Question about Stairmaster 4600PT Stepper
Stairmaster 4600pt pedal falls without warning
When steping the pedal looses all resistance and falls to the floor without warning
I have the stairmaster 4000pt which was bought new in 2003. in 2007, i started experiencing the same problem, the right pedal would sometime slip and fall to the floor. i called the local fitness store and they came and replaced the hub assembly and that resolved the problem until now. The left pedal is now slipping.
Posted on Dec 09, 2009
  • 3 Answers
Pedals stuck
My pedals on my Stairmaster are frozen in the top position, what do I check?
  1. Remove the alternator belt. IF pedals drop, problem is in alternator. IF NOT,
  2. Remove the drive chain, IF pedals drop, problem is in transmission, IF NOT,
  3. Problem is in hub assembly. Replace assembly.
Frozen Pedals in Top Position on Stairmaster Steppers
Nov 28, 2013 | Stairmaster 4600PT Stepper
Stairmaster 4000pt pedal slips
Why does one pedal drop on my Stairmaster Stepper but the other pedal operates correctly? Stairmaster Steppers, How to Troubleshoot when one Pedal Drops (Loses Resistance) while the Other Pedal Operates Correctly
  • If one pedal drops while the other operates correctly on your Stairmaster stepper, this problem commonly occurs when the drive sprocket on one side or the other becomes defective
  • Usually, when one drive sprocket fails, the other isn't too far behind
  • The best approach to resolve this problem is to install a new hub assembly
Why does one Pedal Drop on my Stairmaster Stepper
Jul 07, 2012 | Stairmaster 4600PT Stepper
I have a Stairmaster 4000PT. When using it, the left pedal will suddenly drop to the floor. Opened the case. The spring is intact. I used it with the case open and didn't notice anything different...
Sep 02, 2011 | Stairmaster Exercise & Fitness
Should stairmaster pedals go to floor if you don't keep pedaling? once I keep pedaling they go back up, but if I just step slow they drop to the floor and do this when you first get on as well
This is exactly the way the machine was designed to work. The attached link will take you to our Website. There you can find more information about your unit. Including the Owners/Operators manual, the Service manual, diagram and parts for the unit.
Stairmaster Stepper 4600PT Parts Hub Assembly Spring SPORTSMITH net
Aug 04, 2011 | Stairmaster 4600PT Stepper
My right pedal on my 4600 cl goes right to ground i belive the bushing is bad on the leveling arm the left side pedal is good and i nice and tight on the shaft where the right side was loose do u think the...
Dec 05, 2010 | Stairmaster 4600PT Stepper
Left pedal has no resistance right pedal is fine
Nov 11, 2010 | Stairmaster 4600PT Stepper
Both pedals slip?
When both pedals slip at the same time, it is more likely to be the alternator brushes than it is to be the hub assembly. Check this link for a brush replacement video. I am also attaching a troubleshooting video for no resistance on a 4600PT.
Stairmaster Alternator Brush Replacement Video
Sep 08, 2010 | Stairmaster 4600PT Stepper
Left pedal on stepper falls to ground in workout
YOU MAYBE HAVING AN ISSUE WITH THE SPROCKETS THAT HOLD THE DRIVE CHAINS ON BOTH PEDALS. YOU CAN PURCHASE THEM SEPARATELY OR A COMPLETE HUB ASSEMBLY. TO REACH STAIRMASTER/NAUTILUS @ 1-800-864-1270
Feb 26, 2010 | Stairmaster 4600PT Stepper
Stairmaster climber model 4600 pt pedals go all
Unplug dc power connection then remove right side panel check for loose connections on on alternator, check distance of speed sensor to speed sensor disc you should no more than 3 credit card distance between them. Next remove the black wire from the B+ terminal on the alternator, then remove the brown wire from the field terminal on the alternator.Place a short wire with alligator clips between B+ and field terminals start stepping for about 10 to 15 second you should full resistance in that case its the upper console that if not replace alternator
Jan 23, 2010 | Stairmaster Exercise & Fitness
Stairmaster 4600PT Stepper Logo
1,018 people viewed this question
Top Stairmaster Exercise & Fitness Experts
zr800o1le
zr800o1le
Level 1 Expert
fordexpert
Matt Olenzek
Matt Olenzek
Are you a Stairmaster Exercise and Fitnes Expert? Answer questions, earn points and help others
