Question about Chaintech 9LIF7 i845G Motherboard
All support drivers card network ...sound..etc
Good evening i want drivers support for mainboard model:07e8h shipset intel:i845g ------------------------- Processors Map ------------------------------------------------------------------------------------ Number of processors 1 Number of threads 1 Processor 0 -- Core 0 -- Thread 0 Processors Information ------------------------------------------------------------------------------------ Processor 1 (ID = 0) Number of cores 1 (max 1) Number of threads 1 (max 1) Name Intel Pentium 4 Codename Northwood Specification Intel(R) Pentium(R) 4 CPU 2.00GHz Package Socket 478 mPGA (platform ID = 2h) CPUID F.2.4 Extended CPUID F.2 Brand ID 9 Core Stepping B0 Technology 0.13 um Core Speed 1994.2 MHz (20.0 x 99.7 MHz) Rated Bus speed 398.8 MHz Stock frequency 2000 MHz Instructions sets MMX, SSE, SSE2 L1 Data cache 8 KBytes, 4-way set associative, 64-byte line size Trace cache 12 Kuops, 8-way set associative L2 cache 512 KBytes, 8-way set associative, 64-byte line size FID/VID Control no Features Thread dumps ------------------------------------------------------------------------------------ CPU Thread 0 APIC ID 0 Topology Processor ID 0, Core ID 0, Thread ID 0 Type 01001001h Max CPUID level 00000002h Max CPUID ext. level 80000004h Function eax ebx ecx edx 0x00000000 0x00000002 0x756E6547 0x6C65746E 0x49656E69 0x00000001 0x00000F24 0x00010809 0x00000000 0x3FEBFBFF 0x00000002 0x665B5001 0x00000000 0x00000000 0x007B7040 0x80000000 0x80000004 0x00000000 0x00000000 0x00000000 0x80000001 0x00000000 0x00000000 0x00000000 0x00000000 0x80000002 0x20202020 0x20202020 0x20202020 0x6E492020 0x80000003 0x286C6574 0x50202952 0x69746E65 0x52286D75 0x80000004 0x20342029 0x20555043 0x30302E32 0x007A4847 Cache descriptor Level 1 D 8 KB 1 threads Cache descriptor Level 1 T 12 KB 1 threads Cache descriptor Level 2 U 512 KB 1 threads MSR 0x0000001B edx = 0x00000000 eax = 0xFEE00900 MSR 0x00000017 edx = 0x000A0000 eax = 0x00000000 MSR 0x0000002C edx = 0x00000000 eax = 0x14100014 MSR 0x000001A0 edx = 0x00000000 eax = 0x00000089 Chipset ------------------------------------------------------------------------------ Northbridge Intel i845G rev. A1 Southbridge Intel 82801DB (ICH4) rev. 01 Memory Type DDR Memory Size 256 MBytes Memory Frequency 132.9 MHz (3:4) CAS# 2.5 RAS# to CAS# 3 RAS# Precharge 3 Cycle Time (tRAS) 6 DRAM Idle Timer 16 Memory SPD ------------------------------------------------------------------------------ DIMM #1 General Memory type DDR Manufacturer (ID) Micron Technology (2CFFFFFFFFFFFFFF) Size 256 MBytes Max bandwidth PC2100 (133 MHz) Part number 8VDDT3264AG-265B1 Serial number 14127BC4 Manufacturing date Week 38/Year 02 Attributes Number of banks 1 Data width 64 bits Correction None Registered no Buffered no Nominal Voltage 2.50 Volts EPP no XMP no Timings table Frequency (MHz) 100 133 CAS# 2.0 2.5 RAS# to CAS# delay 2 3 RAS# Precharge 2 3 TRAS 5 6 Dump Module #1 0 1 2 3 4 5 6 7 8 9 A B C D E F 00 80 08 07 0D 0A 01 40 00 04 75 75 00 82 08 00 01 10 0E 04 0C 01 02 20 C0 A0 75 00 00 50 3C 50 2D 40 20 A0 A0 50 50 00 00 00 00 00 41 4B 34 32 75 00 00 30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 06 40 2C FF FF FF FF FF FF FF 01 38 56 44 44 54 33 32 50 36 34 