Question about Refrigerators
Should the coils be wet in my freezer
My coils are wet in my freezer
  • 2 more comments
  • shurpy1 Apr 14, 2009
    Door does shut, but i am confused. I dried them off should that help, get the fridge cool again.
    the freezing section gets cold, the coolong section is warm, i noticed the fan in the freezer is not running , i think that might be the problem, Is that fan designed to blow the cold air from the freezing section down to the cooling?
    really, i took it apart and there is a fan
    the fan is designed to blow some of the cold from the freezer section down to the cooling section
  • 297 Answers
In the deepfreezer you have a problem, in the cooling section not.
Is the door still shutting properly?
Posted on Apr 14, 2009
  • 2 more comments
  • astrid prieto Apr 14, 2009
    Freezing or cooling section?
    In cooling section leaving door to long opewn or too much new to be cooled and or blocked dewatering channel to compressor (little hole) can be problem. The more plastic objects in there like on dishwasher with codensation principle increases the amount ofcondensating moisture.
    First freezer I see with a fan, seen half the world.
    But then I learn every day. What exotic type you have there?
    4 things in a kitchen with a fan.
    -your fresh air/airco
    - your vacuumunit above your cookingplate
    -your tumble dryer
    -your dishwasher if a bit older
    No use for a fan in a freezer, good heavens.
    Like said, i learn every day. May I inquire wich brand and type it is? Not very energy friendly system by the way. Would like to meet the looney inventing that. Natural draft like on a chimney stack is better. Well if those people fitted a fan it has some purpose. For drying, but you draw off a whole lot of cold air.
    Better ways to design those things. So we get down to the problem of does my fridge light bulb go out when I shut the door ...
    And for that we need the schematic and check if that fan or switching element if any are good or faulty.
    Oh you got the antique reversed setup, my mother had one saved on supermarket coupons but without the fan. Still cold air goes down naturally and warm air up naturally. Open fridge part inside still? So it might be that the fan has to run continuously, was it like that?
    Well then after a while the electrical motor brushes get worn and need to be replaced like in the vacuumcleaner. Today we throw all away and buy new stuff instead of fixing that.
Why is my top freezer partially cooling
clean your coils in the back of the fridge or look under neath to clean them- a vacuum with the long skinny nozzle will work or Home Depot and Lowes sell a Coil cleaning brush about $12
Oct 25, 2016 | Refrigerators
I have a GE GSH25JFTA CC refrigerator and it is not cooling properly. What should I check or replace?
Depending how long the power was off you may have an ice blockage in the freezer. Normal cooling causes the freezer coils to build up frost and snow coating all over the coils. A normal defrost cycle melts that frost/snow off and keeps the coils clear so the fans can move air through the coils.During the power outage the frost may have started to melt wetting the snow. If the refrigerator then came on and re-froze the wet frost/snow into a solid block of ice, the normal defrost cycle would not be able to clear that solid ice out. So it may be blocking the air flow. Remove freezer back panel and see if there is ice back there. If yes--use something like a hair dryer to melt everything out until it is completely clear. Make sure the fans are running also.
Apr 14, 2015 | GE Refrigerators
Vapor coming from bottom of inside freezer and water to dispenser frozen
The most common cause of this is a dirty condenser coil. Find the condenser coil for the unit , it will be under the freezer, in the back or ,in some models, on top. It will have a fan behind it. Shut of the unit and clean it. First with a paint brush to remove heavy dirt, then with a spray coil cleaner--this may get dirty, so be prepared with a mop. Clean it thoroughly without getting electrical components wet. (If you get anything electrical wet, make sure you allow ample time to dry before energizing it).
Mar 27, 2014 | Freezers
The freezer keeps freezing the coil in the back of the freezer how do I put it on defrost
If your refrigerator is not cooling but your freezer is still working then you most likely have a problem with Ice buildup. Sometimes the ice will start to form inside the refrigerator on the bottom of the freezer compartment, even though the refrigerator section is not staying cool.
