Question about Dishwashers
Dishwasher will not fill. Water lines have been checked and filters are clean
Dishwasher will not fill with water. we have checked lines and cleared filters.
  • 297 Answers
Flow detection shot?
Expensive one I had couple of months ago on a Bauknecht. 300 dollars. New machine at 250. Scrapped it.
Flow detector was coupled at automatic waterstop.
Beware if you have a old machine drying with hot air, most all new models use condensation leaving your dishes etc a bit bit wet :(
Posted on Apr 14, 2009
Bosch dishwasher doesn't work. water not coming
Hi Gilgol, The link below is a Bosh Dishwasher list of error codes, I believe your error code is E3....CHEERS..
http://removeandreplace.com/2015/10/09/bosch-dishwasher-error-codes-how-to-clear-what-to-check/
Bosch Dishwasher Error Code E3
Fault Condition: Not filling with water
Repair or Check: If the water supply cut-off valve on the dishwasher is completely open but the dishwasher will not fill with water then shut off the water supply and unplug the dishwasher. Remove the water fill line and check to see if the water inlet screen valve is plugged up. If so then replace the water valve. Cleaning the screen can make the issue worse so always replace if the screen is clogged. The valve can get stuck open from gunk and therefore flood or overfill.
Parts Required: Water inlet valve
Bosch Water Inlet Valve Assembly for Dishwasher
Apr 02, 2016 | Bosch Dishwashers
My dishwasher wv9-6s a bush brand is displaying error E1 can someone helpe please
E1 error is the water is not filling quickly enough or restricted or low water pressure or not filling at all.
check your faucet is turned on, if it is turn it off and take the water hose off. There is a small strainer or filter in the line at the dishwasher end, ensure it is clean and clear.
May 22, 2014 | Dishwashers
Are there intake filter screens on the GU1500XTL B?
I have never heard of a water filter for a dishwasher since the water entering your house is clean and filtered and potable. If the water supply line for your dishwasher is clogged you have a different problem where in you must clear it to allow sufficient flow for the machine to fill. If it is restricted it will most likely take longer to fill but it will still operate. If the filler is on a timer then you will not be getting enough water into the machine and must restore adequate flow for it to operate. There is no need to filter water into your dishwasher. People who have water supply problems will get water conditioners for hard water issues and whole house filters for sediment problems. I would get Culligan to take responsibility and fix the problem if they caused it.
Mar 11, 2014 | Whirlpool 24 in. GU2500 XTP Built-in...
I have frigidaire dishwasher,starts cycle,can hear water entering dishwasher,checked level of water,does not get to 1",machine starts washing by the sound of motor, but dishes are not clean,water drains...
Depending on your dishwasher, it fills either by a timer or by a water probe or float. I will assume its a timer as a probe or float wouldnt exhibit this behaviour. I would say you have a restriction in your water supply line. Check your valves, any screen filter in the water line for sand/scale/silicate/etc, pressure regulator if applicable. Another posibility is a poor magnet in your fill valve.
Dec 19, 2009 | Frigidaire Dishwashers
Dishes come out pitted and feel dirty. I have
Hi
Thanks for using FixYa. First of all please check the Water temperature by using a thermometer inside the dishwasher to measure the water temp. It should be as close to 125 degree F to 140 degree F as possible. Now try using the temperature boost feature if your dishwasher is equipped with this cycle feature and check if this will help your wash ability issues.
Now check the Powder soap by making sure that you store your soap in a dry environment and it is not stale and clumping together. Possibly try a different detergent like a liquid or gel. Also, make sure the dishes are loaded properly, or dishwasher is not overloaded.
To check the proper filling dishwasher will fill with water up to and around the heating element. If water is more below the heating element, you may have low water pressure or a problem with the fill valve. Try & listen if it sounds like it is spraying the water around with enough pressure.
For low water pressure, try to clean the screen at the entrance of the fill valve, sometimes the fill valve can fail and not allow the proper water into the dishwasher and may need to be replaced. And, check the spray arm and pump cover for splits or leaks. Also make sure that the water is draining and is not accumulated in the dishwasher, if it is in dishwasher then check for clogged drain hoses and drain pump.
Low water fills are a very common trouble maker with today's dishwasher.
Please do rate this solution and revert for further assistance.
Thanks
Rylee
Nov 08, 2009 | Frigidaire 24 in. GLD2162RDC Stainless...
Hi, I installed LG dishwasher, control board is working, water is coming from the water line but when hooked up to the dishwasher and dishwasher is on, there is no water coming into the dishwasher....
it should drain a bit of water out before it fills when it first starts. if that water doesn't drain out then you may have a drain pump fault. You can test this by dumping a few glasses of water into the machine then starting it up ( you should hear it drain that water out)
if that worked... then you have a fill solenoid fault or a line filter fault.You can check power to the fill solenoid or give it a couple of taps when its suppose to be filling to see if its just stuck. the inline filter could be plugged where you hook up the water supply to the machine (clean it or take it right out)
Aug 23, 2009 | LG Dishwashers
Dishwasher gets no water
It is no fuse in dishwasher.
Solution1: Check if the inlet line to d/w is open(usually it located under the sink)
Solution2: To rich a fill valve filter:
1. Shut off water to d/w
2.open kick panel under front door of d/w
3.disconect the water line on left hand side
4.pull filter from center of water valve by nose pliers
5. clean the filter by old toothbrush under the sink
6.put everything back
7. if does not help the water valve needs to be replace
Nov 29, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Miele G 7856 Commercial Dishwasher
Hi. The above machine stops mid cycle and drain/fill light is on, also error code F3E, have cleaned both hot and cold water inlet filters, also checked drain pump and drain line, all ok. Machine drains with no issues and fills with hot water, runs for a while then shuts down.
Any ideas?
Aug 20, 2008 | Miele 24 in. G638 Plus Free-standing...
Problem with Miel dishwasher: no water
if the valve is humming and the tap is on it should fill.is there a plv fitted to the tap somtimes they fail.i had one today on an asko for not filling.remove the hose from the dishwasher and turn the hose on into a bucket to see if water comes through.the valve could still be faulty.hope this helps.
Mar 19, 2008 | Dishwashers
Water problem
Many dishwashers will drain at the beginning of any cycle.
If the water does not fill after the pump-out cycle, then the problem is either the fill valve or the float switch. You should be able to hear the float switch click as you raise or lower it. The fill valve usually hums whenever it has power.
If the fill valve has power but doesn't open, (use a voltmeter) replace the fill valve. If there is no power at the float switch, nor at the fill valve after pumping out, then the clock / timer is at fault.
Mar 10, 2008 | Dishwashers
Dishwashers Logo
117 people viewed this question
Top Dishwashers Experts