41 47 2D 32 36 35 42 31 20 01 00 02 26 14 60 12 7B C4 00 00 00 00 00 00 00 00 00 00 00 00 00 70 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 80 43 50 51 31 15 36 53 32 39 4B 51 36 5A 52 31 33 90 4C 20 01 43 FF FF FF FF FF FF FF FF FF FF FF FF A0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF Monitoring ------------------------------------------------------------------------------ Mainboard Model 07E8h (0x14C - 0x24880) LPCIO ----------------------------------------------------- Vendor SMSC Vendor ID 0x55 Chip ID 0x6D Config Mode I/O address 0x2E Dump config mode register space, LDN = 0xA 0 1 2 3 4 5 6 7 8 9 A B C D E F 00 00 00 00 00 00 00 00 0A 00 00 00 00 00 00 00 00 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 20 6D 01 09 00 04 00 2E 00 00 00 00 00 00 00 00 00 30 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 60 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 70 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Hardware monitor ----------------------------------------------------- Analog Device ADM1027 hardware monitor Voltage sensor 1 1.48 Volts [0x7E] (CPU VCORE) Voltage sensor 2 3.28 Volts [0xBF] (ATX +3.3V) Voltage sensor 3 5.12 Volts [0xC5] (ATX +5V) Voltage sensor 4 12.05 Volts [0xC0] (ATX +12V) Temperature sensor 0 37°C (98°F) [0x25] (CPU) Temperature sensor 1 0°C (30°F) [0xFFFFFFFF] (AUX) Temperature sensor 2 33°C (91°F) [0x21] (System) Fan sensor 0 -2147483648 RPM [0x0] (FANIN0) Fan sensor 2 -2147483648 RPM [0x0] (FANIN2) Dump hardware monitor SMBus Register space, base address = 0x0FC00 SMBus request at channel 0x0, address 0x2E 0 1 2 3 4 5 6 7 8 9 A B C D E F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 20 00 7E BF C5 C0 80 21 25 00 00 FF FF 00 00 00 00 30 00 FF 00 00 00 00 00 00 00 00 00 00 00 27 41 60 40 05 91 40 0E 00 FF 00 FF 00 FF 00 FF 00 FF 81 7F 50 81 7F 81 7F FF FF FF FF FF FF FF FF 40 62 40 07 60 C4 57 08 08 00 80 00 5A 5A 38 64 64 4B 44 40 00 70 00 00 02 00 FF FD 42 53 F1 00 00 55 00 00 00 00 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 90 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 PCI Device List ------------------------------------------------------------------------------ Host Bridge bus 0 (0x00), device 0 (0x00), function 0 (0x00) Common header Vendor ID 0x8086 Model ID 0x2560 Revision ID 0x01 PI 0x00 SubClass 0x00 BaseClass 0x06 Cache Line 0x00 Latency 0x00 Header 0x00 PCI header Address 0 (memory) 0xF8000000 Subvendor ID 0x0000 Subsystem ID 0x0000 Int. Line 0x00 Int. Pin 0x00 Capabilities Vendor Dependant Capability Offset E4h Dump 0 1 2 3 4 5 6 7 8 9 A B C D E F 00 86 80 60 25 06 01 90 20 01 00 00 06 00 00 00 00 10 08 00 00 F8 00 00 00 00 00 00 00 00 00 00 00 00 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 30 00 00 00 00 E4 00 00 00 00 00 00 00 00 00 00 00 40 3C 03 00 00 41 20 10 20 04 01 00 00 1B 08 10 00 50 00 00 40 00 00 00 00 01 2A 1A 02 00 45 2A 47 2C 60 08 08 08 08 00 00 00 00 00 00 00 00 00 00 00 00 70 02 00 00 00 00 00 00 00 05 84 41 2B 71 C1 00 20 80 3D 00 AF 00 AD 00 00 00 01 00 00 00 00 00 00 00 90 10 11 11 11 11 33 33 00 45 04 00 00 00 0A B8 00 A0 02 00 20 00 17 02 00 1F 00 00 00 00 00 00 00 00 B0 00 00 00 00 30 00 00 00 00 00 00 00 20 10 00 00 C0 44 40 30 11 00 00 0C 0A 00 00 00 00 00 00 00 00 D0 02 28 04 0E 0B 0D 00 10 00 