Question about Hoover SteamVac F5914-900 SpinScrub Upright Vacuum
Tools how to switch from floor to tools.
    President:
  • 1,673 Answers
On the front of the dirty water tank is a block that you pull out(don't forget to put it back in when done, or you won't have any suction), Remove recovery tank front panel
(F) by sliding it straight up.
4. Replace panel with converter (G).
Slide converter halfway down opening
until it is firmly in place.
5. Before connecting tube (H) to
cleaner, make sure black tabs are
extended by pulling tan collar
toward tube.
Open door on hood labeled “Stair/
upholstery Cleaning Connection”.
Press round solution tube connector
onto round projection inside door.
Press connector collar down firmly
to ensure that it is fully connected.
The tank replaces in a hingelike
manner. Position front of lid
under tabs (I) on front of tank. Rotate
lid down onto tank.
Make sure lid is secure on all
sides before cleaning.
For full suction, it is important that
the recovery tank lid is properly
secured before cleaning.
Reverse procedure to remove
hose and solution tube.
Raise carpet cleaner handle to
upright position.
Posted on Jan 15, 2008
SOURCE:
Dyson D35 floor tool is scratching the floor
look for a sharp object stuck in brushes ,in casing or casing damage
Sep 25, 2016 | Dyson DC 35 Multi Floor Cordless Vacuum...
How do I switch from tools to flooe on my hoover steam vac ? it is green next to tools do I need to change iit to floors ro clean the carpet?
Hi Cherie! To switch from tools back to floor you only need to disassemble the hose from the cleaner. Be sure to close the circular hose port on the nozzle. Hope this helps!
Jun 11, 2014 | Hoover Steam Vac Dual V w/ SpinScrub...
How do I switch from tools to floor on my hoover steam vac ? it is green next to tools do I need to change iit to floors ro clean the carpet?
Hi! To switch from tools back to floor you only need to disassemble the hose from the cleaner. Be sure to close the circular hose port on the nozzle. Hope this helps!
Can't put the floor cleaning attachment on.
Hi Donna! Attaching the bare floor tool is quite easy. Hold the bare floor tool in your hands with the squeegee blade closest to you. Then hook the front of the bare floor tool onto the clear lip at the floor level and swing the tool underneath your machine until it snaps.
Aug 30, 2013 | Bissell 9500 ProHeat 2X CleanShot Upright...
Is there a switch to turn-off the tools so that
On the Hoover U6311-900 there is no switch that turns off the suction to the tool hose. That hose is attached to the head of the vacuum on the side via a spring loaded "door". Just twist the hose to remove it, the door will close and you will have full suction again.
Apr 06, 2010 | Hoover U6311-930 Power Drive Bagged...
Can't switch cleaning mode from tool to floor
there's a mechanism inside the steamvac that should switch the mode automatically when you press the handle release and pull the handle down for the vacuum mode... it's automatic! it took so long to figure out because I kept looking for the switch when it was upright and didn't look as I was using it.
Aug 25, 2009 | Vacuums
My DC21 Floor tools keeps shutting off on its own.
You say the floor tool keeps shutting off. The key question is: what do you have to do to get it going again? There are electrical connections at both ends of the hose, and poor contact there can cause the tool to work intermittently - in which case you will find that just moving the hose will cause the tool to switch on and off. You can't do much about these connections other than have a look to see if they appear damaged. Make sure the hose is fully attached at both ends. If this doesn't help, please post again giving more details.
Apr 13, 2009 | Dyson DC21 All Floors Stowaway HEPA...
How to switch from tools to floor on hoover widepath 6500? no manual
THERE SHOULD BE A KNOB ON THE SIDE THAT YOU TURN IT WILL SAY FLOOR AND HOSE TURN IT TO FLOOR
Apr 10, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
I am not getting any water to come out of the floor part or tools
Hi There!
Here is a PDF link for a Bissell Service Center Repair Guide. Hope it helps! Juli ;)
newzealand.bissell.com/images/IncludeContent/Service_Center_Help/Upright_Deep_Cleaner_Repair_Guide.pdf
Nov 27, 2008 | Bissell 7920 ProHeat Pro-Tech Upright...
Bissell Proheat upright dirt lifter 12amp
on the vacuum there is a switch one for the hand held attatchment and one for the floor you have to switch from hand held to floor
Sep 24, 2008 | Bissell 1698 PowerSteamer ProHeat Upright...
Hoover SteamVac F5914-900 SpinScrub Upright Vacuum Logo
359 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Kirk Thompson
Level 1 Expert
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
