Question about Samsung HT-TX72 Theater System
Display on main dvd has stopped working
WHEN SWITCHING ON IT SAYS HELLO ETC BUT AFTER ABOUT 10 SECS IT DISSAPPEARS
  • 1 more comment
  • a_cooke2 Apr 14, 2009
    THIS SHOULD BE HT-TX35 MODEL
  • a_cooke2 Apr 16, 2009
    Thanks for responding
    I am using a samsung tv and dvd cinema system the only other thing is a sky box, It has always worked untill recently i used a usb memory stick and now the dvd display switches off but the film will carry on running, i have tried the master reset from the manual which puts all the settings back to default but still no luck????
  • Cobbzilla May 11, 2010
    Are you using all Samsung products? I have had a lot of issues with the use of Samsung's Anynet+. Whenever I watch a movie it will begin running the blu ray and turn off all other Samsung devices other than the tv of course.
    Problem Solver:
  • 13 Answers
What were you using the USB device for? Were you using it for standard media like pics or were you using it to install an update for drivers? My only suggestion would be to check your dvd players settings or check to see if your dvd has online drivers or updates you can install via USB.
Posted on Apr 17, 2009
Why does display says"please wait". message on screen reads "searching for software. no respose to controls.
under somewhere there is a reset button push for 5 - 10 secs and go from there.
Aug 28, 2014 | Televison & Video
Panasonic the genius prestige problem:::: it will run for about 10 secs then shut off, turn it on again real quick it will run another 10 secs...everything else works on it, the broiler,bake, but when the...
Before spend $$ on replacement boards, make sure anything attached to it is powered off. Unplug TV for 5mn to 15min. Plug back in and it should power on. If not leave unplugged overnight before spending on a replacement board. We have to do this 2-3 times per year when someone forgets to turn off auxiliary components (receiver, DVD, cable box, etc) first. It has always come back on.
Mar 16, 2013 | Panasonic NN-SD797S Microwave Oven
Stuck on hello message
Sounds like the unit is not booting up correctly. Probably going to need a new main board.
Jan 29, 2013 | Televison & Video
I have a pulsar nx14-x003 watch with world time zone ect.. My problem is the digital time has dissapeared, the anolog time still works, as does the stopwatch ect.... When I edit the time the digital time...
Hi, maybe You just holded reset button at basic display mode. With 1st pressing and holding it for few secs You can make digital time disappear, 2nd holding makes disappear upper display, and 3rd time You are back with both displays on.. ;) Just bought them from eBay and lazy to read manual..its a nice watch indeeed :)
peace
Dec 30, 2012 | Watches
Panasonic DMR-EZ48V stopped working properly. It seems to have frozen up, but resetting it doesn't get it working again. When I reset by pushing the power button for 10 seconds, it flashes HELLO 15...
My unit is doing exactly the same thing. I've tried reloading the firmware, but it never appears to enter the First Time Setup. To load the CD I had to remove the cover, (disconnect the power) and manually eject the DVD tray. With the cover off, look on the side of the DVD. There is a square hole, directly above the screw that attaches the DVD to the chassis. Insert a stiff rod and push. The DVD tray will open. This is how I loaded the firmware CD. This all started after I rescanned the tuner and then did a manual channel edit. While trying to edit the channels, the unit stopped tuning and ended up in its current state.
Jan 23, 2011 | Panasonic DMR-EZ48 DVD Recorder
My note book switching on and holding for a few seconds (5 secs) switching off. there is no display coming. could you advice me
Surely it has a shortcircuit with any of the main components. Try first by removing the battery and starting only with AC adapter. then, remove one of the memories, then the other one. keep always a RAM module. then remove the HDD and try to start without it. finally remove the DVD unit and start. If this is not enough then you have an electronic problem in Motherboard (Maybe in Video Chip), It is necessary that you service it.
Thanks for ranking!!!
Apr 28, 2010 | Toshiba Satellite A100-S8111TD Notebook
My JVC TH-G30 gives me a locked message when I try to open the load tray what should I do?
hello Setting the disc ejection lock
You can lock the disc tray to prevent the disc form
being ejected.
When the main unit is turned off, hold down the STOP
key at the front panel for 5 seconds
If you attempt to open the disc tray by pressing
OPEN/CLOSE key, the disc tray does not open and
“LOCKED” appears in the display window.
To cancel the disc ejection lock, hold down the STOP
key at the front panel for 5 seconds again when the
main unit is turned off.
“UNLOCKED” is displayed in the display window.
Note:
Before the main unit is turned off, DVD/CD function
should be selected.
Mar 29, 2010 | JVC TH-G30 Theater System
Aspire 5100
Hi Fayez,
How soon does the laptop switch off? Immediately, or a few minutes into booting into Windows, or ... ?
It could be an overheating issue. If you're using it on your lap or on a soft surface such as a couch or bed, the fan might not be able to release the heat.
Try putting something underneath the back of the laptop and place it on a stable surface such as a desk and boot it up - see if it still shuts down.
Otherwise, let me know how soon it's switching off, or at what point if it's the same point every time.
Ben
Mar 07, 2008 | Acer Aspire 5100-5033 Notebook
DVD frozen
suggest unplug Bose system from the wall for 10 secs, then plug in and allow it to initialise.
if this fails take bose unit to dealer.
Aug 17, 2007 | Bose Lifestyle 48 System
Samsung HT-TX72 Theater System Logo
109 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