00 11 B3 00 00 01 00 E0 00 00 00 00 09 00 05 01 00 00 00 00 00 00 00 00 F0 38 0E 00 00 74 F8 00 00 40 0F 00 00 04 00 00 00 VGA Controller bus 0 (0x00), device 2 (0x02), function 0 (0x00) Common header Vendor ID 0x8086 Model ID 0x2562 Revision ID 0x01 PI 0x00 SubClass 0x00 BaseClass 0x03 Cache Line 0x00 Latency 0x00 Header 0x00 PCI header Address 0 (memory) 0xF0000000 Address 1 (memory) 0xFC400000 Subvendor ID 0x0E11 Subsystem ID 0x00B8 Int. Line 0x10 Int. Pin 0x01 Capabilities Power Management Capability Offset D0h Version 1.0 Dump 0 1 2 3 4 5 6 7 8 9 A B C D E F 00 86 80 62 25 07 00 90 00 01 00 00 03 00 00 00 00 10 08 00 00 F0 00 00 40 FC 00 00 00 00 00 00 00 00 20 00 00 00 00 00 00 00 00 00 00 00 00 11 0E B8 00 30 00 00 00 00 D0 00 00 00 00 00 00 00 10 01 00 00 40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 60 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 70 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 90 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 D0 01 00 21 00 00 00 00 00 00 00 00 00 00 00 00 00 E0 08 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 F0 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 USB Controller (UHCI) bus 0 (0x00), device 29 (0x1D), function 0 (0x00) Common header Vendor ID 0x8086 Model ID 0x24C2 Revision ID 0x01 PI 0x00 SubClass 0x03 BaseClass 0x0C Cache Line 0x00 Latency 0x00 Header 0x80 PCI header Address 4 (port) 0x00002440 Subvendor ID 0x0E11 Subsystem ID 0x00B8 Int. Line 0x10 Int. Pin 0x01 Dump 0 1 2 3 4 5 6 7 8 9 A B C D E F 00 86 80 C2 24 05 00 80 02 01 00 03 0C 00 00 80 00 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 20 41 24 00 00 00 00 00 00 00 00 00 00 11 0E B8 00 30 00 00 00 00 00 00 00 00 00 00 00 00 10 01 00 00 40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 60 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 70 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 90 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 C0 00 2F 00 00 03 00 00 00 00 00 00 00 00 00 00 00 D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 F0 00 00 00 00 00 00 00 00 60 0F 00 00 00 00 00 00 USB Controller (UHCI) bus 0 (0x00), device 29 (0x1D), function 1 (0x01) Common header Vendor ID 0x8086 Model ID 0x24C4 Revision ID 0x01 PI 0x00 SubClass 0x03 BaseClass 0x0C Cache Line 0x00 Latency 0x00 Header 0x00 PCI header Address 4 (port) 0x00002460 Subvendor ID 0x0E11 Subsystem ID 0x00B8 Int. Line 0x13 Int. Pin 0x02 Dump 0 1 2 3 4 5 6 7 8 9 A B C D E F 00 86 80 C4 24 05 00 80 02 01 00 03 0C 00 00 00 00 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 20 61 24 00 00 00 00 00 00 00 00 00 00 11 0E B8 00 30 00 00 00 00 00 00 00 00 00 00 00 00 13 02 00 00 40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 60 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 70 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 90 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 C0 00 2F 00 00 03 00 00 00 00 00 00 00 00 00 00 00 D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 F0 00 00 00 00 00 00 00 00 60 0F 00 00 00 00 00 00 USB 2.0 Controller (EHCI) bus 0 (0x00), device 29 (0x1D), function 7 (0x07) Common header Vendor ID 0x8086 Model ID 0x24CD Revision ID 0x01 PI 0x20 SubClass 0x03 BaseClass 0x0C Cache Line 0x00 Latency 0x00 Header 0x00 PCI header Address 