Question about Whirlpool LER5636P Electric Dryer
Dryer is not drying
There is a build up of lent in the dryer, tried vacuming out the vent but hard to get deep into the vent.
  • 3 Answers
Had the same problem. Take the back of the dryer off and vacuum were your lint trap is installed at. Once you take that plate off you will see the lint build up and you will be able to clean it properly.
Posted on Apr 20, 2009
We have a long dryer line to the out side vent... how do we improve drying time... line is clear and we clean the lent from the dryer frequently...also, clean lent after every use..
If you may want to look into installing a booster fan for your vent line.
It can really help in cases such as yours when the vent line is extra long.
Oct 04, 2014 | Kenmore Dryers
Tip
Dryer Heating Problems
I have been getting a lot of problems with dryers not heating right. A lot of sloution have been that people have been cleaning out their heat vents from the dryer. If there is a lot of lent build up in the vent or in the vent hose, it will make the elements shuts of to early. Therefore it will not dry the cloths like it should.
on Dec 01, 2009 | Dryers
Maytag dryer will not restart immediately after drying a load. has to cool down
try cleaning out your dryer vent. Remove your lint trap and use a flexible wire brush to clean deep inside, then remove your dryer vent hose and make sure all lint is clean from the dryer side of the vent and the vent hose all the way to the out side vent.
Sounds like it may be clogged with a build up of lint
May 23, 2012 | Dryers
I have an older model gas dryer with the lent catcher located on top of the dryer. It spins and it gets hot but it is not drying properly. I have to run the dryer three times to completely dry my...
you might have a restriction in the exhaust system. check the entire exhaust vent tube/hose from the back of the dryer to the outside of the building for any restrictions. check the outside exhaust vent for any restrictions or obstructions. make shure the exhaust tube/hose are as short and straight as possible any sharp curves or bends can restrict air flow.
Oct 07, 2011 | Whirlpool GGW9868K Gas Dryer
My maytag 3000 series dryer is not even a year old untill 2 more days, it does not dry my clothes no matter what setting I have it on the lent trap gets cleaned about 2 or 3 times during each cycle,yet it...
oooow,,,temper temper,,,,take a deep breath,,,
i think the temp censor has stoped working thats why its not getting very hot its that or the heating coil/s are broken,,also check the air vents at the back are not blocked up if so its not getting any air to it,,,
then go out and find a big stick,,,and batter it with the stick,,,
this realy wont help fix it,,but it will make you feel soooo much better?
Jul 12, 2010 | Maytag Dryers
Not drying completly seems not alot of lent on lent filter
Your rear connecting exhaust vent must be removed and cleaned out.
If it is the flexible vent material it must be un-kinked or mashed when reattached.
Run a 50 minute timed dry cycle with the vent completely off.
If the load dries OK,the connecting vent is the problem.
Jan 17, 2010 | Whirlpool LEQ8000JQ Electric Dryer
Dryer shuts down after 5mins and also has a random
I think the vent is pluged up or bent so that the lent is trapped in the hose. its getting too hot. don't use it anymore till you get it cleaned and check for lent build up in side. can cause fire.
Jan 02, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Dryer is taking to long to dry. taking 3 hours to dry clothes
you nead to check the vent hose and make sure it is not pinched off,also check the vent hose from the dryer to the vent outside and make sure it is not pluged with lent.
Dec 26, 2009 | LG DLE5955 Dryer
We have a Kenmore 110 6092299 90 Series dryer. The motor still runs - but no hot air, at all. I've tried timed and heat dry. Nothing. It just tumbles and it takes 4-5 rounds to dry. At first we were told...
Sounds like the heating element or the thermo-cut off. A vent being clogged for some time, can cause too much heat to build up and make the element or cut off fail. These are the 2 most common things.
May 05, 2009 | Kenmore 63942 Dryer
Dryer has heat..but very low temp , takes forever
Make sure that your vent pipe is completely clear of excess lent. It will not dry properly if the venting is not running freely. If the unit is cleared of lent, inside and out, the only other possibility is the thermostat is not reading correctly.
Apr 11, 2009 | Dryers
Whirlpool LER5636P Electric Dryer Logo
93 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
