Question about Kenwood KDC-MP232 CD Player
Can't get into AUX source
I tried to input my iPod through the aux inputs in the back. The receiver will not chance to AUX source. I tap the source button and it cycles, Tuner-CD-Standby, but no AUX. If the iPod is playing I can hear it in the rear speakers when in "Tuner" mode, and still hear the radio in the front and rear speakers at the same time. Really weird. Any help is appreciated.
  • cjmaz88 Jul 02, 2008
    I'm having the same problem, when i press menu (while in standby) there is no option to turn on the aux. but i have it all connected.
  • 6 Answers
Try putting the unit in standby via the src button, before then enter the menu and select or switch on aux1...then press menu again to store it...it should then have an aux option via the src button when the unit is next activated.
Posted on Nov 04, 2007
  • 626 Answers
Are you sure it is an AUX input? According to the Manufacturers Specs, the AUX, is an optional accessory. There is a Pre-Amp connection, which would be an output, hence causing the problem you are having. Best of Luck.
Posted on Sep 14, 2007
SOURCE:
HOW TO USE AUX
AUX is the auxillary terminal to connect any input to the set. You must connect to the AUX input an IPOD or any device , use the conttrol panel to switch o the AUX and play the source.
Oct 28, 2010 | Sony CDX-F5510 CD Player
Cannot find the choice for aux input in order to attach iPod
put on standby mode. then hold in "menu" button.
go through the list by pushing the right hand trigger down. there should be an option aux1. change this to turn on and aux input is on the source option.
Jan 25, 2010 | Kenwood KDC-W3037A CD-receiver,...
Can't get auxiliary to work on Pioneer Mosfet Head unit 50x4
you have to turn the AUX input on through the function menu which can be accessed by following these steps
1. with the unit on. press and hold the source button unitl the unit turns of (or goes into demo mode, which is fine)
2. depending on the model that you have, you will have to press and hold the
(volume button or the audio button), until a menu is displayed.
3 . toggle through until you find AUX 1 and AUX 2. i would turn them both on and see which one you have plugged into, then you can go back and turn the other off.
4. once you have change it to ON. press the source button to turn on. the aux option should now be in your source options.
5. also, while on AUX, you can go into the audio settings and turn up the SLA (sound level adjustment) to +4
hope this helps
Aug 26, 2009 | Pioneer 50W x 4 MOSFET Apple iPod...
Can i use mp3 player with panaconic cg-c1300u?
If your audio system has aux input then buy a compactible cable to connect your 3.5mm output oprt to the audio systems aux input. then change the audio source is Aux input in your audio system and play the audio using our ipod.
Aug 19, 2009 | Panasonic CQ-C1300U CD Player
MP3, IPOD, CD doesn't appear when I press "Source"
Easy.
If you read your owner's maunal, page 26, the USB is designed for a flash drive (up to 4GB), not an Ipod.
If you would like to play your iPOD, purchase the IPC008 (Ipod Lead) and you're done!
Feb 24, 2009 | Eclipse CD1200 Car CD/ MP3 Player
Pioneer KEH-P4830R connection to AUX source
Hi. Sorry, I can't actually solve this one for you but was hoping you may be able to look in the manual and let me know which model number CD changers are compatible with this headunit. We don't have the manual and so far have been unable to find the answer anywhere so your help would be much appreciated.
Thanks
Lee
Jan 17, 2009 | Pioneer KEH-P4020 Cassette Player
Mp3 to aux input
Try putting the unit in standby via the "SRC" button FIRST..., then press the menu button and cycle through to the "AUX 1" option and activate this....then press menu button again. When the unit is next switched on, you should have an "AUX" option accessible via the "SRC" button which will cycle through all of the availale modes ....standby-tuner-cd-aux etc etc.
Oct 31, 2007 | Kenwood Sirius KDC-MP522 CD Player
Connect ipod to cd player wit built in aux input.
VERY SIMPLE SOLUTION FOR DEH-P5800MP!!!!!!
Turn unit off by holding the Source (volume knob) button until power is off.
Now, hold down the Function button (FUNC) until the unit turns on. You will now be in the Initial Settings menu, a special menu. Press the Function button (FUNC) again until you see the word AUX, press up to enable it, then press the Source (volume knob) button until you see AUX. It works now, congratulations.
Sep 22, 2007 | Car Audio & Video
Auxilary RCA inputs have no volume control
Your problem stems from the fact that the CDA-7892 is not equipped with an RCA aux-input jack. If you're plugged into RCA connectors at the back of the head unit, they're outputs, not inputs. The sound you hear is just feeding back through the outputs and into the head unit's amplifier. If you want to play your iPod through this head unit, you need to purchase either the auxiliary input adapter (KCA-121B) or iPod adapter (KCA-420i).
Mar 15, 2007 | Alpine CDA-7892 CD Player
AUX inputs
Turn the ignition key to on or accessory position, turn the stereo off, then hold the function key for a couple seconds, the stereo will turn on and you scroll through the menu with the left and right arrow buttons and change settings with the up and down buttons
Feb 25, 2007 | Pioneer DEH-P6800MP CD Player
Kenwood KDC-MP232 CD Player Logo
745 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Mike Duncan
Mike Duncan
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