0 (memory) 0xFC480000 Subvendor ID 0x0E11 Subsystem ID 0x00B8 Int. Line 0x17 Int. Pin 0x04 Capabilities Power Management Capability Offset 50h Version 1.1 Debug Port Capability Offset 58h Dump 0 1 2 3 4 5 6 7 8 9 A B C D E F 00 86 80 CD 24 06 01 90 02 01 20 03 0C 00 00 00 00 10 00 00 48 FC 00 00 00 00 00 00 00 00 00 00 00 00 20 00 00 00 00 00 00 00 00 00 00 00 00 11 0E B8 00 30 00 00 00 00 50 00 00 00 00 00 00 00 17 04 00 00 40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 50 01 58 C2 C9 00 00 00 00 0A 00 80 20 00 00 00 00 60 20 20 7F 00 00 00 00 00 01 00 00 00 00 00 00 C0 70 00 00 D5 0F 00 00 00 00 00 00 00 00 00 00 00 00 80 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 90 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 D0 00 00 00 00 00 00 00 00 00 00 00 00 10 00 3F 00 E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 F0 78 BF 1F 00 88 83 00 00 60 0F 00 00 06 00 00 00 PCI to PCI Bridge bus 0 (0x00), device 30 (0x1E), function 0 (0x00) Common header Vendor ID 0x8086 Model ID 0x244E Revision ID 0x81 PI 0x00 SubClass 0x04 BaseClass 0x06 Cache Line 0x00 Latency 0x00 Header 0x01 PCI header Primary bus 0x00 Secondary bus 0x05 Int. Line 0x00 Int. Pin 0x00 Dump 0 1 2 3 4 5 6 7 8 9 A B C D E F 00 86 80 4E 24 07 01 80 80 81 00 04 06 00 00 01 00 10 00 00 00 00 00 00 00 00 00 05 05 40 10 10 80 22 20 50 FC 70 FC F0 FF 00 00 00 00 00 00 00 00 00 00 30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 06 00 40 02 28 20 00 00 00 00 00 00 00 00 00 00 00 00 00 50 02 74 00 00 00 00 00 00 00 00 00 00 00 00 00 00 60 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 70 40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 80 00 00 80 00 00 00 00 00 00 00 00 00 00 00 00 00 90 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 A0 10 00 08 00 00 00 00 00 00 00 00 00 00 00 00 00 B0 01 00 02 00 00 00 C0 00 00 00 00 00 00 00 00 00 C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 F0 00 00 00 00 00 00 00 00 60 0F 00 00 00 00 50 24 PCI to ISA Bridge bus 0 (0x00), device 31 (0x1F), function 0 (0x00) Common header Vendor ID 0x8086 Model ID 0x24C0 Revision ID 0x01 PI 0x00 SubClass 0x01 BaseClass 0x06 Cache Line 0x00 Latency 0x00 Header 0x80 PCI header Subvendor ID 0x0000 Subsystem ID 0x0000 Int. Line 0x00 Int. Pin 0x00 Dump 0 1 2 3 4 5 6 7 8 9 A B C D E F 00 86 80 C0 24 0F 01 80 02 01 00 01 06 00 00 80 00 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 40 01 F8 00 00 10 00 00 00 00 00 00 00 00 00 02 00 50 00 00 00 00 00 00 00 00 01 FA 00 00 10 00 00 00 60 8B 85 80 85 D0 00 00 00 85 80 80 8A 00 00 00 00 70 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 90 F5 54 00 00 00 00 00 00 00 00 00 00 00 00 00 00 A0 00 02 00 00 C1 00 00 00 0D 00 00 00 00 00 08 00 B0 00 00 00 00 00 00 00 00 04 40 00 04 00 00 00 00 C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 D0 86 21 00 00 02 0F 00 00 04 00 00 00 00 00 00 00 E0 10 00 00 80 01 04 0D 14 33 22 11 00 71 07 67 45 F0 0F 00 41 04 00 00 00 00 60 0F 02 00 00 00 81 00 IDE Controller bus 0 (0x00), device 31 (0x1F), function 1 (0x01) Common header Vendor ID 0x8086 Model ID 0x24CB Revision ID 0x01 PI 0x8A SubClass 0x01 BaseClass 0x01 Cache Line 0x00 Latency 0x00 Header 0x00 PCI header Address 0 (port) 0x000024B0 Address 1 (port) 0x000024C0 Address 2 (port) 0x000024B8 Address 3 (port) 