No sound and voice recording device;not able to get the right sound driver
Unable to use the mic when i connect headphone to PC, no device found for voice and sound recording..Tried searching for sound driver for toshiba satellite L100 but Not finding..please help
    Scholar:
  • 148 Answers
  • NO SOUND,NO AUDIO
  • check the system - device manager for sound and audio adapter, checks for any markings on the device red x, yellow ? , or ! checks for any sound blaster if not detected (removed it and install back)
  • uninstall and re-install the sound and audio device driver, or
  • install the sound drivers
  • use a headset or external speaker if it works the internal speaker needs replacement
Posted on May 02, 2009
The Mic is not working
right click on the speaker icon and make sure external mic is set up. One time I had to use my internal mic to record stuff it was a pain.
Play back devices
Recording Devices
Jan 28, 2014 | Frisby Computer PC Laptop Headphones...
External microphone thinkpad t41
Control Panel, Sounds, look at Recording devices (depends on the OS you are using, you didn't mention, Vista, XP, 7,8?), Mic. Your Headphones jack, when in use, will cause the internal sound to disable, depending on OS the mic setup is a bit different but you should find it in sounds, recording devices.
Nov 12, 2012 | IBM ThinkPad T41 2373 Notebook
Mic not working properly : I have a iNTEX Headphone with a mic, the mic is not working at all. I've tried recording my voice(which did not work out),In control Panel the default Voice recording device is...
u need to check u r sound setting .plz click on sound icon in taskbar then click on sound property and recording there u can check u r mic if mic not working so srry dude u need to buy a new mic kkkkkkk
Oct 28, 2009 | Logitech Premium Headset
Acer aspire 5735 mic problem
Go to control panel and sound devices and unmute the mic under record options. To avoid feed back use headphones or mute the mic in the play back option. Audacity is a good open source application to use to record on your PC.
Jul 25, 2009 | Acer Aspire 5735 Notebook
The Internal Mic In My Dell Inspiron 1525 Isnt Picking Up Sound??
You need to set the internal mic as the default input device. To check this Right click on the sound icon next to the time and select Recording properties. In the Recording properties right click on Arrey Microphone and select set as default. If this does not help. Uninstall and reinstall the sound drivers. To uninstall the sound drivers click on start and type DEVICE. Open device manager from the results and then look for sound devices. Click on the Plus sign next to Saound and audio devices. Right click on the SigmaTel entry there and select uninstall. Put a check on remove this driver from the computer. Once done restart the computer and go to support.dell.com and click on Drivers and Downloads. Enter your system service tag and download the Sigmatel audio drivers and install them. Check if the MIC works after the restart. If the Arrey microphone is set as the default and you have uninstalled and resinstalled the drivers and it does not work in MSN try recording with the Windows sound recorder and see if it works there. To open the sound recorder click on start and type SOUND. Open sound recorder from the results. Incase the mic does not record even in the recorder it could be bad or have a loose connection. If in warranty call/chat with the Dell technical support. If the warranty has expired consult a local computer guy.
Mar 29, 2009 | Dell Inspiron 1501 Notebook
HEADPHONE MIC
The headphones need to be plugged into the green jack on the computer, your microphone needs to be plugged into the pink(red) jack on the computer.
Mar 25, 2009 | Acer Power 1000 PC Desktop
My micriphone attached to headphone seems not to work.
First, make certain that the mic is really broken, by testing it in another application or devise. Sometimes you cannot hear your own voice unless you are in recording mode! If the mic is found to be working, then try to reconfigure the software, or the Yahoo connection. Good Luck!
Dec 06, 2008 | ASUS Computers & Internet
Headphones with mic model # na
Hello...
Try this one:
1.Click on Start
2.navigate to Control Panel
3.click on Sound, Speech and Audio Device
4.click on Sounds and Audio devices
another window will appear
click on the Voice tab
on the Voice Recording
click on Volume
there should appear another window
adjust the Mic Volume
hope this helps
Oct 09, 2008 | Computers & Internet
Vn-3100
use a compaticord and plug from the earphone to the mic of the pc and use sound recorder to record the message
May 16, 2008 | Olympus VN-3100PC Digital Voice Recorder
Microphone
dear mil20, this could be because of multiple reasons:
a) You've muted your mic from the speaker icon in task bar.
b) Maybe your sound driver is not installed correctly, can you play music in your system ?
c) You can check your microphone settings in control panel to ensure you've actually enabled microphone options. Also see if you've set default voice instrument speakers or headphone. Finally see if you've plugged the mic right.
d) If none of that helps you might like to take your mic and system to nearest hardware store to ensure nothings wrong with your hardware.
If that was helpful please press 'fixya'
Oct 22, 2007 | Oracle 10g Database Standard (ODBSEONUPP0)
Computers & Internet Logo
356 people viewed this question
David Payne
David Payne
