Question about Honda Garden
Need to know how to time honda harmony tiller
Had to take the engine apart to clean valve seat .went to put it back together and dont know how to set timing please help !! don .
  • 35 Answers
Well
heres your 4 strokes
1 intake down
2 compress up
3 power stroke down
4 exhaust up
if you start with you start with the piston just a couple of degrees past TDC (top dead center) so that it has started its return down
now set the valves so they are closed:
if you have an adjustable valve clearance's then your clearances should be noticeable like 10 thousands ( you should be able to move the lifter ( rocker arm ) and it will be loose up and down
with the spark plug still out; so you can see the piston coming to TDC and passing it to come down
turn the flywheel and watch the strokes and the condition of the valves
1 just past tdc, the intake valve opens and the piston goes down for the intake stroke
2. jst as the piston comes around BDC the intake valve should close and return to tdc with all valves closed ( the compression stroke )
3 just past TDC the ignition will fire and the piston will return down with both valves closed( the power stroke)
4 just past BDC the exhaust valve opend , the piston travels up and completes the exgaust stroke.
and after completing the exhause stroke and arriving at tdc the intake valve opens and you start over again 1,2,3,4
Posted on Apr 16, 2009
How do you replace the honda gc190 decompression mechanism
This is a problem with GC-160 and GC-190 engines on pressure washers, tillers, etc. Once they get some hours on them and as things seat in-wear in, they get to a point you can not pull the start cord. If you remove the spark plug, the engine turns easily. The valves need adjusted. The valves are set .005" to .006" off the seat. This allows enough compression release but the engine runs. I find the valves need adjusted every 25 hours, not the 100 hours Honda states.
Mar 16, 2013 | Karcher 2500 PSI Pressure Washer
I took my car seat apart to wash it and I don't know how to put it back together
We would advise you contact the manufacturer of the carseat as the likelihood is that the unit will need to be sent to specialist engineers to inspect and put back together correctly. Due to safety implications of the harness being incorrectly fitted it may not be possible to do this yourself.
Dec 19, 2012 | Baby Gear
Honda GC190 can't pull starter cord
This is a problem with GC-160 and GC-190 engines on pressure washers, tillers, etc. Once they get some hours on them and as things seat in-wear in, they get to a point you can not pull the start cord. If you remove the spark plug, the engine turns easily then the valves need adjusted. The valves are set .005" to .006" off the seat. This allows enough compression release but the engine runs. I find the valves need adjusted every 25 hours, not the 100 hours Honda states.
Aug 29, 2012 | Honda Garden
I have a honda fg-100 that the tillers do not rotate. I have taken the tran apart and all the geears look good. So i checked the clutch. I cant tell if the clutch is worn. How thick are the pads suposed...
I had the same problem. The gears inside the tiller housing are seized. I had my brother take it apart and that's what he saw. He cleaned it up really good (which un-seized the gears) then repacked it with some really good grease and slapped it back together. This thing is working like a charm. The repair shop said I'd be better off buying a new one for $300, yeah right..lmao!!
Jun 23, 2012 | Honda 25cc 4-cycle Mini Tiller
Hi tuffy wont start ,,,,,,,,,,,put gas in carb and it runs,,,,,,,,,all taken apart new diafram,,,,,,,,,cleaned with corb cleaner still wont start
make sure you cleaned the main jet and low speed jet good and make sure your needle and seat are in good condition some time the seats swell up do to bad gas. there for no gas gets through the seat and make sure your gas is clean w no water, if this isnt a needle and seat carb use regular wire and clean it good.
Jul 02, 2010 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Need specs.for Honda rototiller motor
Hello
The valve clearance is 0.08 for intake valve and 0.11 for exhaust valve . To do the timing you have to remove the spark plug and set the piston at top dead center (all the way up) and on the cam pulley you have a mark (like a triangle) that you have to align with the fan cover bolt hole . Hope this help
Jun 04, 2009 | Honda Garden
Honda fg 1oo won't start
It can be fixed take it to a small engine (lawnmower) shop
May 20, 2009 | Garden
Cannot keep tiller running
Could a gas/oil mix been used by mistake. When you cleaned carb did you also clean dusty air filter?? Try leaveing off filter first and run. Are you sure you are in "choke position" when engines seems to be running ok,be sure to double check yourself here. If engine runs ecelleant in "choke" sounds like your in "Run" position and positioning is problem not performance.
Please rate. Thanks jj505
Mar 28, 2009 | Garden
Garden Logo
435 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
