Question about GE GSS25KGMBB / GSS25KGMWW / GSS25KGMCC Side by Side Refrigerator
GE gss25kgma icemaker not working, can not get the green light to stop flashing, tray will not fill up with water, water is working. Have turned on and back on.
  • 242 Answers
It is either your electronic ice maker or the inlet valve , order the ice maker kit with your model number and it includes both parts. this will fix it.
Phil
Posted on Apr 14, 2009
I have a GE Profile fridge PSS25MGNAWW with an ice maker that is not working properly. The ice maker doesnt fill with water. If I turn the ice maker off then back on it will squirt water in for about...
HI this is just a test the icemaker runs when you first turn it on, its not suppose to fill up the tray, it will fill it when the icemaker reaches the correct temperature, if its not cold enough in the freezer it wont kick on, if its been sitting for several hours and still wont fill or make ice, you need a new icemaker. The new icemaker part # is WR30X10093
Sean
Mar 30, 2011 | GE Freezers
Ice tray not filling
Open your freezer and remove the ice bin. You will see the mechanism and the tray that fills with water to make the cubes. On the left there should be a rocker switch that turns the ice maker on and off with a green light that tells you if its on or not, under the ice cobe tray there is a small paddle that should move, give it a wiggle. On the right you will see the wire for the ice maker, make sure that it is plugged in. Once the icemaker starts working (little green light comes on) you should have ice within 24 hours. You may need to remove the ice bin and a
small plastic louvered cover above it.
Hope this helps.
Jun 23, 2010 | GE Profile PSW26P Stainless Steel Side by...
I have a GE, side by side GSS201EFAWW, The
turn switch off for 15 seconds, turn on, move flap under machine back and forth 3times, wait 6 miniuts, should rest. if no water, bad solinoid valve
May 08, 2010 | GE GSS20IEP Side by Side Refrigerator
GE Monogram icemaker is not working. The green light on the ice maker is blinking every second. I turn the ice maker off then turn on after a few second. The light stays green. After 10 minutes, I...
Your model uses a electronic ice maker. If the tray has srinking cubes and if you fill to top with tap water, let freeze and if it does not drop the ice the problem most ikely is the icemaker mode=> WR30X10093 The ice maker has a thermistor or thermostat built in and communicates with the circuit board inside to tell when it is time to cycle. You can try the water test and let me know but this is a typical failure with that type of ice maker. If this solve you ice maker problem please rate me. If not explain what you tried and we will try the second test. If need you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, Thanks, Sea Breeze
Feb 11, 2010 | GE Monogram ZISS480DRSS Stainless Steel
ICE MAKER BLINKING ON/OFF. TURN IT OFF & BACK
Icemaker is jamming. Stripper may be bent where the ejector hangs up advise replacing icemaker
Feb 08, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Fridge icemaker is not working - Help!!
I installed a new icemaker (cost approx $100) and its making ice. Very easy to install yourself (remove 4 screws holding part below icemaker, then unplug icemaker, and unscrew the 2 screws holding it in place.). Good luck-
Jan 28, 2010 | GE Profile Arctica 25.4 Cubic Feet...
Ice maker water line doesnt shut off
If the icemaker did not stop right in the spot where the water fills the tray, without completing the cycle, you have an icemaker problem, but that is highly unlikely. More likely is that the water fill valve (the part right where the water line hooks onto the refrigerator) will have to be replaced.
Jul 07, 2009 | GE Profile PSW26P Stainless Steel Side by...
"service" light flashes but will stop for awhile when the icemaker is turned off and back on again.
if the problem occurs when the icemaker is working?lift up the overflow gizmo over the tray that should shut the icemaker off for as long as you want. is this a newappliance? if it is check to see that the icemaker is not connected to hot water which could the light to flash good luck
Feb 16, 2009 | Sub-Zero 690 Side by Side Refrigerator
KSRA25IL ice cube tray won't fill
The fill tube is probably frozen. Its in the roof of the freezer. turn off the freezer and heat the roof of the freezer with a hair dryer, being careful not to get it too hot,and it should thaw and work again. If you can put the food elsewhere for a day, just turning it off with the door open should work also.
Nov 11, 2008 | KitchenAid KSRS25IL Side by Side...
GE GSS25KGMBB / GSS25KGMWW / GSS25KGMCC Side by Side Refrigerator Logo
294 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
