Question about Canon NP 6035 Copier
Copier not working: Flashing E 007 Code
We moved the copier from one location and now it will not work. It is flashing an E 007 Code. I followed the suggestions in the Operator's Manual but it is not working.
  • 3 Answers
You need to re set it in service mode its long winded.if it does not work you will need parts the copier is old and parts are no longer available from canon.its a fuser fault.if you need any help no proplem.i can tell you to re set it and which parts you may need.i dont think i can get them.i have not seen that modle for 6 years at least.but im fully canon trained on it.good luck
Posted on Apr 14, 2009
My copier is flashing the code H4
I have a tip posted here on Fixya that resolves this problem easily.
Here is the link:
http://www.fixya.com/support/r4376849-sharp_al_series_copier_h3_h_3_code_reset
If it works for you then please return here and provide feedback for me that I was helpful.
Thanks
Jul 25, 2010 | Sharp AL 1631 Copier
Error code on display, L1 or 1L flashing. What is
L1 or L1-00 indicates Scanner movement failure. The scanner is the part under the glass that lights up and moves back and forth. So if you lift up the feeder so you can see the glass, turn the machine off for a few seconds then back on. Watch the movement of the scanner. It should move right and inch or two then back to the left. If all goes well the copier should come to ready. Lay a piece of paper on the glass and press the print button to watch the scanner movement. If it binds up or does not scan correctly there are 2 possibilities.
1) your scanner lock is engaged and is preventing the scanner from moving. Check the clear plastic dial located under the far left upper side of the copier, near where the paper exits the machine. Make sure it is in the unlocked position.
2) Your scanner rail is dirty and dry. This rail can be seen under the glass towards the back of the copier. The scanner rides on this rail. It is very common for these to get dirty and for the grease to dry up causing the scanner to freeze up on the rail. The glass must be removed and the rail cleaned and lubricated.
Just power off then on the copier to reset.
Jul 15, 2010 | Sharp AL 1631 Copier
Copier flashing "H4" code
Hello sir;Follow these steps within 4 seconds; press 'clear', "exposure" ,"clear" "exposure" then enter 14 hit print, should be OK.
Jan 30, 2010 | Sharp AL 1631 Copier
Xerox XC 1045 has a flashing H 4 error.
elem_1_spacer.gif Performing a Fault Reset 14 will reset your copier and will help to clear error codes.
  1. Turn the power off.
  2. Locate the Clear Button, which is grey in color, in the upper right corner above the green Start Button.
  3. Locate the Auto Button the lower left corner of the Control Panel.
  4. Turn the power back on.
  5. Press the buttons in the following sequence, releasing each button after each time you press it: [Clear], [Auto], [Clear], [Auto]. Every light on the Control Panel should go out, and the error code should clear.
  6. If the error code has not cleared, wait a few seconds then repeat Steps 1 through 5.
  7. Program the copier as if you were going to make 14 copies.
  8. Press the green [Start] button to store the reset code. The copier will return to the ready position.
  9. Run a test copy.
Jul 01, 2009 | Xerox Office Equipment & Supplies
Error code 1 and L flashing alternately
Hello sir; I like you check the scanner unit, the mirrow does move out when you make a copy, you may easy to find out what cause the mirrow not move out.
Jun 03, 2009 | Sharp AR-5316 Advanced Digital Imager...
Copier flashing between L and 1.
Hello sir;the trouble code display, means the scan unit have problem, check the scan unit does it move forward and backward is ok? or mirror motor not working final check out the scan cable is come off ?
Mar 19, 2009 | Sharp AL-1641CS Copier
L1 is flashing on my copier
Hello, Please check out the following website and see if you can find your error code:  http://www.copier-help.com/copier-help/
Hope this helps. Good luck
Dec 11, 2008 | Sharp AL-1217 Copier
Xerox 3001 Code A6
A codes are up top. Make sure the switches are not stuck down or broken. Test the machine in the long document mode, that asks for the paper first then the original. Usually an easy fix.
Aug 29, 2008 | Xerox 3001 Copier
Di251 error code
most popular solution is you resigin your job hahahah
Jul 11, 2008 | Konica Minolta DiALTA Di200 Copier
Canon NP 6035 Copier Logo
80 people viewed this question
old marine
old marine
