What I think you might mean is that the battery you are using expires after fifty minutes of use. There is nothing you can do except to recharge it or buy a new battery?
you can find a pretty cheap replacement lcd panel for it on ebay. it's pretty easy to replace, few screws from the front bezel, and it should snap off.
check it in the website of HP u will get the price-->go to the website-->click on the option 'accessories & softwares'-->u will find battery as well as charger under accessories-->u will also get the option of compatibility under each model of charger or battery by clicking on which u will find the models of notebooks compatible to the particular battery or charger......
Bluetooth setup HP Compaq nx 7300 is here, just click here and download it now; http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=321957&prodSeriesId=3310301&prodNameId=3310302&swEnvOID=2104&swLang=8&mode=2&taskId=135&swItem=ob-45935-1
hi there, try to perform power drain first. take out the battery and unplugged power adapter. hold and press power button for 30secs then release. put the battery/adapter back in then power on the computer. if same issue happened, this could be a battery issue. if unit is still under warranty have the battery replaceed. thanks
Have you had previous problems with your laptop power supply and battery? I have this same laptop and use it very regularly. I do have problems with battery life, but never actually powering on. I suspect the battery is not accepting a charge. My suggestion is to replace the battery and see how things go.
