Question about Garden
I have a Briggs and Stratton 5.5 hp 2250 PSI pressure washer that lacks PSI. How do I make sure the upload valve is free. It just doesn't appear to be adding pressure to the tank.
  • 313 Answers
SOURCE: dayton 5000 psi pressure washer
check out www.smallengineadvisor.com for trouble shooting & repair.
Posted on Jun 24, 2008
  • 1111 Answers
SOURCE: just bought a new Briggs Stratton 6 75 pressure
assuming you tried choking it when you tried to start it, verifiy its getting gas,if not tap lightly on the bowl of carburator. if it is getting gas, check for spark
Posted on Jun 20, 2009
SOURCE: 2200 psi husky briggs and stratton pressure washer
After a long none use, I tried to wash my driveway and powered on the washer,it did, but when i tried to engage the power washer by pressing the wand lever, it did not engage. What can I do to get the power washer working?
Posted on Jan 30, 2010
SOURCE: how to change oil in a pressure washer
From the manual CleanShot 2050 Briggs and Stratton
Change Pump Oil
1. Drain engine oil and fuel from pressure washer
2. Use an 8 mm allen wrench to remove black pump oil cap between high pressure outlet and garden hose inlet.
3. Tiltl pressure washer to drain oil into an approved container until it drips slowly from pump.
4.Tilt pressure washer in opposite direction and empty premeasured pump oil bottle into same opening (a small funnel may be helpful) [THIS IS WHAT THE MANUAL SAYS-NOT CLEARLY WRITTEN IN MY OPINION OR WRITTEN BY SOMEONE FOR WHOM ENGLISH IS A SECOND LANGUAGE]
5. Install black pump oil cap and tighten firmly.
6. Set pressure washer in upright position. Add fuel and engine oil.
From the engine manual use synthetic 5w-30, 10w-30 from -20 degrees F to temperature of 100 degrees F.
Change oil after 5 hours of operation initially. Before tipping to drain oil, remove fuel from fuel tank by running until tank is empty. Remove oil cap and dipstick and tip engine. Keep spark plug side up. Or remove drain plug from the bottom of pressure washer with a ratchet and square extension and drain oil from bottom. (fuel does not have to be removed)
Posted on Apr 22, 2010
SOURCE: Need to know where oil
I have the same model...... it should be just underneath the unit.... it will look like a square head recessed. I used the ratchet set extension and it fit just right. I literally had to tilt the darn thing upside down to find it. Then once it was loosen a bit, I put the machine upright on the wheels again, and slip a plastic pan underneath as I finished unscrewing the oil plug, Out came the black goo.
Posted on Sep 26, 2010
I HAVE AVANGUARD 9HP PRESSURE WASHER NEED TO KNOW PSI @GPM OF THIS
most rarely exceed 2600 psi as these can blow right through your hand..gpm maybe 40-45..there should be a plate with all that on the unit..
Jul 10, 2014 | Briggs & Stratton Briggs Stratton Vanguard...
How does a uploader work
Do you mean unloader? That would be a valve that dumps the discharge pressure back to the suction side when the trigger is releasesd.
Jun 25, 2014 | Craftsman 2500 PSI Briggs & Stratton...
Briggs and stratton 6.5 hp 2.500 psi wont give presser constentley
I will need your model # to assist further
Mar 31, 2014 | Garden
Will not produce pressurized water
check the pressure regulator valve. It may be set wrong or stuck open. If that is not the problem then a valve may be stuck in the pump.
May 17, 2013 | Briggs & Stratton Briggs Stratton 1800...
Where is the fuel shut-off valve on a briggs and stratton 2100 psi model 01439
a lot of the dont have one but a small inline valve can be installed the fuel dripping from the carb when its turned off replace the needle valve and seat
Mar 29, 2012 | Briggs & Stratton Power Products 1539...
Started by Craftsman 2700 PSI , 2.3 GPM Briggs & Stratton Powered Pressure Washer for first time in 9 months. Added new oil, and gas. started but is smoking from muffler and is dripping what appears to...
The first thing I would check would be the oil level, to make sure you didn't put in too much oil. If the oil level is correct, it could be a stuck piston ring, letting oil blow by the piston, and out the exhaust. If this is the case, you are going to have to tear down the engine.
Hope this helps!
May 09, 2011 | Craftsman 2700 PSI,2.3 GPM Briggs &...
I have an old briggs stratton 2001 power washer its hard to read model number it looks like EXYRB2321 or EXVRB2321 its 6 hp when i put in ether number at B&S sit they say no results i need a...
Excell pressure washers used a series of numbers such as yours. I believe that that number will be for pump or pressure washer as a whole unit. Check Excell web site for a match. If you are looking for the engine model number check the fan shroud or valve cover or tag on engine itself. Good luck
Sep 06, 2010 | Briggs & Stratton 020324 3700 PSI Pro...
Garden Logo
96 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