0x000024C4 Address 4 (port) 0x000024A0 Address 5 (memory) 0xFEBFFC00 Subvendor ID 0x0E11 Subsystem ID 0x00B8 Int. Line 0x0A Int. Pin 0x01 Dump 0 1 2 3 4 5 6 7 8 9 A B C D E F 00 86 80 CB 24 07 00 80 02 01 8A 01 01 00 00 00 00 10 B1 24 00 00 C1 24 00 00 B9 24 00 00 C5 24 00 00 20 A1 24 00 00 00 FC BF FE 00 00 00 00 11 0E B8 00 30 00 00 00 00 00 00 00 00 00 00 00 00 0A 01 00 00 40 07 A7 03 A3 00 00 00 00 01 00 01 00 00 00 00 00 50 00 00 00 00 50 15 00 00 00 00 00 00 00 00 00 00 60 08 00 00 00 00 00 00 00 08 00 00 00 00 00 00 00 70 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 90 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 F0 00 00 00 00 00 00 00 00 60 0F 00 00 00 00 00 00 Audio device bus 0 (0x00), device 31 (0x1F), function 5 (0x05) Common header Vendor ID 0x8086 Model ID 0x24C5 Revision ID 0x01 PI 0x00 SubClass 0x01 BaseClass 0x04 Cache Line 0x00 Latency 0x00 Header 0x00 PCI header Address 0 (port) 0x00002000 Address 1 (port) 0x00002400 Address 2 (memory) 0xFC480400 Address 3 (memory) 0xFC480600 Subvendor ID 0x0E11 Subsystem ID 0x00B8 Int. Line 0x05 Int. Pin 0x02 Capabilities Power Management Capability Offset 50h Version 1.1 Dump 0 1 2 3 4 5 6 7 8 9 A B C D E F 00 86 80 C5 24 07 00 90 02 01 00 01 04 00 00 00 00 10 01 20 00 00 01 24 00 00 00 04 48 FC 00 06 48 FC 20 00 00 00 00 00 00 00 00 00 00 00 00 11 0E B8 00 30 00 00 00 00 50 00 00 00 00 00 00 00 05 02 00 00 40 09 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 50 01 00 C2 C9 00 00 00 00 00 00 00 00 00 00 00 00 60 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 70 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 90 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 F0 00 00 00 00 00 00 00 00 60 0F 00 00 00 00 00 00 Ethernet Controller bus 5 (0x05), device 8 (0x08), function 0 (0x00) Common header Vendor ID 0x8086 Model ID 0x103B Revision ID 0x81 PI 0x00 SubClass 0x00 BaseClass 0x02 Cache Line 0x10 Latency 0x42 Header 0x00 PCI header Address 0 (memory) 0xFC500000 Address 1 (port) 0x00001000 Subvendor ID 0x0E11 Subsystem ID 0x0012 Int. Line 0x05 Int. Pin 0x01 Capabilities Power Management Capability Offset DCh Version 1.1 Dump 0 1 2 3 4 5 6 7 8 9 A B C D E F 00 86 80 3B 10 07 01 90 02 81 00 00 02 10 42 00 00 10 00 00 50 FC 01 10 00 00 00 00 00 00 00 00 00 00 20 00 00 00 00 00 00 00 00 00 00 00 00 11 0E 12 00 30 00 00 00 00 DC 00 00 00 00 00 00 00 05 01 08 38 40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 60 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 70 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 90 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 D0 00 00 00 00 00 00 00 00 00 00 00 00 01 00 22 FE E0 00 40 00 3A 00 00 00 00 00 00 00 00 00 00 00 00 F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 SMBus Controller bus 0 (0x00), device 31 (0x1F), function 3 (0x03) Common header Vendor ID 0x8086 Model ID 0x24C3 Revision ID 0x01 PI 0x00 SubClass 0x05 BaseClass 0x0C Cache Line 0x00 Latency 0x00 Header 0x00 PCI header Address 4 (port) 0x0000FC00 Subvendor ID 0x0E11 Subsystem ID 0x00B8 Int. Line 0x0B Int. Pin 0x02 Dump 0 1 2 3 4 5 6 7 8 9 A B C D E F 00 86 80 C3 24 01 00 80 02 01 00 05 0C 00 00 00 00 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 20 01 FC 00 00 00 00 00 00 00 00 00 00 11 0E B8 00 30 00 00 00 00 