Question about Microsoft Zune 2nd Generation Digital Media Player
My zune was shocked
I was taking a blanket off of my couch and in the process my zune got shocked by an electric current. Now my zune doesn't register on my computer. How do i fix my zune. Help my please!!!
I tried to order 2Large Dog Blankets
Register at the site. Then you will be able to use your credit/debit cards to process an order. This site offers personalized dog blankets. There is not reason I can think of that would prevent the website from working with your devices.
large dog blanket
Aug 21, 2017 | Dogs
Why only one side get hot
These are made with a wire in them that heats up. Yours probably has a wire for each side, and one has gone bad. DO NOT continue to use it. I suggest you take it to a qualified repair technician or replace it. It could cause a fire or electric shock.
Dec 07, 2015 | Sunbeam California King Arlington Heated...
How do I restore my devices firmware for my zune 30gb
How to restore your Zune device software:------------
When you restore your Zune device software, the startup partition and the data partition are removed and rebuilt. In addition to removing the Zune device software, this process also erases all audio, videos, podcasts, and pictures that are stored on the Zune device.
Warning To restore the Zune device software, you must have a Windows-based computer that has an Internet connection. That computer must have the Zune software installed. And you must be able to connect the Zune device to a USB port on that computer by using a Zune Sync Cable. Do not perform the following steps if you do not have any one or more of these things immediately available.
After you start to restore the Zune device software, you cannot again use the device until you complete all the steps. You will not receive any confirmation or warning on the Zune device after you start the following procedure.
To restore the Zune device software, follow these steps:
1. Set the Hold Switch to unlocked.
2. Press and hold the Back button at the same time as you press and hold the top of the Zune Pad. When the Zune device begins to power up, release the buttons.
3. Immediately after you release the buttons in step 2, press and hold the following special button combination, depending on your Zune model:• If you have the 4GB Zune, the 8GB Zune, or the 80GB Zune, immediately press and hold the Back button at the same time as you press both the left side of the Zune Pad and the Play/Pause button. Continue to hold these buttons until your Zune device restarts and "Please wait" appears on the screen.
• If you have the 30GB Zune, immediately press and hold the Back button at the same time as you press both the left side of the Zune pad and the center of the Zune pad. Continue to hold these buttons until your Zune device restarts and "Please wait" appears on the screen.
Note "Clearing contents. Please wait" appears, followed by “Connect Zune to your PC."
4. After “Connect Zune to your PC” appears, connect the Zune device to the computer that has the current Zune software installed, and then update the device to the current Zune device software.
----------- Click this link directly for more troubleshooting:-- http://support.microsoft.com/kb/944909 -------- If error problem while restoring then click this link below:-- http://support.microsoft.com/kb/945278 ---------- Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 03, 2010 | Vacuums
3 red lights
Okay, this is an easy fix. First off take your hard drive out of the xbox, than take your cords out of the back, but keep the main power cord in, make sure all of your games are taken out of the xbox. Now grab 1 or 2 blankets from a bed or extra blankets on your couch. Once you're done with that wrap them around your xbox when its turned on, make sure there is one or two holes so a little bit of heat can escape. After 5 - 20 minuets, take your xbox out of the blankets and turn it off for about 3 minuets, you can put your cords and hard drive into the xbox while your waiting, and there you go your xbox is perfectly fine to play for about 15 - 20 hours, but sooner or later it's going to bug you so much doing this over and over that your just going to want to send it in. hope i helped
Feb 20, 2010 | Microsoft Xbox 360 Console
I got shocked when i picked up my zune and now i get a lit up blank screen help?
Try rebooting the Zune by pressing back button and up button at the same time for 10 seconds and see if it reboots. Hopefully something didn't fry when you got shocked.
Oct 04, 2009 | Microsoft Zune JS8-00001 Digital Media...
Red and green light flashing and wont work
PROBABLY A SHORT IN THE BANKET ITSELF AND IT SHUTS OFF TO PREVENT SHOCK OR FIRE.
Apr 27, 2009 | Washing Machines
Freezing
See teh Zun.net site The 30 Gig Zunes have a bug in how it processes the date. Per MS it will fix its self 1 Jan 2009
http://forums.zune.net/ShowPost.aspx?PostID=408989
Dec 31, 2008 | Microsoft Zune JS8-00001 Digital Media...
Microsoft Zune 2nd Generation Digital Media Player Logo
23 people viewed this question
Top Microsoft Audio Players & Recorders Experts
john h
Ap12
Ap12
Are you a Microsoft Audio Player and Recorder Expert? Answer questions, earn points and help others
