SOURCE: code number to use on universal remote control on a hyundai ditital tv model hy3438
just buy another universal remote which is having teach method... by using this remote u dnt need any codes... just once use the remote by which the appliance is working for teaching it then u can do any operation...
SOURCE: maxim tv
apparently some tv's are made with parts from other makes... for example a sony will use parts from toshiba.. if you can find out or know if Maxim are using any other parts and know what other make ..then i can tell you
in summary: you may need a code for a DIFFERENT model tv.
SOURCE: Need 3-digit code for tv remote
I'm looing for the TV brand to choose so I can find the right 4-digit code for an Element TV (Element is not listed)
SOURCE: Universal Remote Control Code
Each remote manufacturer has their own set of codes. There is not one standard code for your TV. You need to get in touch with the maker of the remote.
1. Hold down the TV/Tuner Button.
2. Whilst holding down the TV/Tuner Button, enter the four character numeric device code.
3. Press any other button on the remote.
NB: If the remote was sold to you under the guise of being " the correct remote control for that model," then simply remove the battery cover and you will see that the correct code for your device has been helpfully printed there. If you do not know the code for your particular device, these can be found on numerous websites, or in your TV manual.