1. Empty out the freezer section so that you can remove the bottom panel that covers the evaporator coils. Side by side refrigerators often have the access panel in the back of the freezer.
2. Use a hair dryer or fan to speed up the melting of the ice. Towels will be needed to soak up the water. A wet/dry shop vac and a hair dryer work the best. Melt with one and collect the water with the other.
3. Take the couple of screws that hold the defrost coil loose and remove the heater. With an Ohm meter check the resistance of the coil. If the coil is bad you will get either and open or shorted circuit. If you get a good consistent resistance then it is okay.
4. If your heater coil is good and the fan/blower is working then you probably need to replace the defrost timer or advanced defrost control board, whichever is in your unit.
Take care....
Aug 15, 2010 | Roper Refrigerators
The freezer fills with water and overflows about once a week.The food is partially frozen and the ice is clear and wet. The fridge is cold and no problems but the freezer doesn't fully freeze and water...
your evaporator coil in the rear area behind the freezer back panel is frozen over with ice and the coil can no longer deliver cold air due to ice blocking the air flow from the evaporator fan,remove this rear panel,defrost it with a hair dryer,check the defrost heating coil for continuity,they go bad regularly,if not the heater coil under the evaporator coil,it may be the defrost timer in the refrigerator section of the unit that powers the defrost coil that needs replacement
Jul 25, 2010 | GE 22.3 Cu. Ft. Bottom-Mount Refrigerator...
Amana abb2224des with Bottom freezer. Just
the least you remove the better.use vacuum cleaner hose to collect s..t (dust) easier than wet cloth.
Feb 11, 2010 | Amana ABB2224DES Stainless Steel Bottom...
I have water pooling inside the refriderator. It
there is a drain in the freezer than gets pluged, unplug frige from wall, put food in ice chest take hair dryer and melt ice thats at back wall in freezer remove icemaker if there, and back wall of freezer inside, melt any remaining ice, **** up water with wet vac or sponge,see the pinky size hole in the pan under the coils, point hair dryer at it for a wile. now take the the lower back cover off behind frige and blow all the dust out and find the plastic tube, about the size of your finger and put the wet vac on it until you can hear it sucking in the freezer, take e cup of hot soapy water ond poor it in the freezer pan. put everthing back and your good to go
Dec 09, 2009 | Whirlpool 18.2 cu. ft. Top Freezer...
Burned hole in freezer liner
take off the back panel inside the freezer and in the coil you'll see the defrost heaters(about 3'' glass tube,look for a burned wire or a loose conection to the heaters that might sparked or ground with the wet freezer walls.
Apr 02, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
Ice build up on bottom of freezer
For units with automatic defrosting, there is a drain, sometimes concealed, for the defrosted ice (water) to drain into a removable pan under the coils below the two compartments.
I suspect this is clogged with bits of debris and preventing the melt-water from dripping into the pan.
Check under your ref./freezer behind a trim grill for this pan and check the condition of it; overflowing or empty.
Normally, the fan that blows ambient air through the coils keeps this pan dry-to-moist.
It's fairly shallow so if your ice maker is leaking it will overflow but it should normally only be wet for a short time after the defrost cycle.
If it is pretty dry, note which side is wet. If it is wet under the freezer section, the clog might be loacted there.
If you do not see any holes that could be a drain in either side of the fridge, you could have a more serious problem trying to free it.
Each liner is made as one piece to help keep the inside free of dirt traps but there may be access panels and if they are found low and in the back, they may be intended to access a drain.
If you are lucky enough to find a hole toward the bottom, you should be able to free the drain.
Depending on the location for access, you should be careful poking anything too stiff (like a screwdriver) into it as the coils could be damaged.
Something like a piece of 18 gauge copper wire would be better.
Aug 31, 2008 | Maytag MSD2656G Side by Side Refrigerator
Refrigerators Logo
174 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
