT A BIG JOB TO REMOVE THE FLY WHEEL
If you hand-turn the flywheel, and it fails to turn, it might be that your engine is 'frozen". Remove the starter-motor and use a sizable flat-end screw-driver to try to turn the flywheel, just to be sure! The starter-motor is behind the flywheel, and if it is worn, you should get at least a 'crink' sound to indicate that the starter-motor pulls out and spins a bit. Yes, it is a big job removing the flywheel. You must have oil in the engine at all times!
Jul 11, 2009 | 1990 Suzuki DR 650 RS
1970 ford f100 390cu. The started motor gets locked up about one a week. I pull the starter motor and test it by hot wiring it directly to the battery and it works for about a week until it gets lockup...
You may need to shim the starter and I would have the starter tested.It is not uncommon to purchase a faulty elecrical part of any type from a part store.
Aug 26, 2008 | Ford F-100 Cars & Trucks
Briggs & Stratton 6200 Watt Electric Start Generator 30242 Logo
306 people viewed this question
Top Briggs & Stratton Electrical Supplies Experts
John Trevino
Falcon52
Level 1 Expert
Are you a Briggs & Stratton Electrical Supply Expert? Answer questions, earn points and help others
