How i can reset
I did a google search for the service manual and found one from Sanyo support. From that I was able to figure out how to open the unit safely, and find the fuses and safety switches to check. I found a loose wire plugged onto the main interlock switch (don't know how it worked all this time for how loose it was...). Re-attached it, and now it works fine.
WARNING! There can be very hi voltages on the inside of the uwave so you really need to be careful and know what you are doing! Also, you need a special bit to remove a couple of the cover screws.
It sounds like the magnetron may have
either failed or is not being supplied with the extremely high
voltage required to run it.
YOUR
SAFETY IS PARAMOUNT
This is a job for a professional but if
you are safety clued up, here's instruction.
Make sure the !!!!any
capacitors are discharged!!!!! before attempting any sort of
repair.
Check the door interlock switches first then the high
voltage diode with either an AVO model 8 or moving coil meter on high
resistance range for short circuit, (DVM's won't show the fault!),
the capacitor can fail and go short circuit, the feed fuse on the
primary of the high voltage transformer and then finally, the
magnetron is best checked by substitution.
Hope that helps.
