Question about West Bend 41089 Bread & Dough Maker
Stems in bread machine fall out W B 41091
The stem that rotate the paddles in our bread machine are lose and fall out--can one replace them. It is a West Bend #41091. Please send me to the best place for parts.
Thanks
  • 273 Answers
You need a new pan. Go to www.westbend.com com. Click on the 'Support' tab. Click on 'Replacement parts. Click on 'Bread Machines'. Choose your bread machine model number.
Good luck from Detroit, MI.
Posted on Nov 08, 2011
How do I get the kneeding blade out of the bread machine?
soak the paddle in soapy water overnight with enough water to keep the paddle submerged. The next day wiggle it back and forth while holding the litte ears underneathe the pan. Move it up and down too. If it still doesn't break free go to you tube and type "how to remove a stuck bread machine paddle" have your husband do that move, but don' use more than one jug of water because the TBR15 pan is thin and can bend. Be sure your husband uses hot pads to hold the pan edges so he doesn't hurt his fingers. If that method doesn't work you will have to live with a stuck paddle or order a new pan assembly and paddle and then always remember to remove to soak your paddle after baking and remove it from
the stem, clean, and store. Daryl,,, from breadmachineshelp.com
Feb 26, 2013 | Toastmaster TBR15 Bread Maker
Do you still have knead blade for welbilt bread machine ABM6200
Hi and welcome to FixYa. Most every welbilt paddle / kneading blade that is in production can be found here:
http://www.shopwiki.com/welbilt+bread+machine
Another source is Nelson Appliance:
http://www.nelsonappliance.com/shop/categories/bread-maker-parts.asp?page=2
and
See if you can match your blade to the ones on the linked page. There are a frew places that have used paddles on line but would rather have you look at new stocks vs old stocks first. I realize that none of the paddle descriptions state specifically they are for the ABM6200 Model. The stem sizes are all the same so you should be able to find a correctly configured paddle. If you have the angled upright paddle you may have to look at breadman paddles to find a replacement.
Thanks for choosing FixYa,
Kelly
Dec 29, 2010 | Welbilt Kitchen Appliances - Others
The machine gets warm but the paddle doesn't turn.
Hi, The paddle should turn freely by hand with the bread pan out of the machine. Make sure the pan is inserted in the machine correctly. If the motor shaft turns but the paddle doesn't then the sealed bearing that the paddle rotates on has failed and is frozen so the paddle does not turn.. You may need a new bread pan. Hank
Jul 01, 2010 | Kenmore KTR2205SPR Bread Maker
B2300 Bread Machine: Good morning - Both paddles in the machine come of...
I am experiencing the same thing. I've spoken with a rep at 1-800-231-9786 and they said that if my machine was still under warranty they would replace the paddles and the pan. I purchased mine in 2007 and therefore my cost to replace the above would be $68.00 Cdn. That's getting close to purchasing a new machine. Does anyone have any ideas... wrap the rotating shafts with plumber's tape or anything else that might ensure the paddles will stay in place?
Linda
May 16, 2010 | Black & Decker B2300 Bread Machine
The driver that operates the kneading blade ( paddle) is falling out of the baking pan from the bottom. It appears a washer has disintegrated. Pieces seemed to fall apart when cleaning. any suggestions? I...
There is a sealed bearing at the bottom of the pan. This allows the paddle to rotate. The bearing has failed and is falling apart. This usually happens with age or use. Time for a new bread pan. If you are lucky you can find one on ebay. Sorry for the bad news....Hank
Dec 09, 2009 | Oster 5838 ExpressBake Bread Maker
Rotating shaft is jammed (won't move paddle)
Not quite sure what you mean about rotating shaft, but if you take the bread pan out of the machine and try to turn the paddle by hand and it doesn't move, then the sealed bearing in the bread pan is jammed or broken. Try filling it up with warm water and soaking it for a while. If it doesn't budge after a few tries then the bearing is broken and a new bread pan is needed. If on the other hand it does move, keep the pan out and start a kneading cycle. Look through the lid window and check to see if the motor shaft is turning. If not then the belt inside the machine is snapped, or fell off, or the motor is broken. Good Luck...Hank
Dec 01, 2009 | Black & Decker B2250 Bread Machine
West Bend bread maker -stems turn paddles are loss
check your manual.
If you don´t have one, check here:
http://manualfox.com/link/westbend.htm
They can get you any West Bend manual. Just send them a request.
Apr 11, 2009 | West Bend 41089 Bread & Dough Maker
Bread Machine B2300
this is the second rise period. it is ok, and at this time if you like, you can gently move the dough aside, and remove the paddles. Just remember to put a little oil on the exposed stem. This way, you can have bread without the huge holes from the paddles.
Nov 09, 2008 | Black & Decker B2300 Bread Machine
Metal stem broke!
you should be able to order the part from kitchenaid.com. while you replace the stem it might be a good idea to replace the hub, and the gear assembly in the planitary unit
Feb 12, 2008 | KitchenAid KSM90 Ultra Power Series Stand...
Paddle won't come out
I've had pretty good results with a crochet hook (use a metal one that can be run through your dishwasher). Insert the hook through the hole in the paddle and it should catch on the far side just enough to pull the paddle out of the loaf. Best to do it before it cools and the crust hardens, though.
Sep 23, 2006 | Black & Decker B1561 Bread Maker
Kitchen Appliances - Others Logo
134 people viewed this question
Top West Bend Kitchen Appliances - Others Experts
Jim Goldsmith
Jim Goldsmith
Irene Tulloch
Angel Joseph Jr.
Angel Joseph Jr.
Are you a West Bend Kitchen Appliances - Other Expert? Answer questions, earn points and help others
