Question about Pulsar PF3347 Wrist Watch
Pulsar chrono model pf 3347
WHEN CRONOGRAPH IS RESET SECOND HAND DOES NOT STOP AT 12 OCLOCK POSITION
Go here and follow the instructions. The link is a pdf of the manual.
Posted on Aug 15, 2009
I have the Nautica A40008 watch and I can not reset the big second hand to 12 oclock. It stops always at 11
pull the crown out to second position then press start till it gets to 12 then push crown back in
Apr 09, 2013 | Watches
24 hours hand in advance of 2 hours from the hours hand
You need a watchmaker. This probably occurred when you had a dead battery replace. It is possible to reset the different hands through a procedure involving pressing different buttons with the crown in different positions.
Oct 07, 2012 | Emporio Armani Watch AR1400 Cronograph...
How do you reset the second hand so it sits at the 12 o clock position on an Ingersoll diamond automatic chronograph watch
I don't know if it's the same, but I just solved this problem on a Victorinox (Swiss Army) Chrono Classic XLS. The process involves:
1) Pulling the plunger out to position 3 2) Holding both buttons down for 2 seconds 3) When the hands stop moving press the top button. Each time it's pressed it will advance the second hand one tick. Keep tapping the top button until the second hand is in the 12 position. 4) Push the plunger in.
Oct 26, 2010 | Watches
The timer on Pulsar watch does not line up at 12 when reset.
To set the timer hand on these models of Pulsar watches, do the following:
Looking at the face of the watch, there are two buttons and a crown on the right side. The TOP button is Button "A". - The BOTTOM button is Button "B".
There are 3 positions on the crown: IN (#1), FIRST CLICK (#2) & SECOND CLICK (#3).
First, pull the crown out to the second 'click' position (#3) ... This is all the way out. (STOP THERE! Pulling harder will harm your watch! Don't try to pull past position #3!)
Push and hold Button "A" for two (2) seconds. The dial will sweep around to the 12 O'clock position. You can advance the timer while the crown is in position #3 (second click out) to reset it back to the default position.
The manual says that if you pull the crown out to position #3 while the timer is measuring, the hand will reset back to the 12 o'clock position... I haven't tried that, so I can't confirm.
Jan 02, 2010 | Pulsar Chronograph Watch
The second hand on my invicta chronograph watch doesn't reset to zero
Easier than you think.
Pull your Crown out to the FIRST stop (were you would normally set your date). Push the "A" button (top chrono button) for your dial at the "3 oclock" area, Push the "B" button(bottom chron button) for the second hand.
Dec 26, 2009 | Invicta Subaqua Noma Iii S
I know how to reset my cronograph seconed hand to 12 o' o'clock position. How do I set the minute hand to the 12 o'clock position
It depends on the movement or model. On some you have to pull the stem out to the second position and press the start button. On some you have to pull the stem out, push it back, then pull it out again in succession then press the strt button to set the minutes. Yet others you have to pull the crown out and press both strt and rst button to move the minute hand. In either case one of those combination's should work.
Sep 20, 2009 | Invicta Watches
Need instructions on National Geographic Men's watch #NG010GYSK
go to Buliva web site and look for the chorograph 561/598
FEATURES
1. Hours, minutes, seconds and date display.
2. 60 minute Chronograph (CHRONO) with minutes and
seconds display.
3. 24 hour hand, permanently synchronized with the normal
12 hour hand.
A. SETTING THE TIME
1. Pull the crown out to position “3” (See diagram). If the crown has
a “screw-down” lock, then unscrew the crown lock first by turning
the crown toward you, then pull it to position “3”. Do not forget to
screw the crown back “IN” after all setting is completed.
2. Turn the crown towards you (hands moves clockwise) until the
date changes at approximately midnight.
3. Continue turning the hour and minute hands to the correct time.
If it is afternoon you must go past 12 o’clock again (noon) to set
the correct time.
4. When the correct time is set,push crown back to position “1”.
B. SETTING THE DATE
1. Pull crown to position “2”(See proceeding diagram).The watch
will continue to run.
2. Turn the crown away from you until the correct date appears.
3. Once the date is set, push the crown back to position “1”.
Note: Do NOT set the date between the hours of 8:00 PM and
3:00 AM.This would not damage the watch,but the date may need
to be reset later.
C. CHRONOGRAPH (CHRONO) ADJUSTMENT
If the chrongraph second hand is not positioned at the proper
starting position (12 o’clock or “zero” position), use the below
procedure.It does not need to be repeated unless the watch
receives an impact sufficient to move the hand out of position, or
the Battery has been changed.
1. Pull crown out to position “3”.
2. Push button “A” to move the Chrono Second hand (long hand) to
the “0” or 12 o’clock position. Each button push will move the
hand one step – BUT holding the button down will advance the
hand rapidly.
3. Push crown back to position “1”.
D. USING THE CHRONOGRAPH (CHRONO)
Note:
The maximum chrono reading is 60 minutes, However the
chrono will continue running once 60 minutes has passed. The
resulting one hour periods may be added together mentally to keep
track of longer periods.
For example – If you know that approximately one hour has
passed since you started the chronograph, and the chrono reads
25 minutes, then you know that the chrono has been running 60
minutes plus 25 minutes, which is one hour and 25 minutes.
1. Push Button “A” to start the chronograph. Push button “A” again
to stop the chronograph.
2. Push button “B” to return the two chronograph hands to the
“Zero” or starting point.
3. The Chronograph can be stopped and started again
(Button “A”), repeatedly, to “ADD” times together.
BOOK NO. 561/598 Chrono FS00/01/10
Watch Setting Guide
4/2007
Feb 13, 2009 | Bulova Watch
How do you set and deactivate the alarm function.
I did find two authorized dealers:
www.kenmarwatches.com
www.princetownwatches.com
Contact both and request users manual fur your specific model. They must be able to help.
Jan 05, 2009 | Bulova Watch
Re-set quartz chronograph sweeping second hand
Easy Soultion worked for me. Believe Me I was worried only had the Seiko Sportura for a week now. My second dial for the stopwatch was re-setting to 5 seconds instead of zero. The Solution is
1. pull the Crown all the way out ( In the position you take the crown to set the time , second click ).
2. To set the minute face of stop watch , keep pressing the top button untill it is zero. To set the second needle to zero keep pressing the bottom button untill it reaches zero or where you like it to re-set each time. Depend on you.
3. Once all neddles of stopwatch are at resting postions ( usually zero) secure the crown back to its normal postion. Test your stop watch , hopefully it will go back to zero when you press the reset button. C
Glad to help. ashfaque.r@googlemail.com
May 18, 2008 | Seiko SNA553 Alarm Chronograph
Luminox 8152 chrono
If you have your instruction manual it should tell you how to reset the chrono. i have the Luminox 8352 and it says to pull the crown out to the 3rd position. then press and hold both the start/stop and lap/reset buttons for a couple of seconds. you'll see the second hand rotate, then you can single click the start/stop button to manually move the second hand 1 second, or you can hold it and it will continue move for a longer period until time desired. if you need to adjust the other chrono hands, click the lap/reset button and then you can click the start/stop button again. repeat for the minute/hour chrono hand. when you're finished push the crown back in. it might work even though it's a different model, worth a shot? hope that helps. these are really great watches.
Jan 02, 2008 | Luminox Field 821 wristwatch
Pulsar PF3347 Wrist Watch Logo
307 people viewed this question
Top Pulsar Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
lessaleadr
Level 1 Expert
Are you a Pulsar Watch Expert? Answer questions, earn points and help others