00 00 00 00 00 00 00 00 0B 02 00 00 40 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 60 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 70 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 90 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 F0 00 00 00 00 00 00 00 00 60 0F 00 00 00 00 00 00 DMI ------------------------------------------------------------------------------ DMI BIOS -------- vendor Compaq version 686O2 v2.17 date 09/09/2002 DMI System Information ---------------------- manufacturer Compaq product Evo D310 version unknown serial 6S29KQ6ZR13L UUID FFFFFFFF-FFFFFFFF-FFFFFFFF-FFFFFFFF DMI Baseboard ------------- vendor Compaq model 07E8h revision unknown serial 6S29KQ6ZR13L DMI System Enclosure -------------------- manufacturer Compaq chassis type Desktop chassis serial 6S29KQ6ZR13L DMI Processor ------------- manufacturer Intel model Pentium(R) 4 processor 2000 MHz clock speed 2000.0MHz FSB speed 400.0MHz multiplier 5.0x DMI Port Connector ------------------ designation SERIAL A (internal) designation IOIOI A (external) port type Serial Port 16550A connector DB-9 male DMI Port Connector ------------------ designation PARALLEL (internal) designation PAR (external) port type Parallel Port ECP/EPP connector DB-25 female DMI Port Connector ------------------ designation USB 1 (internal) designation USB 1 (external) port type USB connector Access Bus (USB) DMI Port Connector ------------------ designation USB 2 (internal) designation USB 2 (external) port type USB connector Access Bus (USB) DMI Port Connector ------------------ designation KBD (internal) designation KBD (external) port type Keyboard Port connector PS/2 DMI Port Connector ------------------ designation MOUSE (internal) designation MOUSE (external) port type Mouse Port connector PS/2 DMI Port Connector ------------------ designation CD-AUDIO IN 1 (internal) port type Audio Port connector On Board Sound Input From CD-ROM DMI Port Connector ------------------ designation AUX AUDIO IN 1 (internal) port type Audio Port connector On Board Sound Input From CD-ROM DMI Port Connector ------------------ designation PRIMARY ATA (internal) connector On Board IDE DMI Port Connector ------------------ designation SECONDARY ATA (internal) connector On Board IDE DMI Port Connector ------------------ designation FLOPPY (internal) connector On Board Floppy DMI Port Connector ------------------ designation MIC (internal) designation Line I/O: Rear MIC (external) port type MIDI Port connector Mini DIN DMI Port Connector ------------------ designation LINE IN (internal) designation Line I/O: Line In (external) port type MIDI Port connector Mini DIN DMI Port Connector ------------------ designation HEADPHONE/LINEOUT (internal) designation HeadPhone & Line Out (external) port type MIDI Port connector Mini DIN DMI Port Connector ------------------ designation RJ45 (internal) port type Network Port connector RJ-45 DMI Port Connector ------------------ designation CHASSIS FAN (internal) DMI Port Connector ------------------ designation CPU FAN (internal) DMI Port Connector ------------------ designation SPEAKER (internal) DMI Physical Memory Array ------------------------- location Motherboard usage System Memory correction None max capacity 2048MBytes max# of devices 2 DMI