Question about Refrigerators
I need a wiring diagram for a Defy upright freezer Model F 350 wiring connections to PC board thermostat
  • 1 more comment
  • JCJC Feb 20, 2013
    So where is the solution??
  • Anonymous Mar 20, 2014
    I have a Upright Kelv Freezer FN360J.It does not defrost. I would like to obtain a wiring diagram please. Can anybody help
  • Anonymous Mar 25, 2014
    PC board must be replaced. Need repair / service manual to download
Defy F350 uprigt freezer ices on evap coil righthand red led are displayed. Can the heater or ice sensor be faulty.Thanks Marius
Posted on Jun 28, 2009
How do i connect the wires on a westinhouse Freestyle upright freezer thermostat...ther is a five pin plug and it has the green earth wire connected but the ...blue .. brown..black..orange and red are not...
I'd be looking for a wiring diagram on the back of the unit or inside the bottom rear cover. The wire colors and numbers on the thermostat would guide on where to connect what
Feb 04, 2015 | Freezers
Defy f640 wiring diagram
Defy F640 freezer fan keeps switching on and off and does not cool.
Jan 19, 2014 | Freezers
Defy fridge f640 wiring diagram faulty compressor or thermostat
Hi my name is jp. Got a defy f640 the freezer not working. Trips power. Wires been removed at back of the compressor. Need to know where the wires need to go
Dec 22, 2012 | Refrigerators
Wiring Diagram Defy 521 Electric Stove
NEED A WIRING DIAGRAM OF A DEFY 521 ELECTRICAL STOVE
Sep 29, 2012 | Kitchen Ranges
I need to install condenser fan motor on my newly bought freezer to protect it from our upcoming very hot summer. As I've heard that installing such a fan will prolong the life of the compressor. So, I...
One wire must go to Neutral or the black wire where it comes off the main power lead and connects to the unit wiring, The Live wire should be picked up from the thermostat terminal that powers the freezer compressor. In this way the fan will only run when the compressor is operating. If the fan motor is a large one , more than 200 watts, you will need to run it through a relay to prevent overloading the thermostat contacts.
May 10, 2011 | Microwave Ovens
I need to replace my thermostat on my ge chest freezer model #fcm7sudww, I lost the wiring diagram and I need help to rewire. Thanks
Wiring diagram of the chest freezer turned into chest fridge. The junction box is not required if all connections are made inside the fridge service compartment. Active (A) connection passes via latching relay terminals
inside the thermostat.
Additional information can find HERE.
Hope helps; tell us news.
Aug 05, 2010 | General Electric Chest Freezer FCM5SU
Freezer wont shut off and goes to -10f regardless the thermostat setting thermostat is on the outside door(digital)
I'd say the freezer thermostat is stuck closed. You will have to verify this with a meter. The wiring diagram is on the back of most freezers. Good luck.
Jul 13, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Freezer will not turn on
Sounds like the sensor circuit may be open. Here is the problem, either it has a board that's bad or the sensor is out. Ohm the sensor circuit and record the temp the box is at in refrigerator and freezer. then the ohm reading. Contact manufacturer or representative of manufacturer, and ask what the sensor should read at the temps you have.
Generally if you get a reading on the sensor circut the sensor is ok, and the board is out BUT not always. this is why you need the temperature and the ohm readings. Sometimes the wire diagram has a legend with these reading on it. Look all around the underneath and behind sections for an envelope containing the wire diagram.
Apr 16, 2009 | Freezers
Frigidaire Upright freezer with Beeping Display
First make sure you have a good 9v battery installed. If it is ok then the problem will probably be in the display board or the wiring connectors between the boards. CE is communication error. If your model has the electronic tempature control instead of mechanical thermostat the problem could be in there. My bet is a bad connection at display board.
Sep 05, 2007 | Kenmore 20.6 cu. ft. Upright Freezer 24092
Refrigerators Logo
1,072 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
