Question about Ariston Technologies L63 Free-Standing Dishwasher
Ariston L63 Dishwaher problem
I have proble with my Ariston L63 Dishwasher. When I start a program after a short while it stops and leds 2 & 4 are flashing. I found a meaning for the LEDs from internet: Heating element or High limit open or control panel. Any ideas how to start to look for the source of the problem and how to fix it? Thanks in advance
  • Anonymous Sep 25, 2008
    After I switch on my Ariston-it starts and stops after a few minutes with 2nd and 4th lights from the left blinking.What do I do?
  • Anonymous May 02, 2009
    i have an ariston L63X but it doesn't have an operating manual can anyone help me.
  • 641 Answers
Unplug the power cable, remove the service panel and follow the next steps : - Remove one of the wires connected to the heating element and check with a multi-meter the element's resistance. In case you can't read any result,you should replace the element. - Check the water level switch- The switch level is usually a diaphragm device with a small clear tube attached between the switch and the bottom of the washer's outer tub.Clear tube first from any obstruction, In case it doesn't help, disconnect the wires from the and measure with a multi-meter on its tugs for continuity and disconnection while you are inhale and blow to its tube. In case it doesn't react, you should replace it. - Control panel - look for loose wires. If you think that your main control PCB timer have failed, you may be able to get it tested, and if faulty, get a re-worked (repaired one) much cheaper than a new one. Good luck !
Posted on Sep 13, 2007
Ariston l63 is not rinsing proper cycle but instead flashing 12hr light
Error messages,
Your dishwasher is equipped with a safety system which is able to detect any operating anomalies. These anomalies are reported by one or two wash cycle indicator lights "G" flashing rapidly.
24463930-0h3kxpflbez5mdeb5anq3st4-3-0.jpg Flashing LED diode above the mark 12h (drying) indicates faulty NTC thermistor. So, could be faulty: thermistor NTC, wiring between NTC and control board, control board.
May 20, 2014 | Ariston Technologies L63 Free-Standing...
Our hot water heater has stopped working in our Ariston dishwasher. How do I order a new part?
You need to take the bottom front off the heater, UNPLUG dishwassher first. There will be two wires going to the heater element, Unplug one wire and check the element with a OHM meter to see if the element is bad. If you don't get a reading the element is bad write down the make and model number you can order this part from sears or a local appliance repair parts store.
Feb 16, 2010 | Ariston Technologies L63 Free-Standing...
The detergent dispenser on my Ariston AS100 Dishwasher will not open automatically any solutions please
put unit on a quick wash as the dispenser opens early in the cycle .. if it heats and the dispenser is still closed then a new dispenser is in order...
Nov 25, 2009 | Ariston Technologies L63 Free-Standing...
Ariston L63 dishwasher stopped mid cycle with water in base.
1) Ensure the dishwasher is turned off. 2) (may not apply) Turn the plastic blue lever located under the sink to the vertical position (this opens the valve, so water can go into the dishwasher) 3) Pour powder indo the dishwasher 4) Turn the dishwasher controller to the top position (the 12 o?clock position) ? this is the eco-setting. 5) Press the on/power button on the dishwasher, so that it now turned on (a light will display) 6) Move the dishwasher controller to the ?R? position (it?s on the very left), and leave it there a second or two. 7) Move the dishwasher controller back to the eco-setting (the 12 o?clock position
Jun 16, 2009 | Ariston Technologies L63 Free-Standing...
Does not fill with water
fixed problem by throwing machine out into back yard and buying new one. seems to have worked up to now
Dec 03, 2008 | Ariston Technologies L63 Free-Standing...
L63 Salt light is flashing
goes for short time and 2 ljghts flash the red salt light wont go on
May 16, 2008 | Ariston Technologies L63 Free-Standing...
Ariston Technologies L63 Free-Standing Dishwasher Logo
1,329 people viewed this question
Top Ariston Technologies Dishwashers Experts
Renee Knafel-Bullock
Are you an Ariston Technologies Dishwasher Expert? Answer questions, earn points and help others