Physical Memory Array ------------------------- location Motherboard usage Flash Memory correction None max capacity 0MBytes max# of devices 1 DMI Memory Device ----------------- designation DIMM1 format DIMM type SDRAM total width 64 bits data width 64 bits size 256 MBytes DMI Memory Device ----------------- designation DIMM2 format DIMM type unknown DMI Memory Device ----------------- designation SYSTEM ROM format Chip type FLASH total width 4 bits data width 4 bits size 0 MBytes DMI Extension Slot ------------------ designation AGP type AGP 4x width 32 bits populated no DMI Extension Slot ------------------ designation PCI Slot 1 type PCI width 32 bits populated no DMI Extension Slot ------------------ designation PCI Slot 2 type PCI width 32 bits populated no DMI Extension Slot ------------------ designation PCI Slot 3 type PCI width 32 bits populated no Software ------------------------------------------------------------------------------ Windows Version Microsoft Windows XP Professional Service Pack 3 (Build 2600) DirectX Version 9.0c Resources ------------------------------------------------------------------------------ Memory I/O Space, BA=0x00000000F8000000 Memory I/O Space, BA=0x00000000F0000000 Memory I/O Space, BA=0x00000000FC400000 Port I/O Space, BA=0x2440 Port I/O Space, BA=0x2460 Memory I/O Space, BA=0x00000000FC480000 Port I/O Space, BA=0x24B0 Port I/O Space, BA=0x24C0 Port I/O Space, BA=0x24B8 Port I/O Space, BA=0x24C4 Port I/O Space, BA=0x24A0 Memory I/O Space, BA=0x00000000FEBFFC00 Port I/O Space, BA=0x2000 Port I/O Space, BA=0x2400 Memory I/O Space, BA=0x00000000FC480400 Memory I/O Space, BA=0x00000000FC480600 Memory I/O Space, BA=0x00000000FC500000 Port I/O Space, BA=0x1000 Port I/O Space, BA=0xF808, size=0x4 Memory I/O Space, BA=0x00000000FEE00000, size=0x1000 Port I/O Space, BA=0xFC00 Port I/O Space, BA=0x400 Port I/O Space, BA=0x2E
  • 64 Answers
    Master:
  • 363 Answers
Hello, everyone, have you ever played a game called RuneScape? I heard this game is very popular before, and now there are still many players, and recently I found a website may be able to help you, to share with you www.rsgoldfast.com
Posted on Dec 19, 2016
My computer runXP and need to download new network card
Hello visit the mainboard or the pc`s homepage, for downloading the driver.
Or visit the network cards homepage.
If you have entered the mainboard model, or the pc`s model full number, i could have found the driver for you.
Good luck
Feb 26, 2013 | Computers & Internet
I have a Netgear Wireless N150 router. It has been installed on our 2 computers. However, I had to reinstall Windows Vista on one and when I tried to reinstall the router, it tells me "No working...
Sounds like the driver for the network adapter has not be installed following the re-install of vista
to verify
go to start-->control panel-->System
Click on 'Device Manager'
Look for any devices that have a question mark or exclamation mark next to them
I suspect you will find something like 'Ethernet controller' which wont be configured correctly.
You will probably need to download the driver, using your other machine and then transfer to the problem machine and update the driver
If you need help identifying the driver then please provide details of the make/model of your PC.
