Question about Directv (DWO2-10007) DTV Receiver / 100-Hours Video Recorder
DirectTv Recievers R15
I have 12 R15 Receivers and they keep going to sleep on me why is that. When I press the remote they come back up but always on a SM radio station. any answers why?
  • stamp2k1 Dec 01, 2008
    Same thing happens to me.... I hate the firmware also. It always messes up when I rewind or fastforward and stop to where I want to start watching.
    Genius:
  • 1,153 Answers
Let me get this straight, your receivers, after no type of action in about 5-15min they go to sleep. And return when pressing a button, correct?
Posted on Sep 14, 2007
SOURCE:
I have a Denon AVR-1600 receiver and just installed a DirectTV receiver, RC66RX remote. How do I program the DirectTV remote to run my Denon receiver?
I don't think the codes are available online?
although if you call the directTV 1 800 # they can give you the program code, really hope this helps?
Feb 27, 2015 | Denon AVR-1601 Receiver
Why can't I find the codes for DirectTV remote?
The DirectTV remote should have the option to
scan for the code check the instructions for
the automatic scan method most likely you
turn on the tv, dvd/vcr keep pressing button
until channel changes or set turns off which
ever button you use if you dont have the
instructions try this address
http://www.satex.com/directv/remote_codes.html
Nov 22, 2007 | Polaroid FLM-3232 Television
Tip
DirectTV RC65 Code Search
TIVO DirectTV RC65 Remote Control Programming by Code Search
Here are the steps to program your TIVO DirectTV RC65 remote control using Code Search:
  1. Turn on the TV or component.
  2. Slide the MODE switch to the TV, AV1 or AV2 position, as desired.
  3. Press and hold the MUTE and SELECT keys at the same time until the green light under the selected switch position flashes twice, then release both keys.
  4. Enter 9-9-1 followed by one of the following four digits: 0 for Sat box, 1 for TV, 2 for VCR/DVD/PVR, 3 for Stereo.
  5. Press PWR, or other functions (e.g. PLAY for VCR) you want to use.
  6. Point the remote at the TV or component and press CHAN UP. Repeatedly press CHAN UP until the TV or component turns off or performs the action you selected in step 5.
  7. Use the CHAN DOWN key to step back a code.
  8. When the TV or component turns off turns off or performs the action you selected in step 5, stop pressing the CHAN UP key. Then, press and release the SELECT key.
NOTE: If the light flashes 3 times before the TV or component responds, you've cycled through all codes and the code you need is not available.
If you know the 5-digit code you want to use, follow these steps.
To download and electronic copy of the DirectTV RC 65 manual, click here.
I hope that helps.
on Apr 02, 2010 | Tivo DirectTV Remote Remote Control
Viewsonic HDCP LCD & DirectTV HD receiver
connect it with HD RCA's....then youll have both HD and Working cable.
Nov 12, 2007 | Zenith HDSAT520 DirecTV DTV Receiver
Turn of the sleep mode on my Hopper
Hi there joe ibrahim, my name is Kimberly and I form part of the Social Media department with DISH. In order to disable the Inactivity Standby mode on the Hopper and Joey system, press 'Menu' on the remote, select 'Settings', then 'Diagnostics' and last, 'Updates'. From the Update Screen select Disable and be sure to select 'Save'. If you have additional questions feel free to reach me at: [email protected]
Kimberly Escobar
Social Media Representative
DISH L.L.C
Aug 17, 2013 | DISH Network ViP722 DTV Receiver /...
Is there a way to get a Denon rc1146 remote to work with a Denon 3310 receiver?
If you have already tried it and it doesn't work, than there is nothing else that you can do other than purchase the correct remote or just go to a universal remote. You would think that denon would keep their ir codes consistant through different models of recievers.
Jan 05, 2011 | Denon Audio Players & Recorders
I have DirectTV and a DirectTV remote RC64. I can
Here are all the codes I have
10171 10096 10187 10020 10381 10024 10030 11314 10186
here is how to set up without a code:
mode switch set to TV
PRESS & HOLD Mute and Select buttons at the same time UNTIL light blinks twice
enter 9911
keep pressing channel up until the channel changes on the tv
Maker sure to test the VOL button, if volume works
PUSH select key to set the code
THESE PROCEDURE CAN BE USED WHENEVER A REMOTE KEY IS NOT AVAILABLE.
CHANGE THE LAST NUMBER, 1 TO
2 for AUX1 (VCR and DVD)
3 for AUX2 (Audio Devices)
Mar 27, 2009 | Sylvania LC320SS8 32 in. LCD Television
Cannot program Emerson Jumbo Univ remote to DirectTV
Try this: Press and hold the TV Power button and the Dirctv/TIVO button at the same time. Hold both buttons down for about 4 seconds or until remote light stays red. Then press the channel up button until the tv turns off. You may press the button over 100 times. You need to go slow. When the TV turns off press the enter button (or select button).
Dec 27, 2008 | Tivo DirectTV Remote Remote Control
Deep Sleep
use the TV VIZEO remote to get out of RGB mode and go to hdmi2 and for me that ALWAYS works.  or whatever mode your cable is set to.  good luck
Sep 11, 2008 | Vizio P50HDTV10A 50 in. Plasma HDTV
Remote control code to program for directv receiver
i have a ton of codes i need your model# of your Directtv Receiver.
Feb 05, 2008 | RCA DRD430RG DirecTV DTV Receiver
Directv (DWO2-10007) DTV Receiver / 100-Hours Video Recorder Logo
288 people viewed this question
Top Directv Televison & Video Experts
David Ritko
David Ritko
Danny Crawford
Are you a Directv Televison and Video Expert? Answer questions, earn points and help others
