Question about Echo 3 TE SL7 3 New Electric Scooter by Shoprider
Stalling The scooter will run fin for about 10 mins the it will start to stall out. it becomes hard to start and will only run for a couple of mins before stalling out again. it will some times take 5 to 10 mins to get scooter started after it stalss out
    Problem Solver:
  • 11 Answers
Check your batteries, they might be ready to die. Stalling is a sign your are not getting enough power to the scooter and when you do, it runs until they run low again. Kinda like a cell phone batt, ones it dies and you wait awhile you can get it started but only for a couple of minutes before dying again.
Posted on Apr 17, 2009
Last year I had a similar experience.
In my case, the problem was with the reset fuse ( the reset button under the seat).
It was very easy and quick to replace.
THE ONLY WARNING HERE IS : BUY AN EQUIVALENT PART FROM A DEALER SO YOUR SURE TO BE WELL PROTECTED.
Try at your own risk or contact a qualified engineer.
The OldRider
Posted on Apr 14, 2009
I have a 03 kia sorento that i just changed the timing belt and water pump on. It drove fine for about 10 mins but then stalled. After 15 mins it starts, runs for 10 mins, rough again and stalls out.
run fault codes
check for wiring on crank shaft position sensor or cam position sensor/s
it will be something that was affected by the belt replacement procedure
Feb 14, 2017 | Kia Cars & Trucks
It will crank and run good for 10 minutes and shut off. Once it shuts off when you restart it, it will only run for a couple of minutes and shut off again ?
I would start by getting a can of carburetor cleaner and have it 'at the ready' and try the 'start, run stall, start run stall' operation again. Only THIS time, once the engine begins to stall, give it a couple of quick shots of the cleaner into the air filter to see if it stays running on the cleaner.
If it does, then it's still a fuel problem. If it doesn't, then it probably an ignition problem. I would be sort of leaning towards the ignition coil getting weak. The reason I'm saying that is your statement about it running (I'm assuming cold start) for at first, 10 minutes then it stalls. Start it again and it runs for a couple of minutes and stalls again.
This could possibly be from the coil getting warm/hot and not producing the needed spark. After a 10 minute run it simply gets too hot and stalls the engine. After the next restart, the coil is already warm from the engine and so it don't take as long for the coil to get hot and stall the engine again.
Hope this makes sense and helps you out.
Apr 25, 2015 | Honda Gx340 Gas Engine 11hp Motor Pressure...
2003 crown victoria cranks wont start, was running fine, just cut out.never started again
As with any no-start situation, you need to know if you have spark to the plugs, fuel to the injectors, and normal compression to proceed.
Jan 28, 2013 | 2003 Ford Crown Victoria
Accent 2000 runs well then stalls once hot and will not start till cooled off
Check your coolant level and overflow bottle for proper fill. Or try running it With radiator cap loose to see if it still stalls. If it still stalls and coolant levels are good you need to check temp sensor. May be more than One. If you did install a new one, it may have been faulty or damaged. If all that fails then try an idle positioning sensor. The spring may be worn.
Sep 24, 2012 | Cars & Trucks
I have a scooter a bms teamguys 150cc scooter it is impossible to start in the morning or after its been sitting for a few hours you have to use starter fluid to get it going but once its warmed up it runs...
Could just be cold blooded. Does sound like fuel is being primed to be able to start. if a person has to use starter fluid, then that means the carb is not getting enough gas at start up. Carb will most likely need to be pulled apart and soaked in solvent or equivelant for couple hours. Make sure float is adjusted properly and fuel filter is clean
Oct 10, 2009 | Yumbo Dakar 200 Motorcycles
Suburban stalls while driving after running for 15-30 minutes. After letting it sit for 5-10 min it runs fine for another 5-10 minutes, then starts doing it all over again.
a bad crank sensor can cause this. shuts off while going down road, and will start about 10 min, later with no problems runs fine until it quits again. hope this helps,
Oct 07, 2009 | Chevrolet Suburban 1500 Cars & Trucks
2000 durango 5.2 cold starts, engine stalls or rpm surging
i know this may sound stupid but if your battery is old or a little weak on this vehicle the idle air control solenoid will act speradicley hunting for were it should be and the vehicle will stall.replace battery
Jan 31, 2009 | 2000 Dodge Durango
Stalling runs ok then cuts out
sounds like the timeing belt is bad.
Jan 09, 2009 | 1996 Saab 900
Car starts then stalls once the engine warms up.
You need new timing belt and gears. Buicks gears are made of plastic, and become a big glob. Nothing for the timing belt to grab onto.
Sep 12, 2008 | 1992 Buick Riviera
Echo 3 TE SL7 3 New Electric Scooter by Shoprider Logo
452 people viewed this question
Top Echo Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you an Echo Health and Beauty Expert? Answer questions, earn points and help others
