Question about Camping, Backpacking & Hiking
Charging an Innovage outdoor wind up 5 led lantern and radio
I bought a second hand Innovage outdoor wind up 5 led lantern and radio. It didn't come with a box or any instructions. It works perfectly, just not sure how long I should charge it for to get the best results from the lantern.
If anyone could tell me a safe charging time for the lantern I will be most grateful.
Many thanks
2 Suggested Answers
  • 973 Answers
SOURCE: lantern doesn't charge using the hand crank dynamo
You most likely need a new battery, you can purchase one from Black and Decker, here is the link
http://www.dewaltservicenet.com/Products/ProductDetails.aspx?pid=68217&tid=15945
Posted on Jun 18, 2010
Where can I get a replacement battery for the trail tracker, emergency radio lantern, yellow?
Trail Tracker Sport Lantern/Weather Radio doesn't charge using the hand crank dynamo for my Power on Board Trail Tracker lantern/radio, You most likely need a new battery, you can purchase one from Black...
More information please open this link:-- Best Manuals
Jun 17, 2016 | Cars & Trucks
Tip
LANTERN OPERATION 1. PUSH THE LANTFRN/FLASHSLIGHT/OFF (11) TO ?LANTERN 1+2? OR...
LANTERN OPERATION
1. PUSH THE LANTFRN/FLASHSLIGHT/OFF (11) TO “LANTERN 1+2” OR “LANTERN I”. THE LANTERN WILL BE TURNED ON.
2. PUSH THE LANTERN/FLASHLIGHT/OFF (11) TO “FLASHLIGHT’ TO TURN ON I’HE FRONT LIGHT.
3. PUSH THE LANTERN/FLASHLIGHT/OFF (11) TO “OFF’ THEN BOTII LANTERN AND FLASHLIGHT WILL BE TURNED OFF.
4. PUSH THE BLINKER/SIREN/OFF (12) TO “BLINKER” AND THE FLASH LIGHT (10) WILL BLINK.
5. PUSH THE BLINKER/SIREN/OFF (12) TO “SIREN” AND THE SIREN WILL BE TURNED ON.
6. PUSH THE BLINKER/SIREN/OFF (12) TO “OFF” AND BOTH THE FLASH LIGHT (10) AND THE SIREN WILL BE TURNED OFF.
7. PULL OUT THE LANTERN (16) AND ADJUST THE LANTERN ANGLE.
on Mar 05, 2009 | Jeep KNG36-JXLWBC AM/FM/Weather Radio
I have a Vector VEC1378 rechargeable lantern - does this lantern also take a battery or must it be electrically charged only? If so, how do you open the battery case. Thank you.
I have the same and bought a $20 6v lead acid replacement from the Batteries Store. There are 4 small screws hidden under the foam rubber ring pad on the bottom. Very easy to open and swap out the battery. That said if you want to sell me your old lantern as is, I would enjoy having a second one for camping. Thanks and good luck. I can be reached at rudock1 at yahoo dot com. -Billy
Jul 25, 2011 | Vector Sport & Outdoor - Others
Coleman rechargable lantern Model 5327A750. Have not used it in a while have left it on charge for over 24 hours. the night light works but the main light does not go on. Replaced the bulb and still...
just read the charging instructions. Charge for 16-18 hours. If stored for more than 6 months recharge for the full 16 hours. Do not leave the lantern on after the battery has stopped, has overdischarging the battery can cause problems in recharging to a full charge. If this does happen, switch lantern to off and recharge for 40 hours.YES 40 hours. Only the LED is the only light to be used while charging. If you hane the other light on hi or low the battery does not charge.
Hope this helps
Oct 24, 2010 | Sport & Outdoor - Others
I have a b&q rechargeable 1m candle power lantern, how long do I leave it on charge from being flat as the charger unit does not have a led incorporated in it.
Probably between 3 to 5 hours.
Check battery regularly. It should be warm while charging. When it begins to get hot it is charged. If you charge the battery for longer, there is the increased danger of fire or leakage from the battery.
Note how long the battery has been charged for and during for future charges, reduce the charging time.
NiCad batteries should be run flat before being recharged rather than being topped up in order to get maximum life out of the batteries. This is less critical with NiMh batteries.
Sep 28, 2010 | General Hand Tools
Coleman lantern fan am/fm radio
This lantern/fan/radio combination does not use/accept batteries. It is recharged using the black A/C adapter provided with the lantern. I hope you received the adapter with the lantern when you bought it @ the garage sale? You plug the adapter into the little circular opening just above the round spotlight on the lantern. Hope this helps!
Aug 22, 2008 | Coleman Lantern Fan Radio (841.321) AM/FM
Ac power adapter
Both at Walmart and Radio Shack you can find universal adapters that allow you to change the connector and voltage to fit the device. Try one of these, you can usually pick one up for under $10.
Nov 26, 2007 | Computers & Internet
Camping, Backpacking & Hiking Logo
322 people viewed this question
Top Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
