Question about Radio Shack Pro-83 Scanner
Tool on scanner wont shut off
I was driving the other day, and i accidentally hit a button on it, and its like an "eye" its located as a 3rd sub tool on the 4th channel, it searches channels for frequencies, its wicked annoying since it makes a loud annoying noise when it finds one, its already programmed, i mis-placed the book. can someone please tell me how to shut the stupid thing off! :) thanks! - E bombz
  • 150 Answers
Re: tool on scanner wont shut off
Go to the below link for the manual. That eye symbol refers to stalker mode, which enhances the reception of the radio, see page 23 of the manual. It sounds to me like it's stuck in service mode(SVC) which allows you to scan frequency ranges for police,fire,air, etc.See page 28 of manual for more details. Hoipe this helps.
Posted on Sep 14, 2007
0 characters
3 Points
How do I program the scanner. It keeps telling me there is an error when I enter anything. Any help would be greatly appreciated.
I have one of these scanners they are kinda hard to program uniden could of made it simple.....Ok you have to hit your function button first...Then hit your e button enter button the enter button and it will go to program...The enter button and the program button is the same just go to your enter button. e button this will put your scanner into program mode...then you can start entering your frequencies...if you don't have it in program mode it will show error...If you have any more problems you can e mail me
Jul 16, 2011 | Uniden BC72XLT Handheld Scanner
put your bc72 in program mode.. hit you e button your enter button..but first put your scanner in function mode... then hit your enter button this will put your scanner in program mode and you can start entering your frequencies into it....if you have any problems biddy mac you can email me at
Jul 02, 2011 | Uniden BC92XLT Handheld Scanner
Error meassage keeps comming on when trying to program frequencys
that is because you are trying to program frequencies into the scanner with hitting your program button...hit your program button.. its your prg..button when you hit your program button then try putting your freq in...
Jun 18, 2011 | Radio Shack Pro-2018 Scanner
Hello, there is no way to lock the keypad like one would a cell phone to prevent the accidental pushing of buttons. However if you are listening to a transmission and you want to stop it on the frequency it is at so you don't miss any of the conversation simply push "man" (manual) on your keypad and it will remain on that frequency until you hit "scan" again. Once you hit "scan" it will begin to trunk. The "lock" button on your scanner is to lock the lights on so they don't shut off in **** a short time. Hope this helps.
Regards, Tony
Mar 24, 2011 | Radio Shack Pro-97 Handheld Scanner
My scanner was woking fine untill i hit a button by mistake and now it wont scan through the channels ... i dont know what button i pushed!
To remove the lockout from a channel, manually select the channel and press L/OUT so L disappears.try this the channels could be locked
Jan 22, 2011 | Uniden BC898T Base Scanner
Pro-96 Scanner: My pro 96 scanner says all channels locked and it ...
If there is no frequencies on your scanner it will lock all channels out. if all your frequencies are on one bank and you accidentally hit that bank number and turn it off it will lock out all channels. If that's the case just hit that bank no. back on and they will unlock.
May 17, 2010 | Radio Shack Pro-96 Scanner
My scanner comes on but does nothing it don't scan up or down but did at one point and time what is up with it?can someone help me
I've got a couple of options you might consider:
1. You may be in "manual" mode & the scanner's locked onto one frequency (one that obviously doesn't have much happening on it if you're not hearing anything!). Try pressing the "Scan" button, which will take it out of Manual mode.
2. You've accidentally "initialized" the scanner which means all of your frequencies have been deleted (sort of like wiping your hard drive clean). If that's what's happened, you'll need to re-enter all of your frequencies.
Oct 26, 2009 | Radio Shack Pro-97 Handheld Scanner
Lock out problem
In all likelihood all the programming has been deleted, which would default the scanner to this condition. Turn on the power & press the "Manual" button, then check the frequency. Keep doing this to ascertain if all have been deleted. If so, re-program the scanner.
Sep 25, 2008 | Uniden BC72XLT Handheld Scanner
Programming a scanner
To program a BC 70XLT turn the scanner on and hit the man key.
enter the channel you want to program (ie 1) hit the man key again then enter the frequency you want to scan (IE 450.625) then hit the E key to enter the freq into the location if you want to sequence to the next channel then hit the man key again enter the freq and hit the E can go through all 20 channels this way.
Sep 12, 2008 | Uniden BC60XLT Handheld Scanner
Radio Shack Pro-83 Scanner Logo
97 people viewed this question
Top Radio Shack Radio Scanners Experts
Robert McClure
Are you a Radio Shack Radio Scanner Expert? Answer questions, earn points and help others
