Question about Rheem 40 Gallon FVR NATGAS Low WATER HEATER 6YR 22V40SF
No Hot Water in morning
Rheem - 50 Gal Model # 21dv50
No leaks
Less than 10 years old
Can't tell if pilot went out / cover screwed in place
First time this ever occurred
Mike Ruggiero
    President:
  • 949 Answers
Remove the cover then the access cover, then you can see inside,
the pilot light is probably out.
If out turn the gas off, then get a long match, grill lighter,or piece of paper ready to light, you should be able to see the little thin
gas line that runs inside the tank and see where it connects to,that is where you need to light, now that you see where to light, turn gas knob to pilot, and press down and at the same time light the pilot.
( blow into the pilot area before putting match inside to make sure no gas has built up inside) Hold down the knob for a minute then release, if pilot goes out try again and hold down longer, if you hold it for 3mins and it does not stay lite, the thermocouple is bad and you will have to replace it.
Posted on Apr 14, 2009
How do i fix my Rheem 30 gal model 71 308 from leaking?
BEWARE!!!! LEAKAGE IN WATER HEATER MAY BE EXTREMELY HAZARD DELIVERING!! STOP USING IT AND TURN IT OFF FROM MAINS, CALL AUTHORIZED SERVICE CENTER IMMEDIATELY AND DON'T USE IT BEFORE THAT!!!!
Apr 26, 2014 | Rheem 30 GAL ELEC SHORT Water Heater 6YR...
Where can i get a 21dv50 water heater to buy
21dv50 is discontinued. This is ordinary tank-type 50 gallon gas water heater.
Amazon sells 50 gallon 22V50F1 Rheem water heater for $420 with free shipping ... but who carries the warranty?
Frankly you can get in-store returns, and buy same quality gas water heater at local box store since Rheem makes GE water heaters at home Depot.
Other brands are equally good, as AO Smith makes Kenmore water heaters at Sears and Whirlpool at Lowes.
I prefer the AO Smith because maintenance is easier.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Sep 17, 2012 | Rheem 40 Gallon FVR NATGAS Low WATER...
My Rheemglas fury 21DV50 hot water heater pilot goes out about every 2 days for the last week and 1/2. It will light and I'll be able to have hot showers but doesn't last more than about 2 days. Is it the...
It could be a thermocouple but first take the whole pilot assembly out and disassemble it. Clean it very good (compressed air is ok) especially the orifice inside the pilot horn. You may just have a weak pilot. If the flame is in good contact with the thermocouple and problem still exist, then change the thermocouple. I believe in doing the free things first.
Jan 28, 2011 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
My 50 gal elec water heater model #81v52d only stay hot during a shower for 10 min how do I make the water hotter is there a dial on it?
Remove the four screws that hold the covers on the side of the water heater and carefully spread the insulation apart to see the thermostat,reset button and heating elements. The thermostat will have a adjusting screw on it that you can turn with a small blade screwdriver.There is a arrow pointing to temperature setting that you can adjust by turning the screw clockwise to increase the temperature. They normally come from the factory set at 120 degrees so you can turn it up to 135-140 and see if that helps.
Thank you and I hope this helps you.
Jan 20, 2011 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
I have a rheem fury 50gal gas water heater that will not stay on. I have replaced the thermo couple, it did lite but then went out.
I would like to know how old this heater is. This information can be found on either model or serial numbers.It won't appear obvious but last six numbers will tell you. You have already changed thermo-couple so I would check to see that it's properly centered in pilot flame.When you light it hold pilot button down for two-three mins.while watching thermo-couple.It should be a nice cherry red. If it is and pilot goes out after you release button then you either have another bad thermo-couple or gas valve is bad.If it does not get cherry red at least on tip then you need to reposition thermo-couple and try again. If gas valve is bad and heater is less then six years old valve will be covered under warrenty,however labor won't typically be covered unless you have extened service contract.Hope this helps.Thanks.
Nov 03, 2010 | Rheem 50 Gallon FVR NATGAS Water Heater...
Electric Water Heater Using Too Much Electric.
Maybe you want to think about getting a tankless heater.The gad unit works real good.But the electric water heater i want to think you should check the thermostate.Maybe it is struck and not cutting off every time.
Mar 13, 2009 | Rheem 30 GAL ELEC SHORT Water Heater 6YR...
Rheem 50 Gal Hot Water Heater will not stay lit
On the back of the gas valve (where you turn the temp up) there is a stem that actually goes into the tank that senses the temprature of the water it could be dirty or buried in sediment depending on how old the tank is, or just bad. if the tank is over 10 years old i wouldn't bother replacing the gas valve, the tank is probably not far behind. A new valve will run around $100.00 maybe a little less. You wont find it at menards or home depot in stock but they may be able to order it for you. Menards sells rheem products or try you local plumbing supply house. REMEMBER TO RELIEVE THE PRESSURE ON THE TANK BEFORE YOU WORK ON IT. IF YOU CHANGE THE VALVE DRAIN IT FIRST!
Feb 10, 2009 | Rheem 50 Gallon FVR NATGAS Water Heater...
Rheem 40 Gallon FVR NATGAS Low WATER HEATER 6YR 22V40SF Logo
458 people viewed this question
Top Rheem Water Heaters Experts
Donni Steen
gizmonix
Level 1 Expert
Jim Goldsmith
Jim Goldsmith
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
