Question about HP Pavilion dv1000 Notebook
When should you change out your laptop battery?
My hp Pavillion laptop doesn't seem to be getting any power even when its plugged inot the ac adapter .I have had it for about 3 and half years now.My question is when should you change out your laptop battery as I still have the same one in it when I first bought it.
Thanx
Dan
  • 326 Answers
Laptop batteries life will vary depending on use. In my experience it is suggested to replace the battery within 3 years. This depends on your requiring the battery.
If you wish to work mobile then a new battery makes your investment a tool, and should be considered.
Posted on Apr 14, 2009
Nc6000 multibay battery does not recharge
Perhaps remove the multi-bay battery, and let main battery charge all the way. Then reattach multi-bay battery, and see if it's recognized.
(Will charge)
That is AC adapter (Charger) removed, then remove multi-bay battery.
Plug AC adapter back into laptop, THEN plug AC adapter into power.
[You do Not want to unplug an AC adapter from a laptop, with the AC adapter plugged into power. Could be a power surge/voltage spike. Unplug AC adapter from power, when plugging into laptop, or unplugging from laptop ]
Main battery charged, unplug power to AC adapter, unplug AC adapter from laptop. Plug multi-bay battery in, then AC adapter.
(Then plug AC adapter into power)
Post back in a Comment.
Regards,
joecoolvette
Feb 28, 2013 | HP Computers & Internet
3 weeks ago My Laptop HP Pavillion Entertainment system DV9500 shut off while I was using it and now it doesn't even power on. I purchased a new power supply thinking that was the problem but still can't...
unplug the ac adapter from the laptop and remove the battery
press the power button for about 5-10 secs
while the battery is out, plug in the ac and turn on the computer if still doesnt turn on
use a known good adapter and plug it in if it still doesnt work then motherboard needs to be replaced
hope this help
Sep 07, 2010 | HP Computers & Internet
HP Pavilion dv6000z 15.4" Notebook Laptop PC (AMD Turion 64 X2 Duo Core TL-50 1.60GHz, 1GB RAM, 100G... (d6000z) PC Notebook: My hp pavillion dv6000 dims while having the ac ad...
Go to Control Panel > Power Options
You will need to change the setting for when it is connected on battery and when it is connected on power.
May 14, 2010 | HP Pavilion dv6000z Notebook
My hp pavillion was no power without ac adapter
if the pc is not getting power without the ac adapter then most likely the battery is dead if it does not take a charge via the ac adapter then then the battery is no good or the ac adapter is busted
Apr 28, 2010 | HP Pavilion dv1000 Notebook
My hp pavillion was no power, please give an advise.
There could be a problem with the battery. A fast check to determine whether you have a problem with the power adapter, power cord or the laptop's battery is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
If the laptop works directly from the power adapter with the battery removed, then the power adapter is good. In this case we can suspect that the battery is defective & needs to be replaced.
To verify this, unplug your laptop & try to run it on battery only. Watch out how long it will stay on (if at all). If it didn't work on battery alone, or worked but for a very short time, then your battery is defective.
Apr 19, 2010 | HP Pavilion dv1000 Notebook
My hp pavillion laptop won't start at all whats wrong?. It hasn't been dropped.
Remove the battery and the AC adapter then press and hold the power button for 30 secs. Put back battery and plug back AC then power ON as normal.------
Also try with ONLY battery (AC removed) and vice-versa.--
Basically I would check output of my AC adapter first. If everything is OK with that, I will check the power button.
---- This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Feb 24, 2010 | HP Pavilion dv6000z Notebook
HP Pavillion HDX 9000- No Power I was using the laptop when suddenly I got a message saying I had mimimal battery power and I needed to plug in my AC power. But the AC power supply was already plugged in....
Sandytoo,
Sometimes the AC port on the motherboard can become loose or disconnected and will cause the powercord to not charge to the batteries or run power to the motherboard. If you changed out the Power adapter and that didn't help, then this would be my best assumption. The AC connection on the motherboard can be replaced pretty easy by someone knowledgable in motherboard repair with sodering. Most of the time with this issue, a motherboard replacement is not required, Even though its alot easier to just replace the board. Most Repair places will probably talk you into replacing the board, even though its really not necessary, with this issue.
Sep 22, 2009 | HP Pavilion dv9000z Notebook
My laptop HP Pavillion ZV6000, battery started decreasing and wouldn't charge when the ac adapter was connected. I purchased another ac adapter thinking that was my problem. It didn't work. Now I have...
As others have said, the most common fault with the ZV series is the power socket. However, you mentioned the Lightning Bolt. This indicates that the battery is being charged and it should go out as soon as the battery is fully charged.
If the Lightning Bolt flashes on and off regularly, especially when the power cable is moved, then the socket is at fault and needs replacing.
You can check to see if the battery is receiving a charge by doing the following
1. Right Click the Desktop
2. Click Properties
3. Click the Screen Saver tab
4. Click the Power button
5. Click the Power Meter tab
This will tell you the computer's current power source and whether the battery is charging.
I have replaced several of these sockets on ZV5000s and I'm sure the 6000 will be similar. I would not recommend this job for anyone without technical knowledge, despite some of the websites that say you can do it yourself. You will need to strip the entire laptop down and all but remove the motherboard before the socket can be replaced.
Hope this helps
May 21, 2009 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
No power whatsoever, but...
Try taking the battery out and running the laptop with just the AC adapter.
Also you should use a multimeter to test your AC adapter for voltage. If there is voltage from your AC adapter and the unit will not turn on with the battery removed then you have a faulty motherboard or another component in the laptop.
If it works without the battery all you need to get is a new battery or live with it without battery.
Sep 16, 2008 | Computers & Internet
HP Pavilion dv1000 Notebook Logo
125 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
