Program computer-Maytag commercial washer mat12pdbaw
JUst purchased 10 used Maytag commercial model #Mat12pdbaw. Need help to program price, cycles, etc. I don't have instruction booklet
  • Anonymous Apr 27, 2009
    I bought several mat12pdbaw washers and need to know how to change the coin amount.
Try going to this website and scrolling down to find your Maytag Model number. Click on the model number and the programming steps should come up for you.
Anonymous
Posted on Feb 23, 2011
Open the service cover door/switch, on top of coin box .
Numbers will be flashing.
Push the middle button 1 time untell you get to the "6 0X" The third digit,on my example is X. The X represents the number of quarters to start the wash.
Push the left button to the number of quarter you want your vend.
Example
6 01 = .25
6.02 = .50
6 03 = .75
6 04 = $1.00
6 05 = $1.25
6 06 = $1.50
6 07 = $1.75
1 to 39
Replace cover and correct vend will show.
Posted on Dec 13, 2011
Maytag centennial washer won't fill during rinse cycle
If the inlet works during the wash cycle or start program but does not work during the rinse cycle, then it is due to fault in the program. Select another program to confirm this cycle or choose another cycle. If the fault is the same on all the programs then it can be due to the controller unit.
May 04, 2015 | Maytag Washing Machines
Why won't my washer finish it's cycle?
First attack is the lid switch- make sure it connects when closed- you can bypass with a jumper until replaced. After that the water inlet valve. If asking for cold rinse the washer will just sit there waiting to fill. confrim cold water at the valve by pulling hoses or if there is cold at other times like warm wash - you can feel it while filling. There may be a blocked in-line filter so check the external hoses and valve too.
May 16, 2014 | Maytag MAT12PD Top Load Washer
WHy won't my washer finish its cycle?
check lid switch first, this is most common.(machine thinks lid is open), carefully lift and lower lid an you should here a faint click. otherwise i hit some timer issues but not so common. there is no reset, the model you gave comes back as electro-mechanical and not electronic
May 10, 2014 | Maytag MAT12PD Top Load Washer
How to reset control panel to $1.50 / $2.00 on a Maytag commercial washer
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
Apr 25, 2013 | Washing Machines
CHANGING THE MONEY AMOUNT ON A DIGITAL COIN OP MAYTAG WASHER MODEL# MAT12PDBAW
I JUST HAD THE SAME QUESTION FOR A CUSTOMER REQUEST, I TALKED TO THE TECH SUPPORT AT MAYTAG AND THEY EXPLAINED THAT ALL YOU DO IS UNPLUG THE CONNECTOR CC FROM THE PRINTED CIRCUIT BOARD THEN SCROLL WITH THE CENTER BOTTOM BUTTON, TILL YOU SEE 600 DISPLAYED. (600 IS ZERO COINS, 604 IS 4 COINS, 608 IS 8 COINS, ETC.) THEN RECONNECT THE CC CONNECTOR AND PUT IT TOGETHER, SOUNDS SIMPLE ENOUGH. IM GONNA GO TRY IT
Sep 16, 2010 | Maytag MAT12CSD Top-Load Coin Operated...
Front load washer problem
rl means there are clothes in washer during cleaning cycle...however .there is a glitch in the program and have seen that rl code with no clothes in washer...don't bother calling repairman it's a program issue with the computer last i heard there was no fix forthcoming and customer were to be told to use normal cycle as they would the clean cycle
Sep 06, 2008 | Kenmore Elite 45986 Front Load Washer
RE: MAT12PDBAQ Maytag top-load washer (Commercial/Coin-op)
Click on 'washing machines' (below FIXYA) on this website, & search for your brand. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, u hv your manual on line. If available that is....................
Rate me pl if helped...................
Apr 10, 2008 | Washing Machines
I need the coin programming instructions
what sort of coin acceptor is it? single slot? multiple coin slide in? write me at my email: srf12980@localnet.com.
Sep 12, 2007 | Maytag MDE16CS Electric Dryer
Washing Machines Logo
2,074 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
