Lines thru photos
I'm trying to print photos, but its printing with lines thru photos. How can I print a clean photo.
  • 38 Answers
Try to clean the nozzles with the printer troubleshooter. It will force all the nozzles to print at maximum quality and will clean the clogged nozzles. If the procedure fail, then try again. This happens when you are not using the printer for long periods of time. If cleaning nozzles will not be helpful, then remove the color cartridge from his place and put it with the printing head in warm distilled water for 30 minutes.When the water is coloured by the ink, take the cartridge and touch the printing head with a soft paper towell. If a clear line of colour is printed on the towell, then is OK, put it back in the printer and print a test page. If is not , try again with patience.
Posted on Apr 14, 2009
Canon Pixma iP6000D prints white streaks thru the words
Run a self clean on the printer a jet may be clogged. print a test page to see if problem persists. If ink is low put a piece of electrical tape over the sensor of the ink cartridge and try again.
Hope this helps!
Aug 13, 2012 | Canon Pixma iP6000D InkJet Photo Printer
I have the same problem vertical line epsonr230
get your printer service and get new INK jets mean Cartage for your printer thank you it will get no vertical lines then .. it is caused when cartages are leaking..
Jun 25, 2009 | Epson STYLUS R230 InkJet Photo Printer
Lines throughtout photos
It's probably dust built up on the rollers, I suggest trying to print a cleaning page. Refer to your manual for instructions.
Apr 30, 2009 | Office Equipment & Supplies
Canon i9900 isn't printing photo magenta
Use denatured alcohol to soak the print head. Then use suction to draw the alcohol back thru to the foam ports where the ink cartridges rest. Continue until the alcohol runs clear. Then use water and then repeat with alcohol. Allow to dry and re-install in printer. Use new ink cartridges when re-starting printing.
Dec 31, 2008 | Canon i9900 InkJet Photo Printer
My photo prints have lines across them?!
the glossy paper you are using (hp) is smearing the ink... there is now ink on the feed rollers and you need to get in there and clean it all up with alcohol...also run epson matt paper for a few prints to get the color to lay down ..good luck
Oct 08, 2008 | Epson RX620 All-In-One InkJet Photo...
Kodak 5300 Series not a year old
try to do this first, try first to upgrade the firmware of your printer, by clicking help in your kodak AIO Home Center, then under General Links, click on maintenance, then under maintenance, click on firmware upgrade.
after the upgrade is complete, try to remove and then reseat both the ink cartridges. then calibrate your printer. and then clean the printhead deep clean. then print a demo page to see if there is any improvement in your printout.
but if your still experiencing the same problem
you can call to Technical Support of kodak 1-800-421-6699 7am to 12am ET
hope this will help
Sep 21, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Streaky print out from canon Pixma mp830 all in one
I just bought a PIXMA iP3500. The 1st 2 photos I printed had veritcal White lines. I did a Nozzle Check and Alligned the Print head after the 1st photo printed. The 2nd still had the lines. Then I changed brands of Glossy Photo Paper and tried a 3rd time. This time I noticed that it printed much slower and it turned out just fine. Information says that you should have the settings at "high" not "standard". Double check that this hasn't inadvertently changed back to Standard. Gator
Dec 07, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Epson stylus photo 810 won't print
Is it just not printing on the paper and feeding it thru, or will it just not do anything? I need more info?
Dec 05, 2007 | Epson Stylus Photo 810 InkJet Printer
Blue lines all over the printing
Did u clean the print nozzle's as well? If that does not solve your problem, you should try and replace the cartridge. (Colour in case of blue lines and black in case of black lines)
Jan 22, 2007 | Epson Stylus Photo 1290 InkJet Printer
158 people viewed this question
k24674
jasbo
jasbo
