Question about Frigidaire 24 in. FDB1050RE Built-in Dishwasher
Causes interference with radio, tv
My frigidare dishwasher model fdb 1050re causes interference with my under counter radio. I am in the process of trying to get it replaced because it is still under warranty. However, my old Maytag did not cause this problem. Any solutions? Thank you Jim
    President:
  • 1,489 Answers
You could possibly add a metal shield around the electronics in the dishwasher and ground the shield with a wire to the dishwasher chasis. Don't know if this would reduce the EMR enough to stop the interference with the radio, but there's a chance it would.
Posted on Apr 22, 2009
Frigidare fdb1500lfco
Good Morning Kristen - You may try to reset the dishwasher by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and turn the dishwasher back on. If this proves to be ineffective, then the unit may possibly being experiencing a communication issue with the control panel, wiring failure, drain motor/pump or water valve. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair the unit.
May 28, 2013 | Frigidaire 24 in. FDBB840DC Stainless...
My middle spray arm does not turn. I have plenty of water when I turn it on, it's just that it isn't getting to the nozzle up top? Any suggestions?
Sounds like your sump might be blocked. I would take the inner assembly out and check for food and debris in the sump area including the drain pump/chopper blade.
Jan 24, 2012 | KitchenAid Dishwashers
Dishwasher makes tv flicker what causes this
1. the interference filter on your dishwasher is defective. all electic motors give off a type of radiation which is picked up by other devics such as radios and tv sets, most devices have a component which filters this out. this part may be defective.
2. both tv and dishwasher are on same power supply try swithing the tv to a different power outlet to see if this solves the problem if it does have an electrical engineer test the power sockets for any faults.
i hope this helps
Dec 11, 2010 | Frigidaire Dishwashers
Frigidare dishwasher model # NDB 631 RF 53. Washer runs but does not dissolve soap and jet tablet. Does that product not work with this dish washer?
Check your heating element..
A bad heating element causes many problems in dishwashers…
Dishwasher Problems The Heating Element not Working
http://www.fixya.com/support/r4589033-dishwasher_problems_heating_element_not
Dishwasher Maintenance
http://www.fixya.com/support/r4319937-dishwasher_maintenance
heatman101
Asker's Testimonial " expanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Aug 24, 2010 | Dishwashers
My lg wm 14225fd is making a banging popping
this sonde like the drum needs to be rebalenced this needs to be done once a yr. you well need to call a repair person its covered under your warrenty.
Dec 22, 2009 | Washing Machines
Since the transfer to digital TV, I cannot receive the TV channel
The under counter radio was designed to receive the audio from analog TV stations on its TV band. The analog TV signals are no longer being broadcast.
Jun 16, 2009 | Sony ICF-CD543RM Clock Radio
Can't find the model number on Frigidaire dishwasher
The nomenclature should be located on the left side on the inside of the tub right by the front when you open the door. It is most likely an fdb series example fdb1050. however the drain hose pn 154606701 is the factory replacement for most frigidaire dishwashers ten years or less.
Mar 31, 2009 | Frigidaire Professional Series 24 in....
Maytag model no: dwu8530aax installation
under counter dishwasher installation look under sink is plumbing set up for dishwasher? drain and water supply? if no you need to do some plumbing. if yes you need to supply power- water- drian it just slides under counter and is screwed in with 2 screws in 2 brackets on front top of dishwasher. thank you for useing fixya please rate me if you need more info contact me thank you again
Feb 20, 2009 | Dishwashers
can you give me the exact model # on your dishwasher and i will check for you.
Sep 03, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Frigidaire 24 in. FDB1050RE Built-in Dishwasher Logo
221 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
