Question about Garden
Starts idles for a minute or two then when you try to give it gas or change it from cold to warm shuts off
  • 23 Answers
SOURCE: mercedes 190e 2.6 auto,starts fine
MAY REQUIRER THROTTLE BODY CLEAN UP,OR FUEL CLEANER IN THE SYSTEM...
Posted on Nov 15, 2008
tepfy
  • 319 Answers
SOURCE: S10 has very high idle when cold and sticks to the gas when warm
you need to replace the throtle body controll sensor. Also you may want to make sure all your linkage from the pedal to the throtle body is cleaned and lubed correctly. While playing in this direct area. Your throtle body is only 4 bolts away. Why not get some carb cleaner and get to know your truck just a litle more.
If this is a carborator, then you need to turn my warmup idle down. there are 2 sets of idles on carborators. the one to warm up the engine, automatic choke or pin settings. Get a Chilton, find out which idles pin is for what. and play a litle bit.
I think you have a throtle body so I would also check the automatic air intake sensor. It could be going bad. Check your filter and make sure its clean.
hope all this helps.
tepfy
Posted on Feb 27, 2009
rockitman187
  • 2559 Answers
SOURCE: Dodge ram rough cold start idle
Change the EGR valve.
Posted on May 05, 2009
  • 3567 Answers
SOURCE: I have a Roketa 150cc Sicily Scooter (2006). It
Here's the deal. I have never even heard of your bike brand but I have 18 years in bike repair. If you promise not to give me anything less than a "helpful" rating I will tell you how to do the fix based on the assumption that the bike has a standard carb and not a CV carb. The standard carb has a top "cap" that unscrews from the center of the carb body.
ALWAYS have a fire extinguisher on hand when working on carburetors.
Remove the water trap bowl at the bottom of the petcock, (gas valve). Is there any water or trash in the bowl? Drain a cup of gas from the tank. Is there any water or trash in the cup? Dump it, clean it and re-mount it, ( not all bikes have a water trap bowl ).
Drain the carburetor. There should be a screw on the lower side or bottom of the carb float bowl. Remove the screw then replace it after the fuel drains. Turn the gas back on and wait a minute for the carb to fill with gas. If the bike doesn't start and run properly then shut off the gas and remove the carburetor from the engine. Now unscrew the top cap and pull the slide out of the throat of the carb. When you re-install the slide, be sure the long notch on the side of the slide lines up with the small pin inside the throat of the carb.
Remove the float bowl and clean the entire carb with a spray carb cleaner from the auto parts store. Wear protective goggles to avoid getting spray in your eyes. Spray into all the little airways and fittings in the carb. Remove the idle screw and the air screw on the outside throat of the
carb and spray into the screw holes as well.
< < READ CLOSELY > >
Be sure to put these two screws back in the same hole they came out of. IMPORTANT > do not tighten these two adjusters down. Only screw these in until they LIGHTLY seat. Now turn each adjuster one and one half turns outward. Before putting the slide back in the throat of the carb, move the clip on the jet needle one notch lower. Put the rest of the
carb back together, clean the air filter and install the carb. Let the float bowl fill then start the engine. This process should get you back on the road.
Please rate this solution. Thanks!
Posted on Jun 09, 2009
SOURCE: My '01 Tribute V6 3.0 has a rough idle at a cold
Don't waste your time. Have the intake manifold gaskets (upper and lower) replaced. Check all vacuum lines for leaks. Clamp all vacuum hose connections.
Do NOT replace any sensors unless the computer codes indicate.
THIS WILL FIX YOUR PROBLEM!
Posted on Jan 15, 2010
1996 mercedes c280 dies when put in drive
Engine stalls or RPM fluctuates at idle up and down or dies near idle.
