Question about Canon PowerShot A520 Digital Camera
E18 Message - Beeping.
Okay, the lense goes half way out, then beeps, then an E18 message is shown. I've looked, I've tapped, I've blown and played with it, i've followed online help, but it just won't fix!
  • 641 Answers
The E18 error message relates to a problem with the zooming mechanism (lens would not retract or extended) Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem. In any case it could not make it worse Good luck!
Posted on Sep 13, 2007
Samsung microwave displays press 1-4...
The SE indicates a short in the keypad membrane, but to cure this! the whole keypad control board should be changed if effort to resolve is decided, I would also suggest checking the pricing.
Apr 16, 2012 | Samsung SMH9187ST Microwave Oven
Camera powered on, lenses extended, then got an E18 error message. Won't take pics, lenses won't retract. Tried charging battery, no difference. Powers up, powers off, that's it.
Canon E18 error happens when the lens gets stuck while trying to extend.
There is a step-by-step tutorial (with pictures) for fixing this yourself on this website, which is too long to re-post here.
You can also try tapping the USB port lightly against a hard surface, and using compressed air to blow out the area between the camera body and the lens turret.
If you can't fix it yourself and decide to send the camera back for repair, be warned that Canon has horrible customer support and response time. You might want to consider replacing the camera instead.
Oct 25, 2009 | Canon PowerShot S410 / IXUS 430 Digital...
Beeping lights when trying to sew
Look at the back of the needle threader. There is a buttonhole lever. Pull it down and push it back to the top. The machine gives a warning message if the lever is down and you wants to sew or embroid.
Good Luck
Dec 01, 2008 | Singer CE-100 Futura Computerized Sewing...
Persistant beeping
Look for the buttonhole lever, just behind the needle threader lever. Pull it down and push it up again. The machine gives a warning message if you want to sew and the button hole lever is down. Good luck!
Nov 03, 2008 | Singer CE-200 Quantum Futura Computerized...
When I try to zoom, screen goes black and "E18" appears in bottom corner
I won't say this is a solution but to prevent the lens retraction E18 message which seems to be common with Canon zoom lenses, I put the extension tube on mine. Sometimes I put a polarizer lens on it but usually I just leave it on to protect the lens when it is on. I have dropped it (on the carpeting at home) and never had a problem. If you have a Canon with a zoom lens, get a lens hood for it ASAP!! My wife's A520 has one on hers too. No problems.
There are lots of other places on the web with suggested fixes. Keep looking and keep enjoying this camera. Merry Christmas all.
Oct 31, 2008 | Canon PowerShot S2 IS Digital Camera
Locked
Just worked this one out ...there is a small white sliding tab on the side of the sd card.
If you put the card in upside down it will catch the tab and move it..thus locking the card.
Take it out move the tab to the top and re-insert. God I'm dumb ! I love it.
e18 message, this means the lense cannot open properly...6 beeps and she's gone.
There is a small amount of grit caught between the lense and camera preventing it from opening evenly .. a little tap on the bench will release it.
Repeat until clear.
Have a wonderful day, Smithy Australia
Sep 29, 2008 | Canon PowerShot A400 Digital Camera
Motorola MD4260
I had the same problem.
Here is the solution that I received from Motorola tech support:
1.Delete all messages
2. Unplug the power and re-apply power
3. Quickly press and release << (previous message) and >> (next message) buttons together while the "Press review to receive setup instructions" message is playing.
The display will change from a segment scanning clockwise to anti-clockwise
4. Quickly press and release the On/Off button before the "Press review to receive setup instructions" ends. The display will change to a square scanning clockwise.
Note, this goes by quickly. I had to repeat steps 1-4 a couple of times before I got it right.
5. Press and release the delete button. The unit will emit a beep.
6. Press and release the on/off button. The unit will emit another beep and annouce "Press review to receive setup instructions"
Done!
Nov 22, 2007 | Motorola Mobility MD4260-2 Twin Cordless...
E18
This error is cause by a few things. First you need better power, how old is the unit? The battery pack may need replaced, the lens mechanism draws alot of power and sometimes if the flash is charging and the lenses are moving it struggles for power and shuts down. Another thing that can cause this error is jammed gears in the lens. This can be cause from an impact (dropped unit) or debris in the lens mechanism (sand, dirt, dust) the gears are so small and as is dust anything can blow in there and get jammed in the unit to jam it. I have got units to function again by tapping on the front of the lens while repeatedly tapping on the front of the lens. The idea is to work the jam out and free the lens. The E18 means a stuck lens but the reason its stuck i canot tell with out looking at it. Tap on the front of the lens (the part that moves in and out like a telescope) or try and tap on the side while powering it on. If you know some one with a unit like yours try their battery before you get a new one. They are very power hungry and if your unit is a few years old it may be time for a new battery.
Apr 03, 2006 | Canon PowerShot S400 / IXUS 400 Digital...
Canon PowerShot A520 Digital Camera Logo
176 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Steven Wander
Steven Wander
Are you a Canon Camera Expert? Answer questions, earn points and help others
