Question about Soltek SL-75FRV Motherboard
Few Problem Infinity Loop
. Problem > Can't Play some games when i got AGP drivers on comp just Freezes with infinity loop error "WoW" No mater what driver i use. So i bypassed it by disabling AGP and use PCI-PCI bridge it resolved Crash problems. But i can't now Install Viaarena or other Based on new setup items always got same error -1612. Any ideas how to resolve those problems because i think they are linked. Thx.
    Sergeant:
    Champion:
  • 293 Answers
MEMORY PROBLEMS Hi, FOR LONG BEEPS, ONE SHORT BEEP IN AN ENDLESS LOOP, BLUE SCREEN OF DEATH AT STARTUP Try using Memtest 86+ http://www.memtest86.com/ to diagnose your memory problem. You can also try the following methods. Turn off power, Unplug. Remove the cover of your PC. Remove the memory from the Motherboard. Note on the locks! Clean the memory contacts with an eraser yes that's right a rubber Pencil eraser. It should be shiny gold. Reseat your memory to the motherboard and Test! ====================== If you are having trouble with Newly bought items save your self from headaches by returning them and demand a replacement or a refund! You may have purchased a reconditioned\repaired\factory defect product.
Posted on Sep 21, 2007
SOURCE:
Infinity tss 750 sub-woofer when powered on immediately pulls speaker in and has loud humming. no inputs hooked up, only plugged in to ac power source.
The loud humming is the sound of AC mains - clearly your amplifier is receiving an input from somewhere and possibly into the front end.
The hum could be induced by radiated energy from nearby unshielded equipment, it could be the result of an accidental hum-loop or could be because the amplifier power supply has a fault.
It is usual practice with amplifier construction to ensure unused inputs are shorted to ground by switching or by additional contacts and wiring at the input sockets. High gain high impedance inputs can cause a great deal of unwanted noise if they are not shorted.
I suggest you read the instruction manual and perhaps Google a few hints and tips about amplifiers and stuff.
Mar 28, 2016 | Infinity Audio Players & Recorders
My a/c is not working in my 2008 Suzuki forenza.
engine running
A/C on, a/c lamp glowing
fan on HIGH
the compressor clutch ,engages. (belt not missing or loose)
the compressor shaft spins very fast. near engine speed.
if it does, the loop has issues.
if not, the A/C AMP logic, module or the hi/lo freon swtich is open
the AMP, protects the loop and driver.
  1. the amp cuts the compressor, 6 ways, (about)
  2. evap freeze up
  3. a/c loop freon too low or high (that switch )
  4. engine overload.
  5. driving WOT, can cut A/c (wide open throttle) driver protection
  6. engine overheated.
if the clutch is dead. see if there is 12vdc across the clutch
yes, the coil in the clutch is open , OHMS= reads_ infinity
no.. the AMP as dropped off the A./C on purpose
we then check all inputs to the AMPA
i do the hi/lo switch first
all this is covered, in the FSM , HVAC chapter, not a secret at all.
alldata.com
suzuki pit stop plus
Sep 07, 2014 | 2008 Suzuki Forenza
1997 infinity QX4, how to remove spare tire without factory jack handle tool
When you look at the shaft if you see a large slot then any jack handle with a pin through the shaft or a loop on the end will do the job.
Feb 11, 2013 | Cars & Trucks
Infinate loop on 9600 gt
look like you have a lag in your game that maibe related to a bad driver go here (http://www.nvidia.com/object/product_geforce_9600gt_us.html ) for the lastest drivers thanks
Nov 09, 2009 | BFG Technologies NVIDIA GeForce 9600 GT OC...
No CPU to AGP controller.
is that your motherboard on you picture? if so, it has an expansion slot built for pci-e video cards, then problem solved!! if not, try updating your drivers!! then place a fan on you northbridge chipset so that it wont heat-up... that's the thing... pm me..
Jun 01, 2009 | Abit IP35P Motherboard
Texture Freezing
download a GPU monitoring tool here.. http://www.ozone3d.net/gpu_caps_viewer/
check the temps for your video card... if it exceeds 55-60 degrees celcius. its probably heating up. try to upgrade the GPU cooling. "Palit, inno3d, galaxy" these brands usually has crappy cooling systems for their cards. Plus, the nvidia 9800 series is known to produce alot of heat.
I've had a similar problem like yours... I've had a 9800GT inno3d.. it has a crappy cooling system to i had to buy it a zalman graphics card cooling system. It solved the problem...
May 24, 2009 | Microsoft CyberpowerPC Gamer Infinity 7517...
Infinite loop error
First try to pop the 8800gt into a friend's computer, if it works for them uninstall and re-install drivers yet again, followed by a format if appropriate. If it does not work, try to get a RMA on the card.
Dec 20, 2008 | XFX NVIDIA GeForce 8800 GT 512MB DDR3 PCI...
Black screen freezing and rebooting
i think you lost it, coz i have the same prob, then i have to replace it after every try to fix it (like re-nstalling driver even windows too).
Oct 20, 2008 | Evga e-GeForce 6200 GeForce 6200, (256 MB)...
Subs make a noise
If your sub or its amplifier is placed too close to the transmission box, this situation can cause interference. I suggest that you buy a ground loop isolator or an RCA filter. If the problem is about grounding, then you have to buy a ground loop isolator. Otherwise, an RCA filter can solve your problem. First of all, the problem has to be diagnosed.
Jul 04, 2007 | Infinity BASSLINK Car Subwoofer
Soltek SL-75FRV Motherboard Logo
75 people viewed this question
Top Soltek Computers & Internet Experts
Ekse
Paul Bade
Steven Wander
Steven Wander
Are you a Soltek Computer and Internet Expert? Answer questions, earn points and help others
