Question about Philips 51PW9303 51" Rear Projection HDTV-Ready Television
Flyback transformer bad
Wanting to know how to replace the flyback transformer safely. Can't seem to get it out. How can I remove it and can I do it by myself. Tv has been off for 3 days so shouldn't have any current. don't want to have to higher repair man.
    Genius:
  • 1,153 Answers
Still Caps can hold charge for longer than that. Do you know for sure this is the problem. If not then, you maybe shooting yourself in the foot sort of speak. You would need a desoldering tool, iron or gun. Have you check the cost, because most flyback for projection cost maybe over 100. So it maybe easier and safer to call PTS 18008447871 and give them the tv model and what the problem is.
Posted on Sep 14, 2007
SOURCE:
Flyback no. of cmt 2198
The B+ of your CMT 2198 TV seems to be about 95V.
• Have a time to read about these tip:
How to test Flyback Transformer Without taking it off the Board
While we search for your flyback transformer T751 part number
we will let you know.. .
Jul 31, 2012 | Hitachi CMT-2195 21" TV
I just want to know, what is the part number of flyback transformer on my teli panasonic TC-20P1.
Part number is required only if you are ordering with the company and here in this case you can specify the model number as the data base is available with them.
Otherwise the flyback/ line output transformer can be removed and taken to any spares shop to be identified for the replacement.
Jun 15, 2011 | Panasonic Televison & Video
RCA 52in. Projection TV D52W19B does anyone
Hello butmommy03,
This is the procedure but first I must warn you. You are dealing with one of the most dangerous parts of a TV The High Voltage anode or the CRT and the flyback transformer. That being said this is what you have to do:
1) unplug the TV from the wall or power strip.
2) take the back of the TV, and find the High voltage trippler and using a screwdriver grounded by a clip-lead to the grounding strip touch it to the exposed metal of the input to the High Voltage trippler.
3) using a soldering iron de-solder and remove the wire from the HV trippler.
4) Once this is done, angle the chassis to expose the bottom of the Deflection board, if this is no possible you will have to remove the deflection board to get a look at the bottom, once this is done and you can view the bottom of the board using a soldering iron and a de-soldering pump you can remove the solder from around the pins of the flyback transformer about 10 pins in all. Then remove the screws that hold the flyback in place. this is the procedure you requested,
However again I must ask you not to do this yourself and to get a qualified TV technician to troubleshoot this TV for you.
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Jun 27, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Flyback transformer and horizontal output transistor change out
There is a little loose sleeve at the transformer. It can be pulled out, but it is best to squeeze the sides through hole on each side of the terminal to remove the sleeve. The wire just comes out with a small pull afetr the sleeve is removed. Good luck.
Dec 20, 2008 | RCA Televison & Video
I am replacing the flyback transformer
You should post here pictures of old transformer and point out what wire you want to remove, then I can give you an idea what to do as flyback transformer is not in front of me.
Oct 27, 2008 | RCA HD52W59 HDTV Projection Television
RCA D52W19 Flyback Transformer Replacment guide
The picture tube can hold a charge.with a jumper connect one end to the ground wire around the picture tub. attach the other end to a screw driver and push it under the red cap on the picture tub. that will discharge it.. Remove the transformer from the board by disordering all connections. Insert the new fly and solder. from the old transformer follow the two leads on the side to the screen board at the picture tube. one at a time connect the new transformer leads to the socket and board. part number for the FBT 259296 $50.39 from www.the parts store
Mar 21, 2008 | Televison & Video
Flyback Transformer replacement instructions?
remove solder from all pins and squeeze clips to remove...
Oct 12, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Repair shop says Flyback Transformer needs replacement
If you know what you are doing, and you have a good (de)solderstation, you can repaire it yourself, but you don't know if it for sure the transformer. since you did not find the problem yourself, suppose you replace the transformer and your TV does not work !? Even when you repair it yourself, the repair guy shall charge you the cost for his time (I don't know the exact english word for his time checking the TV). And I suppose there is a warranty for his repair. So...
Sep 11, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
No picture, sound ok.
When you change the flyback and the HOT you are supose to replace a small capacitor that came with the flyback and also the small coil l401 that connects the hot base to the horiz. driver transformer secondary is supose to be taken out, the leads scrapped off of insulation and resoldered into place.
Sep 25, 2006 | RCA F32444 32" TV
Chassis removal
all the projection tv are made with removal chassis in mind becouse thats the only parts you carry to the shop remove the upper ruber tap and gentely but firme pull the cable..be carefull tvs have verry dangerous sites, specialy in that area..good luck
Aug 05, 2006 | Mitsubishi WT-46807 46" Rear Projection...
Philips 51PW9303 51" Rear Projection HDTV-Ready Television Logo
75 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
