Sagging roof I have a 99 coleman pop-up camper w/ sagging roof (due to weight of a/c apparently). What's best and most economic way to repair? Would love to see pics of someone who has repaired theres. Thx, Bill
  • Anonymous Apr 25, 2009
    I own a 1999 Coleman Mesa without roof A/C and also have a problem with my roof deforming and sagging in the middle. Turns out, Coleman had problems with many of the plastic roofs doing this. There are other sites on the web describing the problem. No repair avail other than roof replacement which is quite costly.
    Good luck.
  • garagenc Nov 06, 2011
    did you ever get a answer or did you figure how to fix it? I have the same problem and just pulled it into my garage to start. I'm thinking of taking the AC unit off and putting somekind of tee bars inside and attaching a chainfall and pull the roof straight again and then installing aluminum teebars upside down and bolted them to hold the roog level. Maynot look great but should work. Don't think there's enought room to slide a long tee bar in from the roof cut.
3 Suggested Answers
motor1258
  • 6674 Answers
SOURCE: was given a roof top ac for a popup camper need help
Make and model of unit should be on base of roof assy, please reply with that so we can be sure we have right wiring info for you. Although they are pretty common, let's be sure.
Posted on Aug 02, 2010
motor1258
  • 6674 Answers
SOURCE: Hi, the roof top air conditioner drain keeps
Re: re-directing the water dripping over door ! Stop at RV parts store and get yourself a tube of "Dicor" self leveling sealant. It's recommended for rubber roofs, but works well on most roof surfaces.
Then I simply run a 3/8" bead of "Dicor" across wherever the run-off from AC is coming down, and re-direct it so the run-off comes off roof elsewhere. Don't try to smooth it out or anything, as I said, it is self leveling, just use a caulking gun, lay a bead about 3/8" and allow it to set for a few hours if you can. Make sure you pick a time where AC is off for a couple hours so (run-off) water isn't present. You"ll see the path (stain) on roof where it travels to guide you for redirecting. It's a simple fix, and no screws or nails required. Use the rest of the Dicor to fill in any gaps, cracks etc you see on sealant on the roof while your up there, but clean those before applying. If you can wipe your intended path down with some mild cleaner prior to applying bead, it will help it stick better as well. Even a little dish soap in water will do, just be careful, it gets pretty slippery when soap on there. Quick rinse with water then dry with rag, or let the sun dry it. Actually on a rubber roof, It should be scrubbed with mild detergent at least once a season anyway.
Posted on Feb 28, 2011
Testimonial: "Thanks. Great idea."
How to tighten cable on pop up camper
the adjustment can be done by your dealer, contact them see how much it costs.
Oct 26, 2008 | Coleman 10' X 10' Sundome Tent 9160K101
Need 2000 owners manual for coleman niagra pop-up camper
Try this link
http://www.popupportal.com/index.php?action=media;sa=item;in=2985
Apr 23, 2012 | Coleman 10' X 10' Sundome Tent 9160K101
I bought a pop up. On the way home from buying it popped off hitch (apparently the coupler needs to be replaced)- how do I go about repairing (or does anyone know of a place in southe east WI area that...
Hitch: Verify the obvious. 1-7/8" or 2" ball and coupler. Some couplers can be and may need to be adjusted. Look for a screw on the rear side.
Sorry, not much help on the lift system. Although, I rigged a winch up to my coleman instead of replacing the whiffle tree. You may be able to do similar.
Apr 09, 2010 | Coleman Campers Grill
Water damage in ceiling, plywood warped, contact paper bubbling u
Seal roof seams. set up camper . prop peice of plywood slightly bigger than damaged area under damageshim to acheive moderate pressure. wait a week & remove. If it comes back down will have to replace paneling.
Jul 25, 2009 | Coleman Campers Grill
I have cracks on my coleman pop camper rubber roof
Roll with a fibrous roof coating. make sure it has the fibers or else it will not adhere to the cracks or metal.
Jul 11, 2009 | Coleman 10' X 10' Sundome Tent 9160K101
Cracks in the top
nice solution should work, and yes bad design by coleman. you can also paint roof with camper roof paint silver with fiber
Jul 07, 2009 | Coleman 10' X 10' Sundome Tent 9160K101
I need a repair/owner's manual for 1999 Coleman
Tried googling Coleman? They might be able to help.
Jun 29, 2009 | Sport & Outdoor - Others
Delaminated TOP on Coleman Camper
If you have to fix it yourself out of warranty i suggest this ,
REGLUE ALL THE BITS THAT ARE COMING AWAY , THEN FIND A GLUE THAT IS SPREADABLE LIKE A THIN PAINT AND COAT THE ENTIRE ROOF MAKING SURE THAT IT GETS INTO ALL THE CRACKS , LET IT DRY .
THEN PAINT THE ROOF WITH A THERMAL MEMBRANE COATING . This will insulate the camper from the sun and keep heat in during colder times , the thermal paints are not cheap but they do work . Hope this will help you
May 05, 2009 | Tools & Hardware - Others
Heating & Cooling Logo
1,029 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