This problem is commonly caused by a dirty automatic idle speed control valve and throttle valve but always run a OBD2 fault code as well as the cleaning procedure. Buy a can of throttle valve cleaner (do not use carburetor spray cleaner!) from NAPA or Carquest (made by CRC chemicals) and spray it into the air intake while the engine is running, use up about 1/2 the can, engine will try to stall hold the speed up, shut it down and let it soak for 30 minutes, restart and blow out the remaining fluid, shut it down and disconnect the negative battery cable for 5 Min's to reset the base idle control
Oct 15, 2012 | 1996 Mercedes-Benz C-Class
Hard starting and rough idle
The idle valve is the most common problem for hard starting in cold weather. I would recommend having it removed and inspected for contamination. Sometimes they can be cleaned out. If it has heavy carbon buildup, you may have to replace it. (if the idle valve is removed, the shutter inside should easily move when you rotate it from side to side and you can also look at it with a flashlight for a visual inspection.
Feb 20, 2012 | 1997 BMW 328
I have a 1992 Honda prelude that when it starts up it idles at 1100rpms fine but after it runs for like five minutes it drops idle to 900rpms and as soon as I hit the gas it stalls out..... It starts right...
on a cold start car will idle fast till it warms up then will drop to about 1000 rpm, try increacing idle speed so when it warms and drops it should stay idleing
Feb 12, 2012 | 1992 Honda Prelude
Vibration at idle
it may be idle control sensor or a bad mas air flow sensor--maf sensor in otherwords. or could be engine misfire at cold temp. start. only time when cold? or does run better when warm? try warming engine to operating temperature before driving,if problem removes it's self after warm up,up grade gas to 93 octane for 1 tank full. then see if problem goes away. it's cold where you are right? if so the fuel needs to be at least midgrade 89 octane fuel because 87 octane fuel will not start your honda correctly at cold temps. in cold weather 93 or super gas octane will start ,no problem,low octane fuel sometimes gels, or freezes at low temps. if in warm climate, change the fuel filter, add fuel injector cleaner to your fuel tank[preferablly lucas fuel treatment] this will lube your fuel injectors and give better fuel mileage. thank you for choosing fixya.com
Jan 04, 2011 | 2002 Honda Accord
My 98 Honda Accord Vtec 4cyl. eng is starting fine, but after start the idle dips a few times and regains for approx. 3min. If I drive without warming up the car will hesitate and the gas pedal will delay...
Seems like the coolant temperature sensor is giving the computer erroneous readings, and it is not adjusting the fuel mixture properly for cold engine operations. You should have the check engine light on, indicating this malfunction. The idle fluctuations are normal. The engine is trying to die, from the improper cold mixture, and the computer (ECM), recognizing low idle speed, is sending it back up. Another possibilty is that the butterfly on the throttle body is not closing completely, to allow richer mixture needed for cold starts.
Sep 09, 2010 | 1998 Honda Accord
How much warm up time does a dodge sprinter 2500 diesiel require in the winter time?
At idle it can take hours to fully warm up
If your concerned about driving it right away after starting, not a big issue.....start, let it warm a min or two then drive.
Diesels warm slower than gas engines, and they take longer to get warm enough to give you heat untill fully warmed up.
Normally you should see good temp and good heat after driving about 15 minutes after the first cold start of the day.
Feb 02, 2010 | Dodge Sprinter
When i start the atv with the choke it stays on , but when the atv is started without the choke it shuts off. My atv is a Yamaha grizzly
The choke should only be used when starting cold. After the bike is warmed up you can turn the choke off. If it keeps shutting off after being warmed up for a few minutes, then check your gas/air ratio for the idle air mixture knob. Loosen it up 1/4 turn to allow more gas to flow.
Oct 20, 2009 | 2004 Yamaha YZ 450 F
1991 dodge colt won't idle when engine is cold.
probably oil, it may be too thick when it's cold but once it warms up it liquefies and your engine runs smoothly. you could try changing oil, I'm guessing if you have a high performance oil the chances this is the problem may be greater since high performance things are usually geared towards working well when everything is hot
Jun 29, 2008 | 1991 Plymouth Colt
Garden Logo
166 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