If this doesn't solve the problem then let me know before rating this answer and I'll try to help you further
Good luck
Sep 06, 2011 | Computers & Internet
All the programes have been deleted from my pc windows 7 has been instaled but i have no sound drivers
1st hope that your mainboard is compatible with windows 7.
you need to go to the web site of your mainboard manufacturer for exp: msi, ati, asus, dell, hp, gigabyte, etc...
on the web site look for download drivers.
then you will need the model of the mainboard which is printed on the mainboard (in white text)
choose your OS, select sound or audio then click on the link to download the audio drivers.
If you dont see windows 7 for your mainboard, you can download it for Vista.
*if you dont see windows 7 or Vista, then you mainboard is not compatible with win7 and you will need to install windows XP
if its zip file, you will need to unzip it and run the setup file.
good luck.
May 28, 2011 | Computers & Internet
My computer was formatted but after formatting there is no sound device.NOW I NEED FREE SOUND CARD DRIVER OR SOFTWARE
If you recently formatted your computer and reinstalled the OS, you will need to go to the maunfactures support website and download drivers for all devices. For instance, if it is a Dell you can go to their support website and enter the model laptop you have and it will show drivers for all installed equipment; sound, video, networking, webcam, etc. Also if you do your windows updates alot of times it will include missing drivers.
May 05, 2011 | Computers & Internet
How could we know the right model to download the right audio driver in your PC
You need the model number of you computer mainboard, if you are using onboard audio and if you are using a sound card you would need the model number of that card. The model number of the mainboard can be found, either between the PCI, PCI-Express, AGP slots or near the RAM slots.
So it's the name of the manufacturer of your computer mainboard, eg: Asus, MSI, Gigabyte, Abit, Foxcon etc... and the number that follows.
Then go to the manufacturers website and under the support heading, find your mainboard audio drivers.
damnor01
Dec 19, 2010 | Computers & Internet
No sound
Possible causes.
1. No sound ->means no Audio/Sound Drivers or incorrect drivers installed for your Audio devices ie.(no sound icon on your taskbar?)
2. No sound -> Sound card devices or speakers could be defective.
No mention of Operating Systems ie Windows versions , Linux, Dos...etc... or information of Mainboard brand, name, model -> means difficulties in helping to solve your problems!!!!!
Hope it helps.
Nov 05, 2010 | Acer Computers & Internet
I have a gateway mfatxstl kth 300s, All the power wires and master slave ribbons were unplugged. How can I get a diagram on how they should be plugged in? thank you Rod
hi rod, first of all u have to find out manufacturer and model of mainboard, then get a manual plus drivers for the windows version u use
(there are often on/board sound chips and ethernet(networking) cards on the board, therefore the drivers) from the manufacturers homepage or gateways hp.
the manual will tell u where to put all the power and data cords.
for how to wiring up mainboards etc. try to search tutorials on youtube!
good luck
Aug 08, 2009 | Computers & Internet
Why can i found my sound driver?
dear khieonemo,
from your question I under stand that u have an ASRock mainboard with onboard soundcard and now are looking for a suitable driver for it. goto : www.asrock.com/support/download.asp,
enter your boards model number , pick the right operaiotn system and download the right driver fitting your board. some asrock drivers come in bundles, meaning that one self-installing file
includes drivers for mainbord and all of it's onboard components
like sound and ethernet card, usb-ports and even processors and PCI handling, therefore make sure to enter the exact model of your board.
if you cannot find the model number or have lost he manual to it, please post another request for help. thx a lot and good luck
Jul 24, 2009 | Computers & Internet
PRODUCT 07E8H
Use the site www.driverguide.com
Jun 15, 2009 | Chaintech 9LIF7 i845G Motherboard
Installer
I not found Hp compaq 07e8h motherboard driver :(, pls you help me. If you found the driver pls send my e-mail (noorbert69@gmail.com) . Thank you wery mutch.
Jun 16, 2008 | Compaq (243479-001) for Tasksmart C4000...
Chaintech 9LIF7 i845G Motherboard Logo
1,357 people viewed this question
Top Chaintech Computers & Internet Experts
Ed Mac
WTF Chuck.....
WTF Chuck.....
Are you a Chaintech Computer and Internet Expert? Answer questions, earn points and help others
