Do I need a converter?
Does my Orion STV 2763 need a converter box or is it already digital?
    President:
  • 1,779 Answers
If you are on cable, then NO. If you are using rabbit ears or outside antenna then you will need a Box. That set does not have an ATSC tuner in it for over the air digital reception.
Posted on Apr 14, 2009
  • Jim Krause Apr 14, 2009
    If you are on cable, NO.. If you using rabbit ears or Outside antenna then Yes, you will need a box. Your set does not have the ATSC tuner that receives over the air digital transmission.
    Novelist:
  • 159 Answers
Go to menu
send the tv to autoprogram
if your HD channels are available in your tv. Then you dont need a converter box.
I need a 3 digit code for RCA converter box for a Orion tv.
Hello
You haven't given a clear problem post ebefore me. You have only give the model number and brand name of your TV only. Not give the model number of your RCA converter box. Yet i posts a solution to your problem, assuming that your RCA Converter box model number is " DTA 800B1 " The three digit setup codes for Orion TV with this RCA converter box are: 029, 189, 200
ok
gopakumarg43
Oct 04, 2011 | Orion STV2763 27" TV
Just wanting to make sure that I do NOT need to get a converter box for the STV 2367 series.
Hi
Does the instruction book state that the set as built in freeview.if doesyou might still need a digatil box ,as older set will not decode the newer signals, A box can be connected through the scart connector on the back of the tv , you might have to fit a wide band aerial outside if your signal strength is weak Hope this will help
Windyhouse
Sep 16, 2011 | Orion STV2763 27" TV
Are my Orion tv's purchased in 2002 digital ready
Your TV does not have a digital tuner. You'll need a converter box for digital broadcast reception. Remember that if you're on a cable system or using a satellite receiver, your TV doesn't need to have digital tuning. It's only if you want to watch off-the-air broadcasts that you'll need the converter.
May 12, 2009 | Orion STV2763 27" TV
Message on TV Error cannot access digital services
According to the specs on that model, it does not have a digital tuner capable of receiving ATSC signals. You need a converter to receive the digital signal and convert it to analog so that set can process it. Unless you already have a 'black box' between your signal source and the Orion, you have never received 'digital' signals.
Nov 29, 2008 | Orion STV2763 27" TV
Just want the Orion TV (Model: STV 2763) to play VHS videos
Problem Solved:
Take your connector with the 3 colors red,white & yellow and plug into VCR OUT. The other end (w/ 3 plugs) goes into the INPUT on the back of the TV. Next insert a VHS Tape & search the TV for input or a channel below #2 for Cable#1,2,3 or AUV Channel.
In this case; Channel AUX #1
Shows / Plays Video w/ clear sound & picture.
Yahoo.
May 21, 2008 | Orion STV2763 27" TV
Just want the TV to play VHS video
check channel and check plugs
Dtv ready?
Usually on the back of the set there will be a hookup for digital tuner. To get the converter box before Feb 2009 go to http://www.dtv2009.gov
Mar 15, 2008 | Orion STV2763 27" TV
Orion STV 2763 27in TV
I am assuming that your TV has Video IN source selection.
You need to use the Video/Audio OUTput of the VCR/CD and connect them to the Video/Audio INput of the TV. To do this you would have to use a 3-wire shielded cable with male RCA connectors color yellow, red & white.
c296912.jpg RCA male connectors, yellow is usually video, red/white is audio left/right.
599898c.jpg as shown OUT of VCR/CD to IN of TV.
Pnce done, play the VCR/CD with a good known CD or tape and set TV to Video mode.
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Jan 31, 2008 | Orion STV2763 27" TV
Do I need Converter Box???
if it was purchased back in 2003 chances are that it is not digital TV ready and you would need to purchase a converter box.
Jan 02, 2008 | Orion STV2763 27" TV
Help me fix my orion tv problem
Let it run an autoscan or see if in the menu it has channels that are blocked or disabled.
Nov 26, 2007 | Orion STV2763 27" TV
Televison & Video Logo
76 people viewed this question
Top Televison & Video Experts
