Question about Jabra BT350 Bluetooth Headset Headset
How to get jabra bluetooth headset in discoverable mode
I have a headset I haven't used for a long time & I don't know how to hook it up to my new verizon blitz phone.
    President:
  • 949 Answers
Http://www.jabra.com/sites/Jabra/GNimages/Products/WirelessHeadset/BT350/Documents/BT350_UM_AP_EN_650.pdf
This is your manual, you need adobe reader to see the pdf file,
it is a free download if you don't have it.
http://get.adobe.com/reader/otherversions/
Posted on Apr 14, 2009
Cannot pair my iphone 4 with jabra sps5050
The reason is you need a four digit code in order to pair your Bluetooth to your phone. Also, your phone has to be 'Able to be found', ie, set your Bluetooth settings on your phone, so that the phone is in 'Discoverable Mode' and ensure the Bluetooth setting itself is also turned on.
Once your phone is Bluetooth discoverable, try and pair the devices again. Your phone will find your headset and ask if you would like to pair the two devices. Obviously, select Yes/Pair and it will then require a 4 digit code for authentication. With Jabra the code is always "0000" (4 zero's). Once you enter the 4 zero's, the two units will then pair successfully.
Let me know if you require further assistance.
Feb 18, 2011 | Jabra SP5050 Bluetooth Headset
Cannot figure out how to pair my jabra with my blackberry bold......both work....just wont connect
Go into your Blackberry's Bluetooth menu and after turning Bluetooth on, scroll down to Bluetooth Options and select the item. A new menu will appear, scroll to the item which allows you to set Bluetooth to be discoverable (by default, it's hidden). You may have to click on Options to find this menu. You can set it to be permanently discoverable (a security risk) or to be discoverable for just 2 minutes.
Turn on your Jabra headset by holding down the main button until the blue light stays on constantly.
Go back to your Blackberry Bluetooth menu and click "search devices". After your Jabra shows in the results list, select it to add it to your phone.
If prompted for a passcode enter either 0000 or 1111 (varies by Jabra model and by the country it's sold in).
Your Jabra should now be paired and the constant blue light will revert to an intemittently flashing blue.
If this has resolved your problem then please let me know by taking a moment to rate my answer. If not, then please add a comment and I shall attempt to assist you further when I'm next online.
Jul 22, 2010 | Jabra Bluetooth Headset with Adjustable...
How do u get the Jabra bluetooth into discoverable mode?
Hold down the main button until the light is solid blue. You then have less then 1 minute to pair.
Feb 16, 2010 | Jabra Bluetooth Headset with Adjustable...
I cannot get my Blackberry Storm to pair with my Jabra BT2070.
You have to first put the Headset into discoverable mode. According to the Jabra website, this is done by pressing and holding the end/mute button until the light comes on steady. Follow the procedure for your phone to pair a bluetooth device to it. The PIN code will be 0000.
Feb 07, 2010 | Jabra Bluetooth Headset with Adjustable...
My headset will not go into discoverable mode-- solid light
You have to hold the button for about 20 seconds until a solid blue light comes on.
Go to this site, and it will walk you through each step to connect your particular Jabra headset with your cellphone. Choose the headset, and then at the next page, choose your phone. Moving your mouse over each step will change the picture to what you should be seeing on your phone at each step.
http://jabra.pairx.co.uk/ Pls come back and let us know if this solved your problem.
Oct 08, 2009 | Jabra Bluetooth Headset with Adjustable...
Jabra BT3030 Device in Discoverable Mode?
Read the users manual(google is your friend)
But in case they drop support soon, turn the beastie on, press and hold the Vol+ and Answer Call buttons till the "on" light goes solid. You're now in discover mode.
May 15, 2009 | Jabra BT150 Wireless Headset
Get jabra in discoverable mode
ok i finally found out.. Turn on the jabra unit once on hold the answer button AND the volume up button at same time till u get solid blue light... It will flash like 8 times then go solid... At that point it can b found by all ur devices... the passcode is 0000... Enjoy
Apr 14, 2009 | Jabra BT350 Bluetooth Headset Headset
Initialy i had used my jabra bt350 with sony ericson but now it is not getting paired with my present mobile
dude first of all you have to reset the passcode of your jebra bt350 then connect it from your parents mobile.
how to reset----
Press settings/connections/bluetooth/check both boxes; turn on, and make discoverable/click devices tab/turn the jabra off/then hold the ear button till the blue light is solid (not blinking)/click new partnership on the phone/click 0000 for the passcode. it should hook up.
Mar 06, 2009 | Jabra BT350 Bluetooth Headset Headset
Make jabra bt 150 discoverable
within connections settings on your phone your jabra will always be discivered if you have set your bluetooth within phone to be on all the time, when you switch on head set it will be automatically picked up by your phone.hope this helps
Mar 02, 2009 | Jabra BT150 Wireless Headset
Jabra BT350 Bluetooth Headset Headset Logo
2,755 people viewed this question
Top Jabra Radio Communications Experts
TO Lady
Greg Cann
Greg Cann
Michael Vincent Cruz
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
